That's unfortunate...or maybe bypass filtration?
by linksep
06/27/16 02:24 AM
Over Oiling
by mjoekingz28
06/27/16 12:59 AM
Sweden Trials Electric Higway for Trucks
by Y_K
06/27/16 12:07 AM
17 yo deutsch filter?
by robo339
06/26/16 11:07 PM
Ford Focus wrecked
by tig1
06/26/16 10:13 PM
Valvoline Maxlife vs Supertech Synthetic vs QSED
by mazdamonky
06/26/16 09:56 PM
Lexus seats in a Camry
by Nick1994
06/26/16 09:52 PM
shop rechecking work after front end parts replace
by motor_oil_madman
06/26/16 09:50 PM
M1-EP vs vanilla M1
by Atomic
06/26/16 09:29 PM
Supertech Synthetic and Citgo
by RRLJR
06/26/16 09:28 PM
Gun Belt Wanted
by FirstNissan
06/26/16 08:24 PM
car wash soap for pressure washer
by Donald
06/26/16 08:16 PM
Josh_Westwood, Brogan, Superlatives, Ruturaj, derfderfgoose
58280 Registered Users
25 registered (car51, Brad_C, Axe Man, dino33, 2 invisible), 780 Guests and 11 Spiders online.
58280 Members
66 Forums
250856 Topics
Page 1 of 2 1 2 >
#1264166 - 10/23/08 08:24 AM Cartridge versus spin on
BTLew81 Offline
Loc: Illinois
Hi,
My 2007 Mazda3 2.3l has the cartridge filter on the bottom of the engine. Many folks I know have done the spin on conversion. It has crossed my mind, but for various reasons, I have not yet done it.
Any thoughts on this?
2016 VW Passat SE 1.8TSI
Reflex Silver/Black
Factory Fill
#1264170 - 10/23/08 08:33 AM Re: Cartridge versus spin on [Re: BTLew81]
JHZR2 Offline
Loc: New Jersey
I prefer cartridges. Less waste, and the can often be cleaner.
I especially prefer cartridges mounted on the top of the engines, which is quite smart, IMO.
#1264179 - 10/23/08 08:47 AM Re: Cartridge versus spin on [Re: JHZR2]
Eddie Offline
Loc: Florida, Cape Coral
My CX 7 has the same cartridge as the Mazda 3. The first time I changed it, I found it to be more of a hassle with the new O-rings and more manipulation required. After several changes, I now find it easer but, it still takes about 10 minutes longer to change than a spin-on. I do like the fact that it is considerably more environmentally friendly. I will not change over to a spin-on. I think we are not getting the full value as the cartridge costs about the same ( dealer cost or major brand). I pay about $5.25 for a Wix cartridge and $5.15 for a wix spin-on. The cartridge type alsos allows me to visually inspect the filter media for engine or filter problems, without the need to cut the canned filter apart.
CX5 Touring 2.5L :-)
#1264183 - 10/23/08 09:00 AM Re: Cartridge versus spin on [Re: Eddie]
BTLew81 Offline
Loc: Illinois
Good points. I've been using the Motorcraft filter, at WM, for about $3.50. For my 5k changes, it works well, and seems to hold up nicely.
Reflex Silver/Black
Factory Fill
#1264283 - 10/23/08 11:20 AM Re: Cartridge versus spin on [Re: BTLew81]
globey Offline
Loc: MS
I have the 2.3L in my Fusion and find the cartridge changes easy. I've done about five on my car since I've had it.
A time saver for me is not removing the small o-ring every time. I don't use the small plug, so why do I have to change that ring out every time?
Honestly, I like the cartridge for most of the reasons above. Less waste, I can view the filter and I have an abundance of quality filters that I got for low sale prices (K&N, Pure Ones, etc).
#1264653 - 10/23/08 08:46 PM Re: Cartridge versus spin on [Re: globey]
tom slick Offline
Loc: Central Coast, Calif.
I don't really see a benefit to switching to a cartridge. it will also void your warranty on the engine.
You get what you pay for...
So keep in mind how much you paid for this advice.
#1264730 - 10/23/08 10:10 PM Re: Cartridge versus spin on [Re: tom slick]
globey Offline
Loc: MS
I'm assuming you meant spin-on rather than cartridge. His Mazda/Ford 2.3 came with a cartridge filter.
I agree...stick with the cartridge.
#1264783 - 10/23/08 11:11 PM Re: Cartridge versus spin on [Re: globey]
tom slick Offline
oops, yeah I mean no advantage to a spin on.
#1264790 - 10/23/08 11:18 PM Re: Cartridge versus spin on [Re: tom slick]
labman Offline
Loc: Nothern USA
I like everything about the well placed cartridge filter on my Cavalier Ecotec except the filter price. I paid the dealer $8 for the first one. I picked up a Purlator one at at AAP recently for $2.50. I can change oil without ramps now.
