Is Royal Purple API-licensed dexos1-licensed?
by barlowc
3 minutes 45 seconds ago
Supertech High Mileage ATF
by TechnoLoGs
23 minutes 29 seconds ago
WTB: 1 or 2 quarts of Honda Z1 atf
by vinu_neuro
29 minutes 47 seconds ago
12' Ford Super Crew 3.5 Ecoboost - what oil ??
by Boost00
39 minutes 16 seconds ago
2000 lincoln conti floorboards flooding ?????
by OtisBlkR1
Today at 07:59 PM
Mityvac 7400
by 2James1
Today at 07:28 PM
Staining a new fence
by bustednutz
Today at 07:23 PM
Bad luck with GM 3800 motor!
by ZZman
Today at 07:06 PM
Greyhound Chonda Cold Start
by SEMI_287
Today at 06:39 PM
Saw a big dog tic on my pillow
by TechnoLoGs
Today at 06:24 PM
AAP job question...
by Tuffy1760
Today at 06:15 PM
Castrol Edge 10W-30 $4 at Autozone
by mattwithcats
Today at 05:38 PM
gl10, ufomorme, krz, colburnr, richard8988
45901 Registered Users
148 registered (01rangerxl, 99Saturn, -SyN-, 2010_FX4, 95busa, afoulk, 12 invisible), 1575 Guests and 251 Spiders online.
45901 Members
64 Forums
195325 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
Page 1 of 2 1 2 >
#1288930 - 11/20/08 06:16 PM Rotella or Delvac or Delo or Tection?
kartracer61 Offline
Loc: TX
The local WallyWorld stocks the following 15w-40 HDEO oil:
Rotella
Delvac 1300 Super
Delo 400 LE
Tection Extra
They are all the same price ($11.77), is there one of them that is clearly superior to the others or are they all about the same?
Thanks alot!
#1288956 - 11/20/08 06:35 PM Re: Rotella or Delvac or Delo or Tection? [Re: kartracer61]
1040 WreckerMan Offline
Loc: Western Washington
My first choice would be Delo and then Delvac. The Delvac is a good oil and is on par with Delo, I'm just partial to Delo for a dino oil as it has always been a great performer.
What are you going to use the oil in and under what conditions? Each of those oils is a bit different and application may or may not have an affect on their performance.
HP = I'm spending money I don't have, on things I don't need to impress people I don't know!
#1288966 - 11/20/08 06:41 PM Re: Rotella or Delvac or Delo or Tection? [Re: kartracer61]
kartracer61 Offline
Loc: TX
I posted this in another thread I just started, I don't mean to double-post:
Gas engines:
10w-30 in 2001 GMC 6.0 liter
10w-30 in 1995 Chevy 4.3 liter
SAE 30 (with bottle of ZDDPlus) in 1974 Chevy 454ci
SAE 30 in 22hp Briggs V-Twin riding mower
SAE 30 in 6hp Briggs push mower
I'm also using SAE 30 (with bottle of ZDDPlus) in my 2004 diesel tractor.
Thanks
#1288977 - 11/20/08 06:55 PM Re: Rotella or Delvac or Delo or Tection? [Re: kartracer61]
JHZR2 Offline
Loc: New Jersey
delvac isnt quite on par with delo 400 LE according to the latest tests and quals (accordint to chevron). Delvac is the closest to delo in terms of performance (with rotella lagging behind in third), but delo is far ahead of both in many/most tests.
Delo 400 LE is a high quality oil.
#1288987 - 11/20/08 07:04 PM Re: Rotella or Delvac or Delo or Tection? [Re: 1040 WreckerMan]
D-Roc Offline
Loc: CFB Gagetown, New Brunswick
To the original poster, as far as a choice between all three of these, if you are unsure, just close your eyes and point...they are all good.
My question is actually regarding 1040Wreckerman's comment about how each oil is different. I know they are all different, but I'm just curious as to how each would perform best in what situation/usage/conditions? What would you use each for?
What's her name, does she lie?Does she know that know that you'll never treat her right You act like you just saw a ghost,I caught you, and now I know
#1288994 - 11/20/08 07:09 PM Re: Rotella or Delvac or Delo or Tection? [Re: D-Roc]
HTSS_TR Offline
Loc: Irvine, CA
Delo 400 LE is a good HDEO oil, specially when you can buy a case of 6 gallons with $15 off coupon at Costco right now.
'94 LS400 300,000+ miles
'00 E430 140,000+ miles
'04 S2000 40,000+ miles
#1288997 - 11/20/08 07:11 PM Re: Rotella or Delvac or Delo or Tection? [Re: JHZR2]
D-Roc Offline
Do you believe that Delo is ahead of the others in regards to the latest tests, or do you feel that Chevron is just blowing their own horn?
I have also been following your comments lately regarding Chevron Delo, and was curious as to where you got your info from...I can't recall specifically, but did you say previously you attended one of their information seminars?
#1288998 - 11/20/08 07:13 PM Re: Rotella or Delvac or Delo or Tection? [Re: D-Roc]
OVERKILL Offline
Loc: Ontario, Canada
Yes, would be sort of like me attending an Exxon-Mobil conference and then stating their testing puts them ahead of Chevron in almost every test....
