Originally Posted By: irq3
According to the Briggs specs, it should be 3,750 +-100 RPM no load. The no load frequency output should be 62 - 62.5 Hz. As you load the generator, it slows down. It should be around 3,600 RPM/ 60 Hz (or slightly under) fully loaded.
went to the shop today with my volt meter and RPM gauge and this is what i came up with.
Gen needed to be set to 3950 RPM's(no load) to hold a good 123.5(+/-.2)volts,i'm a little concerned with these operating rpm's anyone think so???
i set it there so as the load increases i won't drop below my
120v,,sound right??? i checked my house voltage and that's
123.8ish so i figured the gen should be close to that..
3600 rpm's wasn't even close to my needed volts,i think only
like 118ish.
