Discount Tire Direct 4th of July Sale
by sopususer
06/24/16 08:37 PM
Bible Students?
by Eddie
06/24/16 07:51 PM
What kind of oil drain plug gasket is this?
by Chris B.
06/24/16 07:36 PM
by Chris B.
06/24/16 07:34 PM
First time changing oil what to use ?
by sshazam
06/24/16 07:13 PM
toshiba 720p 28" TV hdmi to thinkpad vga cable?
by bmwjohn
06/24/16 06:48 PM
1988 Brougham
by momo
06/24/16 06:38 PM
Permatex Silicone Tape
by Warstud
06/24/16 06:28 PM
Walnut Grips Really Make A Difference !
by billt460
06/24/16 06:25 PM
PC freezing up when streaming sports
by sleepery
06/24/16 05:52 PM
Use a heavier oil or HM oil?
by mclasser
06/24/16 05:42 PM
Kendall GT-1 (w/titanium?) 20w-50 for airheads
by Samzone
06/24/16 05:20 PM
Koloa, codeman021, chryslerconcorde, VolCntry73, OilyWaterMIXER
58254 Registered Users
92 registered (69GTX, 2015_PSD, AEHaas, 97f150, 01rangerxl, 7 invisible), 1559 Guests and 12 Spiders online.
58254 Members
66 Forums
250764 Topics
#1329921 - 01/03/09 05:41 PM Motorcraft FL-810 Specs
mikey12 Offline
Loc: Ohio
Anyone know the specs of this particular filter? Bypass valve spec, gasket ID/OD, etc? I can find specs of crosses, but not of this particular filter. Valve specs differ depending on the brand crossed to.
#1329927 - 01/03/09 05:48 PM Re: Motorcraft FL-810 Specs [Re: mikey12]
StevieC Offline
Loc: Niagara Falls, ON, CA (near)
I think WIX filters match OEM filters exactly. I would check it out on the WIX filter website. ;\)
'06 Hyundai Sante Fe - 330K KM's
Current Oil: RLI 0w30 (Ask me why)
Don't be part of the Sheeple, check frequently for wool over your eyes. wink
#1329962 - 01/03/09 06:17 PM Re: Motorcraft FL-810 Specs [Re: StevieC]
mikey12 Offline
Loc: Ohio
This is what I have so far:
FL810 crosses to:
Wix: 51334, 8-11 psi valve
Baldwin: B227, 20 psi valve
Donaldson: P550162, 11-17 psi valve
Purolator: L14459, 12-15 psi valve
Hastings: LF402, 20 psi valve
K&N: HP-1004, 11-14 psi valve
Fram: PH3593A, 12 psi valve
#1330116 - 01/03/09 08:46 PM Re: Motorcraft FL-810 Specs [Re: mikey12]
Gary Allan Offline
Loc: Pottstown, PA
Take all of your subsequent numbers and rerun them through all the xref utilities. They'll yield other numbers ..that you also run through all of the xref utilities again.
If you go to Donaldson's site and use the Attribute Search (up and to the right on the xref page) you can put in all the instances of 20Mx1.5 (there are a few) and it will puke out all the filters with that thread. You can then select or reject those that have odd gaskets or whatnot ..and then run all of them through all of the various xref utilities ...etc..etc.
http://lube-direct.com/gallan/
#1330124 - 01/03/09 08:52 PM Re: Motorcraft FL-810 Specs [Re: Gary Allan]
mikey12 Offline
Loc: Ohio
Been down that road, saw an older post referring to Donaldson. Was curious if anyone had a Motorcraft book on the FL-810 specs since I cannot locate any info on Motorcraft web site. Thanks
#1330146 - 01/03/09 09:20 PM Re: Motorcraft FL-810 Specs [Re: mikey12]
killagt Offline
Loc: MS
I love wix ( dont get me wrong ), few month ago I did compare WIX and FL820S, look inside FL820S is way more bulky and more profesional design then WIX. I stick with motorcraft, right price-right quality.
#1330433 - 01/04/09 07:58 AM Re: Motorcraft FL-810 Specs [Re: killagt]
Gary Allan Offline
Loc: Pottstown, PA
..but this is a FL810 ..not FL820S ...
I got caught by the close number too.