If that is the case.
Network Engineer
89 Town Car
00 BMW 328i
02 Expedition
01 BMW ///M5
#1289016 - 11/20/08 07:38 PM Re: Rotella or Delvac or Delo or Tection? [Re: D-Roc]
Well each oil has a bit different base stock and additive package. While they are all good oils they are not the same. I have found is that Delo and Delvac tends to hold up better in HEUI engines than Rotella or Tection (some examples of HEUI engines would be the 7.3/6.0 PowerStroke 3126 CAT,etc.). With 07+ active after-treatment engines that tend to run very high oil temps and significantly increase soot loads Delvac and Delo again out perform the other two choices.
I actually bought a BUNCH of CI-4 Tection on sale and ran it in several of my older big block gas trucks. Since the engines don't place any more heat load on the oil than it would in a diesel the lower quality base oil really isn't a problem. The oil also has plenty of AW/EP additives that an industrial gas engine needs (particularly when the basic technology is 30+ years old). Price on this oil is good and it's a terrific oil for this application. Also worked well in many of our small diesel tractors for similar reasons.
Now, for a 12v 6b or 6c or an L10 the Rotella would probably perform just as well as Tection or Delo since the application is less demanding. An L10 is pretty easy on the oil from a temperature, shear and soot standpoint so any "good" quality oil wil work fine in it.
This is assuming that the engines are in good working order.
Just like a PM program, looking at your particular needs and picking a lube that is best suited to that application makes all the difference in the world IMO.
#1289022 - 11/20/08 07:42 PM Re: Rotella or Delvac or Delo or Tection? [Re: kartracer61]
Gas engines:
Thanks
I'd run any one of the diesel oils listed for everything but the 6.0 and 4.3. In those I think I'd run a good quality GPIII or a syn oil in a 5wxx weight. But again, it depends on how you use the vehicles.
For the old big block and the briggs the 15w40 will work great. Out of your list I think Delo and Delvac use a bit better base oil than Tection and Rotella.
#1289027 - 11/20/08 07:44 PM Re: Rotella or Delvac or Delo or Tection? [Re: 1040 WreckerMan]
D-Roc Offline
Interesting points...I worked at a CAT dealer and one of the problems they always had was the HEUI equipped engines. Funny thing was no one really took the time to consider all the angles as to why they had issues with them...
Good to hear some real world results, helps others out when making informed choices. \:\!
#1289075 - 11/20/08 08:30 PM Re: Rotella or Delvac or Delo or Tection? [Re: JHZR2]
OilGuy Offline
Loc: USA
Please do share your/Chevron's data/claims. Which areas of performance does Chevron claim superiority?
#1291869 - 11/24/08 04:57 AM Re: Rotella or Delvac or Delo or Tection? [Re: OilGuy]
dnewton3 Offline
Loc: Indianapolis, IN
I make a qualifying statement, and then a generalization.
First, the only way to truly know how well any lubricant will work with an engine is to do long term UOA studies. For most individuals, they either don't have the patience and money, or they are just not interested to that depth. If you own just one diesel truck or compact tractor, you're investment is high, but your ability to truly do a study that is fair and unbiased is difficult. It's very hard for a single person to play the field of oil contenders without bias due to the costs and time involved in well-constructed blind tests.
Overall, today's lubricants are well designed and manufactured. There is always the occasional example of some extreme where a person experienced either a huge success or gross failure, but the GREAT MASS OF CONSUMERS often see little to no difference in daily operation between brands.
If Delo, Delvac, Rotella, Tection Extra (and I'll throw in Premium Blue) were all on the shelf for the same price, I wouldn't buy any of them. I'd wait until one of them went on sale or had a rebate, and then I'd stock up like the oil-'ho I am, because I have great faith that they all will perform to my high standard with no issues, and I'll get a bargin along the way.
Edited by dnewton3 (11/24/08 05:00 AM)
Conventional oils vs. Synthetic oils isn't about which is "better"; it's about which lasts longer, in relation to cost. Any product can be over or under utilized.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#1292050 - 11/24/08 10:28 AM Re: Rotella or Delvac or Delo or Tection? [Re: OilGuy]
JHZR2 Offline
Loc: New Jersey
Ill see if I can pull up the technical presentation from the Chevron summit. Effectively Delo 400 LE outperformed delvac, rotella, tection, the 76 HDEO, and one other (sorry I forget the last one) on every major test/certification that was listed on the bottle. Many by a very large extent.
Rotella and delvac flip flopped for second best on the tests.
If I can pull up the presentation Ill post a link, otherwise Ill just try to give a better citation and source. Id think this is something that Chevron would want to show off...
#1318060 - 12/20/08 10:58 PM Re: Rotella or Delvac or Delo or Tection? [Re: JHZR2]
Ben99GT Offline
Loc: MS
My Dad's '02 7.3 PSD has always run the best on Delo. We tried Rotella T and Valoline Premium Blue for 2 oil changes each, and in both cases fuel mileage dropped .5-1 mpg and (less scientific) the engine just didn't sound as healthy.
7.3s love Delo
2001 F150 Supercrew
1991 Mustang LX notch
1999 Mustang GT
Page 1 of 2 1 2 >
