Dust caps needed to protect wheel bearings?
by Drew99GT
05/29/16 09:51 PM
2014 Mazda CX5 SkyActiv
by Matt_V
05/29/16 09:38 PM
getting rid of pwc with intermittent problem?
by motor_oil_madman
05/29/16 08:36 PM
Difference between silicone caulking ?
by Merkava_4
05/29/16 06:15 PM
The Top Dexos2 Oil Available in the USA is What?
by Best F100
05/29/16 05:24 PM
Virgin Puro L14006 [Cut open]
by Run
05/29/16 05:13 PM
The 17 year cicada is here. (locust) PIC HEAVY.
by Rand
05/29/16 04:23 PM
How long is sealed coolant good for?
by addyguy
05/29/16 04:08 PM
4T65E 2006 Buick Lucerne Normal decel gear banging
by deanm11
05/29/16 03:41 PM
California drought and 3" fish delta smelt
by HTSS_TR
05/29/16 03:18 PM
High SAPS & DPF Re-Gen
by userfriendly
05/29/16 02:50 PM
Decent little string trimmer
by Papa Bear
05/29/16 02:24 PM
Moutainman31282, AlaninPA, z0bug33, smitty31, jimshep
58013 Registered Users
94 registered (29662, 04SE, 901Memphis, adolan21, 2015_PSD, 2002 Maxima SE, 6 invisible), 1363 Guests and 314 Spiders online.
58013 Members
66 Forums
249575 Topics
Page 1 of 2 1 2 >
#1303242 - 12/06/08 12:11 PM Oil/Filter recommendation for 2007 Camry 2.4
mrmatrix Offline
Loc: Ohio
For Budget minded folks such as myself, what is the best dino oil/filter to use for a 2007 Camry 2.4L 4 cyl? I have had very good luck with factory Toyota filters in the past and they are not priced bad. The factory recommended oil is either 5w-20 or 0w-20. 0w-20 is out of the question because it is only available in synthetic.
I am basicly looking for a good 5w-20 dino oil for our situation: about 40% of the trips are about 5 miles or so and the remaining trips are at least 10 miles or more. We drive this car about 12,000 miles per year and plan on keeping it about 5 more years or so.
Any comments on the filter brand would be appreciated as well.
Again, we are on a pretty strict budget so price is a major factor as well
Thank you
#1303244 - 12/06/08 12:18 PM Re: Oil/Filter recommendation for 2007 Camry 2.4 [Re: mrmatrix]
Bill in Utah Offline
Loc: UT
Thank you
I'd go down to your local Wal-Mart and pick up either QS, Pennzoil (looks like it just went up) Valvoline, Halvoline or Motorcraft 5w-20 jug of oil and a Supertech oil filter if avail and go to town. 5k OCI and your set. Your total cost should be under $20.
Remember that you have to keep records to show Toyota that you DID change the oil every 5k or 6 months whichever came first.
Nice car. I wish I bought a Camry back in 2007.
Take care, bill
#1303248 - 12/06/08 12:24 PM Re: Oil/Filter recommendation for 2007 Camry 2.4 [Re: Bill in Utah]
mechtech2 Offline
Loc: Chicago Area
I don't think that there is a substandard 5-20 made.
They are all pretty good to excellent.
Don't forget that Havoline is also a contender, in addition to what ^Bill said. I use Motorcraft.
#1303261 - 12/06/08 12:35 PM Re: Oil/Filter recommendation for 2007 Camry 2.4 [Re: mechtech2]
JHZR2 Offline
Loc: New Jersey
havoline or pennzoil would be my choices. Stick with toyota filters if you like them, otherwise id pick a purolator.
#1303279 - 12/06/08 12:55 PM Re: Oil/Filter recommendation for 2007 Camry 2.4 [Re: JHZR2]
dishdude Offline
Loc: Phoenix
+1 what they said. Avoid Fram filters.
#1303281 - 12/06/08 12:58 PM Re: Oil/Filter recommendation for 2007 Camry 2.4 [Re: dishdude]
mrmatrix Offline
Loc: Ohio
off to wal-mart I go! If I go with purolator, should I go with the purolator "pure one". They used to be much better.
#1303285 - 12/06/08 01:02 PM Re: Oil/Filter recommendation for 2007 Camry 2.4 [Re: mrmatrix]
rg200amp Offline
Loc: Phila,PA
The pure one is better. More money but better. If your on a real tight budget, the regular purolator will work fine.
As for oil, I too would recommend the Pennzoil or if not that the Motorcraft.
// 2013 Subaru WRX //
SOLD:
-11 Volkswagen Jetta
-04 Lincoln LS
-01 Ford F250
-04 Mazda Rx-8
-97 Jeep Wrangler
-97 BMW M3
-97 Nissan Maxima
#1303286 - 12/06/08 01:02 PM Re: Oil/Filter recommendation for 2007 Camry 2.4 [Re: mrmatrix]
Loc: UT
Fram filters are fine. They meet or exceed (and some MFG USE THEM) your engines requirements.
