Honda GX35 question
by dirtydannyd
07/25/16 02:08 AM
Need advices for oil filter inspection
by ST2008
07/25/16 01:45 AM
Supertech- ST3387- Virgin cut open
by FordBroncoVWJeta
07/25/16 01:06 AM
Clean battery with garden hose?
by SavagePatch
07/24/16 11:55 PM
Toyota 5w20 blend?
by researcher
07/24/16 11:36 PM
Smoked some baby backs today
by BeerCan
07/24/16 10:28 PM
Ford FWD axle replacement
by 2009Edge
07/24/16 10:27 PM
Saturn ac compressor
by spasm3
07/24/16 10:20 PM
looking for spray guns - analysis paralysis
by tomcat27
07/24/16 10:18 PM
WIX 51372 ADBV Failure
by WellOiled
07/24/16 10:11 PM
moly + engine coatings
by benjy
07/24/16 09:57 PM
Worth the upgrade?
by daves87rs
07/24/16 09:47 PM
NJ1911, SneakyTacos, DaveD, 8o8is, Texasdude74
58584 Registered Users
30 registered (bourne, alcyon, 1foxracing, car51, 182RG, 7 invisible), 798 Guests and 17 Spiders online.
58584 Members
66 Forums
252221 Topics
#1288282 - 11/20/08 07:52 AM Anti drain back valve failure
dirtydave Offline
Loc: michigan
A few weeks ago I changed my oil on my 99 Chevy Astro with 98000 miles. I start engine and everything is fine. Than a couple nights later I go to leave from my inlaws and the outside temp is 35 deg. and I hear this knocking on startup. My oil pressure is good and the knock goes away after 10-20 sec. The next couple days same thing happens. I'am thinking its the wrist pins or something else. Well I decided to start easy and change the filter again thinking it could probley be the oil filter. Well guess what? It is. Old filter was a ac delco 52 and new one is a wix. Problem solved.
#1288305 - 11/20/08 08:18 AM Re: Anti drain back valve failure [Re: dirtydave]
paul246 Offline
Loc: Canada
Glad you figured it out quickly and inexpensively, also thanks for passing it along.
#1288338 - 11/20/08 08:53 AM Re: Anti drain back valve failure [Re: paul246]
rg200amp Offline
Loc: Phila,PA
If only all car problems could be fixed that easy!!!
// 2013 Subaru WRX //
SOLD:
-11 Volkswagen Jetta
-04 Lincoln LS
-01 Ford F250
-04 Mazda Rx-8
-97 Jeep Wrangler
-97 BMW M3
-97 Nissan Maxima
#1288497 - 11/20/08 11:55 AM Re: Anti drain back valve failure [Re: rg200amp]
benjamming Offline
Loc: northern Alabama
any pics?
#1289471 - 11/21/08 10:00 AM Re: Anti drain back valve failure [Re: benjamming]
glenncof Offline
Loc: Northern California
 Originally Posted By: benjamming
any pics?
of what ?
#1289624 - 11/21/08 01:04 PM Re: Anti drain back valve failure [Re: glenncof]
dirtydave Offline
Loc: michigan
no pics. It was late at night, tossed in garbage and forgot about it.
#1289638 - 11/21/08 01:15 PM Re: Anti drain back valve failure [Re: glenncof]
benjamming Offline
any pics?
of what ?
... of the ADB valve failure. Was the failure anything obvious one might see prior to installing?
#1290304 - 11/22/08 07:23 AM Re: Anti drain back valve failure [Re: benjamming]
widman Offline
Loc: Bolivia
I cut open 11 filters a week or so ago and will soon be posting some pics, but I was amazed at the way MOST of the anti-drain valves were designed (or not designed, just thrown in). Little thin rubber flaps, in one case against the bent fingers in the holes that held the base plate together.
Richard's Car Restorations
#1291110 - 11/23/08 07:52 AM Re: Anti drain back valve failure [Re: widman]
PT1 Offline
Loc: near the mistake
I use wix filters in everything. I use the bitog sponsor http://www.fleetfilter.com check it out as the prices are very good.
Oils well that ends well...
#1291931 - 11/24/08 07:11 AM Re: Anti drain back valve failure [Re: PT1]
daman Offline
Loc: Bad Axe, MI
Boy thats funny,thats all i run is a PF-52 and NG/WIX cross and cut
open there the EXACT same filter,carbon copy,both have the
silicon ADBV
unless you used a Mexico made 52,witch is a cheap pice of chit..
"Always"....Mobil 1
Current fill: AFE 0w30
