$12.95 qt
http://aerospacelubricants.thomasnet.com...y=prod&filter=0
Quote:
ProDrive Type 6, 0W-20, 1 Qt.
Synthetic motor oils have been on the market for many years. Most major oil companies have introduced their version of synthetic motor oil. All of these oils are blended using commercially available additive packages pre-approved for read across API certification. These additive packages are blended to produce the lowest possible cost oil that will pass the selected API certification requirements. This is the reason motor oils, including synthetics, are all very similar (EXCEPT ALISYN).
Quote:
Alisyn synthetic motor oils are blended to give the highest possible performance, regardless of cost. We use expensive ingredients that make it impossible to compete, based on cost, with most other motor oils on the market. Alisyn motor oils are designed for high performance race engines, not the small test engines used for API certification.
Interesting PDS
http://www.aerospacelubricants.com/files/sheets/prodrive type 6 tds.pdf
Interesting PDS