There are filters that are cheaper that do the same. That is why I don't buy Frams.
I cut open EVERY filter that I've used (and most of my families) and never had a Fram have a problem in over 30 plus years. In fact I've only had one filter with a problem and it was in the last year. A WIX.
Take care, Bill
#1303371 - 12/06/08 03:08 PM Re: Oil/Filter recommendation for 2007 Camry 2.4 [Re: Bill in Utah]
The Critic Offline
Loc: Walnut Creek, CA
You can get a 10 pack of the Toyota OE filters on eBay for around $40 shipped. As for the oil, I would use whatever 5W20 that is on sale.
Also, if you have not had the software update performed on your Camry, should take it in and have it done. The software update elminates any hesitation under light acceleration and allows for smoother acceleration. The software update is discussed in TSB 0068-08 (May 21, 2008) and is covered under warranty for 8/80k.
11 Prius - 129k - M1 EP 0w20/OE
07 Accord 2.4 - 111k - M1 5w20/FPS Filter
10 Altima 3.5 - 34k - M1 EP 5w30/FU
92 Previa - 160k - Chevron 5w30/Wix
#1303472 - 12/06/08 05:07 PM Re: Oil/Filter recommendation for 2007 Camry 2.4 [Re: The Critic]
dilettantologist Offline
Loc: CA
I just picked up some Toyota OEM filters from the dealer @$3.25 each. That's hard to beat.
All the local dealers are running 15 to 20% off their parts right now. You might give the stealers a visit.
#1303485 - 12/06/08 05:15 PM Re: Oil/Filter recommendation for 2007 Camry 2.4 [Re: dilettantologist]
ChiTDI Offline
Loc: Chicago IL
OEM filters for $3.25, and 4 quarts of a good 5w20 could total as little as $15. I'd go with YB or Motorcraft personally.
#1303527 - 12/06/08 05:47 PM Re: Oil/Filter recommendation for 2007 Camry 2.4 [Re: ChiTDI]
PT1 Offline
Loc: near the mistake
If you are still under warranty I would use a factory filter and keep receipts.
Oils well that ends well...
#1303732 - 12/06/08 09:40 PM Re: Oil/Filter recommendation for 2007 Camry 2.4 [Re: PT1]
Michelob Offline
Loc: Ma USA
My local Wal Mart does not carry Havoline 5W20 and another place that carries Havoline does not carry the 5W20 either. Advance Auto carries a small amount it was $3.39 a quart and I actually bought some today for my Civic but realized it was 40 cents more a quart than Motocraft Synthetic Blend 5W20 was at Wal Mart. My first oil change back in August I used the Motocraft with a PureOne filter and have had no complaints at all and no noises that should not be there so I went to Wal Mart later and bought the Motocraft and put it in again with a new PureOne and will return the Havoline tomorrow. My local WalMart also does not carry Purolator filters either. The Motocraft is cheaper than Pennzoil at Walmart although there is a deal right now for 5qts of Pennzoil and a Fram filter at Advance Auto for $12.98 or something like that after a $5.00 mail in rebate but 5qts of Motocraft at WalMart is $12.50 but no oil filter. I don!t want a Fram anyway. Pep Boys has Shell oil and a filter for $9.99. Without doing UOAS I will be doing 5000 mile changes anyway.
2003 Ford F150 XLT 2WD regular cab.
2014 Kia Fort EX
#1303773 - 12/06/08 10:42 PM Re: Oil/Filter recommendation for 2007 Camry 2.4 [Re: Bill in Utah]
Whimsey Offline
Loc: The Garden State
Take care, Bill
Holy poop! In my Ford's Fram caused dry start problems constantly. This was in OHV and OHC engines using the factory spec'd oil. Once I changed to Motorcraft oil filters the problem went away. I have to say that I used a Napa Gold oil filter on my 1996 Contour, OHC engine,the and I've great success with it. There is no dry start noise with it like with the Fram oil filters.
Whimsey
#1303855 - 12/07/08 12:27 AM Re: Oil/Filter recommendation for 2007 Camry 2.4 [Re: Whimsey]
tsmay51 Offline
Loc: Roanoke, Texas
I have ran Mobil 5000, Castrol GTX, and Pennzoil in our camry. All have performed well but I will have to say it seems to run a bit smoother with Pennzoil than the other two.I am not a fram filter fan but that's all I could get last time. I have not noticed any ill effects with the fram filter.
2015 Toyota Tacoma V6
2009 Mazda CX-9 V6
2001 Honda CRV 4 cylinder
Page 1 of 2 1 2 >