#1265131 - 10/24/08 11:12 AM Re: Cartridge versus spin on [Re: labman]
kkreit01 Offline
Loc: Olathe, KS
^ If that were the case on the Fusion/Mazda, it wouldn't be bad either. However, the cartridge filter is located underneath. You first have to get out your 10mm wrench to remove some bolts for the plastic shield. You then have to locate your special cap filter wrench to remove the plactic cap. Upon loosening, quickly grab your pan, because oil starts dripping/pouring all over -- and on the main bottom engine shield. Before you put everything back on, you now have dirty oil all over the filter cap -- which you must clean off. This also assumes you didn't actually remove the oil filter plug (another source of potential metal-->plastic thread failure). I had my Fusion for 1.5 years, and never removed the oil filter drain plug. Make sure to grab your torque wrench, and set it to 20 ft-lbs before tightening the plastic cap.
Overall, "cartridge" was just a pain compared to any other vehicles I've owned (many). Had I kept the Fusion longer, I would have swapped to spin-on. Yes -- cartridge is better for the environment, and it's nice to be able to see the filter media. It's typically not more expensive, but to me, it's a pain. There's much more to clean, and more potential for problems (in this application).
2014 Dodge Durango Limited AWD 3.6: 5w20 PP/Napa Gold filter
2014 Ford Edge SEL FWD 3.5: Factory Fill
#1265247 - 10/24/08 01:48 PM Re: Cartridge versus spin on [Re: kkreit01]
globey Offline
Loc: MS
My 2.3L Fusion doesn't have a shield to remove.
^ You then have to locate your special cap filter wrench to remove the plactic cap.
Yes, it's called getting the tools before you begin a job. I don't see how that's a difficult task. I suppose getting a funnel is difficult too?
No shield.
So, don't overtighten? Check...you still run the risk of overtightening a metal cannister. Then, if you can't get the spin on off because you tightened it too much, you have to "locate" an oil filter wrench. Too many needed steps.
Honestly, it's not as hard as people make it out...plus the cartridge is on the bottom, in this case, and none of my engine components get dirtied up from the oil. Remove cap/cartridge, replace cartridge/o-ring, remove drain plug. Put cap on, replace drain plug and fill. Does it take a few extra minutes? Maybe...but I've done about five of them and I have it down pretty good. In the end, the benefits outweigh the costs...at least to me.
#1266460 - 10/25/08 10:54 PM Re: Cartridge versus spin on [Re: globey]
ekpolk Offline
The Regenerator
Loc: Pensacola FL
I thought cartridges would be a nice idea, until I changed the one on my wife's Avalon. I'd love to meet the genius who decided to stick it on the bottom of the engine. Two caps, two sets of O-rings, and you still have to be on your back anyway. I'd much, much rather have a spin-on for this car, or have it mounted up top like some other designs.
Labman: great to see you back, don't be such a stranger!
09 Camry Hybrid, Black (M1 5w-20, std flavor).
07 Avalon XLS, Cassis Pearl (GC 0w-30).
04 Prius, Black (GC -- 0w-30).
#1266472 - 10/25/08 11:14 PM Re: Cartridge versus spin on [Re: ekpolk]
Smokescreen Offline
Loc: Alberta, Canada
so if the spin ons had an anti drain-back valve do these cartridge setups have a similar internal setup that never wears out? I have an 09 Corolla with a cartridge, just wondering how it all works.
09 Corolla 1.8L-300Kkms(187Kmi)-PP,Denso
05 LeSabre 3.8L-235Kkms(146Kmi)-F1,Delco
03 Sierra 6.0L-194Kkms(121Kmi)-F1,Delco
All with mpg > EPA
#1266586 - 10/26/08 08:43 AM Re: Cartridge versus spin on [Re: Smokescreen]
IndyFan Offline
Loc: Danville, Indiana
I understand that GM engines all have anti-drainback built-in, even in the spin-on designs. I could be wrong, but I remember reading this somewhere.
15 Ford Transit 3.5 Ecoboost 34k
08 Jeep Wrangler 3.8 101k
01 Ford F150 Crew 5.4 63k
99 Mercedes-Benz E430 Sport 66k
#1267423 - 10/27/08 10:37 AM Re: Cartridge versus spin on [Re: globey]
kkreit01 Offline
Loc: Olathe, KS
No shield.
You're right -- it's not that hard. It was actually easier than I expected after reading all the horror stories. For me, it was just a pain compared to spin-on. Yes, a pain for selfesh reasons. I never had any issues, and I used all the correct tools. What year is your Fusion? Did you buy it new? I thought they all had a shield on the bottom? It would be much better without it, but I assuming it helps for airflow -- gas mileage.
Page 1 of 2 1 2 >
