This is my first post and my first UOA. I'm a little concerned with the results, which seem to show high wear. Sorry about the columns note lining up. I was having trouble copying the Blackstone PDF file. Anyway, Blackstone says:
MIKE: The first sample from your 4-Runner doesn't look too good, though we aren't ready to call any of these readings
a major problem. Universal averages show typical wear levels from this type of engine after ~5,700 miles on the oil.
Silicon may account for a lot of the wear if it's from dirt getting past the air filter, so check this system closely. The
viscosity was a little high and that could show the oil has seen some excess heat. The TBN was still okay at 3.8, so the
oil has some active additive left. 1.0 is low. Try a ~3,000 mile oil run next and check back to monitor.
ALUMINUM 8
CHROMIUM 1
IRON 49
COPPER 12
LEAD 39
TIN 3
MOLYBDENUM 87
NICKEL 1
MANGANESE 1
SILVER 0
TITANIUM 0
POTASSIUM 3
BORON 53
SILICON 26
SODIUM 67
CALCIUM 2059
MAGNESIUM 16
PHOSPHORUS 568
ZINC 799
BARIUM 1
SUS Viscosity @ 210F 63.1
cSt Viscosity @ 100C 11.08
Flashpoint 420
Fuel % : 0
Antifreeze % 0
Water % 0
Insolubles % 0.3
TBN: 3.8
ALUMINUM 8
CHROMIUM 1
IRON 49
COPPER 12
LEAD 39
TIN 3
MOLYBDENUM 87
NICKEL 1
MANGANESE 1
SILVER 0
TITANIUM 0
POTASSIUM 3
BORON 53
SILICON 26
SODIUM 67
CALCIUM 2059
MAGNESIUM 16
PHOSPHORUS 568
ZINC 799
BARIUM 1
Flashpoint 420
Fuel % : 0
Antifreeze % 0
Water % 0
Insolubles % 0.3
TBN: 3.8
