GM to test self-driving taxis
by xfactor9
05/06/16 01:09 AM
Resurfacing Brake Rotors
by The Critic
05/06/16 12:02 AM
Largest M1 filter for Jeep 4.0
by ARMY_Guy
05/05/16 10:50 PM
Mobil 1 or Castrol edge?
by sky06
05/05/16 09:48 PM
1 piece lug nut recommendations?
by dlundblad
05/05/16 09:07 PM
1996 Chrysler Coolant
by outoforder
05/05/16 09:02 PM
Hat Tip to RMEuropean
by sleddriver
05/05/16 08:54 PM
Toro OHV considered flat tappet type...
by Duffyjr
05/05/16 08:48 PM
Tire Rack now carries the Falken Azenis RT615k
by slacktide_bitog
05/05/16 07:30 PM
Walmart now carries Nokian tires
by slacktide_bitog
05/05/16 07:16 PM
Heater Core Leak?
by bprat318
05/05/16 06:54 PM
R2C air filters
by Srt20
05/05/16 05:55 PM
waldawg, Defcon, drivingaford, funkyheff, Ralph62
57814 Registered Users
21 registered (alcyon, Ducked, Doug Hillary, carlprop, 3 invisible), 0 Guests and 0 Spiders online.
57814 Members
66 Forums
248535 Topics
#1284522 - 11/16/08 11:26 AM Honda Snowblower Auger Gear Lube
Pete591 Offline
Loc: Michigan
I understand it can be drained but not sure.
Any info on what's in there and if it is a grease or oil and what type?
#1284526 - 11/16/08 11:30 AM Re: Honda Snowblower Auger Gear Lube [Re: Pete591]
c3po Offline
Loc: Maryland
I have a Honda Snowblower, I think you are talking about the Hydrostatic Transmission Fluid.
I have never drained mine out, might want to download service manual on the internet. How many hours are on that snowblower.
#1284531 - 11/16/08 11:36 AM Re: Honda Snowblower Auger Gear Lube [Re: c3po]
Pete591 Offline
Loc: Michigan
It has about 120 hrs on it.
I never changed the hydro-static oil.
There is a gear box that joins the impeller and auger with some type of lube in it. Wondering what is is and what to use to top it off or chagne it?
#1284565 - 11/16/08 12:13 PM Re: Honda Snowblower Auger Gear Lube [Re: Pete591]
[email protected] Offline
Loc: Michigan
On my Bolens, I refilled with amsoils 75/90 gear lube.. The old stuff was BLACK and about as consistent as tar.
'16 F150, 2.7EB
'16 F150, 2.7EB
Yes, I own 2 '16 F150s."Thanks Dad!" 1936-2015
97 FW Vista 278
T-4.3Gi 185hr&
4kw genset 17hr- T5
#1285984 - 11/17/08 09:07 PM Re: Honda Snowblower Auger Gear Lube [Re: [email protected]]
JTK Offline
Loc: Buffalo, NY
Lower end machines use grease for the auger drive gear case. Old school and high-end would use a gear oil. 75w90 would be a great choice.
Joel
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#1287655 - 11/19/08 03:32 PM Re: Honda Snowblower Auger Gear Lube [Re: JTK]
H2GURU Offline
Loc: Boston
Many Ariens use a 00 oil which is an amalgem of an aluminum looking paste combined with lighter oil in their NON cast iron drive boxes. Its only available from Ariens as I looked elsewhere w/o luck. If your gearcase is 2 pieces this is probably the lube you want. Put as much in as you can because you can't damage it with an overfill. Putting straight EP grease in there isn't a good idea.
#1288342 - 11/20/08 08:56 AM Re: Honda Snowblower Auger Gear Lube [Re: H2GURU]
JTK Offline
Loc: Buffalo, NY
H2- I have a similar looking grease in the little single speed gear drive trans on my Honda pushmower. I popped the bottom of the case off after years of use and that grease looked new yet.
Joel
#1288680 - 11/20/08 02:36 PM Re: Honda Snowblower Auger Gear Lube [Re: JTK]
TylerL Offline
Loc: Mishawaka, IN
That little auger gearbox on my Ariens blower looked like its lube was contaminated with water. I filled it with 80w-90.
