Delo 400?
by Sealbilly
07/25/16 07:17 PM
Noob question about chain maintenance
by JeepWJ19
07/25/16 07:00 PM
Rural King Full Synthetic Oil Sale...
by AnthemBassMan
07/25/16 05:16 PM
Mobil 1 EP oil filter - Cross Reference
by Kung_Faux
07/25/16 05:08 PM
sears SYWR $30 off $30 surprise
by eljefino
07/25/16 05:03 PM
Does BG 44K work?
by j_mac
07/25/16 04:56 PM
First CEL on the SRT-8
by OVERKILL
07/25/16 04:00 PM
How wide are the error bars on Seq IIIG tests?
by bulwnkl
07/25/16 03:15 PM
Who watches the oil co's?
by Camprunner
07/25/16 02:44 PM
Magnetec "Edged" out?
by ARCOgraphite
07/25/16 02:34 PM
Let's talk RUM
by car51
07/25/16 02:23 PM
Any .257 Roberts Reloaders On The Site?
by 2015_PSD
07/25/16 01:18 PM
dewpoint, Luuey, Eskimio, Jngoose76, Ken_Clifton
58593 Registered Users
95 registered (alanwayne1908, aquariuscsm, AIRJAC3, Anakin, 182RG, 7 invisible), 1948 Guests and 17 Spiders online.
58593 Members
66 Forums
252242 Topics
Page 1 of 2 1 2 >
#1239693 - 09/20/08 12:00 PM What exactly do the VW specs mean?
saaber1 Offline
Loc: Pacnw
On some forums, I have heard a lot of people talking about how if an oil meets VW 502 specs that it is "the best" in terms of protection vs. any oil that doesn't meet that spec.
Also, they talk a lot about the "hierarchy" and that a 503 oil is better because the number is higher and therefore a newer and better spec.
I believe both statements that are so often thrown out as fact are wrong, but I don't really know what exact factors the VW spec. considers. Does any body have a link to the actual test? I assume the following factors are part of the VW spec.? Does anyone know how much anti-wear/protection weighs vs the other factors?
1) mpg
2) emissions
3) starting viscosity (start of test I mean)
4) ending viscosity (end of test I mean)
5) anti wear/protection
6) detergency
7) other?
It just doesn't seem right to talk about VW spec oils as the holy grail for protection when instead I think the specs are trying to balance many factors, one of which is anti-wear/protection.
Edited by saaber1 (09/20/08 12:11 PM)
"when 5W30 is cold, ...the oil is 35 weight (5+30),...20 w 50 starts at 70 and warms up to 50"
- Kyle, auto mechanic & VP Speedline Motorsports, INTL
#1239742 - 09/20/08 02:11 PM Re: What exactly do the VW specs mean? [Re: saaber1]
TeeDub Offline
Loc: NY
The only thing the VW 502.00 spec means is that the oil's been tested in the 2.0L, 115 Hp VW gas engine. There are specific limits for valvetrain wear, oil deposits, oil consumption, viscosity increase and TBN retention. As I recall the test runs for approx 200 hrs and no makeup oil is allowed.
VW 505.00 is similar bit uses the old 1.6L. IDI, VW diesel engine.
NYSOFMIND
#1239750 - 09/20/08 02:30 PM Re: What exactly do the VW specs mean? [Re: TeeDub]
jpr Offline
Loc: San Diego, CA
VW 500.00 (officially invalid) Oil for naturally aspirated gasoline and diesel engines with normal fill without extended interval (15000 km 1 year), HTHS viscosity min. 3.5 mPa-s, ACEA A3 + additional VW tests
VW 501.01 (officially invalid) Oil for naturally aspirated gasoline and diesel engines without extended oil change interval (15000 km 1 year), HTHS viscosity min. 3.5 mPa-s, ACEA A2 + additional VW tests
VW 502.00 Oil for high performance gasoline engines without extended oil fill change interval (15000 km 1 year), HTHS viscosity min. 3.5 mPa-s, ACEA A3 + additional VW tests
VW 503.00 Oil for gasoline engines with extended oil fill change interval (30000 km 2 years), HTHS viscosity 2.9 - 3.4 mPa-s, ACEA A3 + additional VW tests
VW 503.01 Oil for AUDI turbo-gasoline engines with extended oil fill change interval and Volkswagen W8 and W12 engines (30000 km 2 years), HTHS viscosity min. 3.5 mPa-s, ACEA A3 + additional VW tests
VW 504.00 For Euro IV gasoline engines with extended oil fill change interval (30000 km 2 years) HTHS viscosity min. 3.5 mPa-s, ACEA A3 + additional VW tests, 5W-30 only, mid-SAPS
VW 505.00 Oil for diesel engines without extended oil fill change interval (15000 km 1 year), HTHS viscosity min. 3.5 mPa-s, ACEA B3 + additional VW tests
VW 507.00 For Euro IV diesel engines with extended oil fill change interval (30000 km 2 years) HTHS viscosity min. 3.5 mPa-s, ACEA B4-04 + additional VW tests, 5W-30 only, mid-SAPS
#1242664 - 09/24/08 06:56 PM Re: What exactly do the VW specs mean? [Re: jpr]
Doug Hillary Offline
Loc: Airlie Beach Australia
Hi,
jpr - VW's Test protocols are outcome specific and the relevant ACEA Quality standard is typically the starting point. That is one reason why ACEA was formed
Some of VW's Test protocols may also involve VW's component suppliers for such things as cam chains and gears, camshaft treatments, actuators (especially valve train), pistons, ring packs and even the supplier of turbochargers, superchargers and perhaps the block/heads and the like. These people may work with VW to devise the Test protocols and seek outcomes to substantiate Warranty provisions and the like
Much of the testing will be done using very sophistocated wear measurement practices such as. For the 506.01 protocol a 1000hr radionucleide test was devised and waer measurement taken hourly in nanometres - one millionth of a mm!
It is unwise IMHO to discount the engine makers tests. They will be the most comprehensive needed before the end user's real world - in day to day use operation
VW's lubricant supplier (currently Castrol) works on field testing outcomes and typically have large fleets of vehicles substantiating the Lab. results in real world operations
Many of these vehicles are placed in used where specific use occurs with normal drivers - high speed motorway, in town and at the extremes of temperature and etc
Regards
Doug
#1242733 - 09/24/08 08:21 PM Re: What exactly do the VW specs mean? [Re: Doug Hillary]
jpr Offline
Loc: San Diego, CA
I was too lazy to upload it before, but here's some slightly dated info from Motul on the VW test requirements -
I totally agree with you on the value of engine maker's testing.
#1243828 - 09/26/08 12:17 PM Re: What exactly do the VW specs mean? [Re: jpr]
ym42 Offline
Loc: Cherry Hill, NJ
Seems like the point with European specs is not how to maintain your engine for the least amount of money but how to save the natural resources, at any cost. I mean do you think there is any point in keeping the oil for 20000 miles inside the engine apart of conservation? Oil is cheap here is USA, so change more often...
#1243851 - 09/26/08 01:08 PM Re: What exactly do the VW specs mean? [Re: ym42]
saaber1 Offline
Loc: Pacnw
Or maybe more accurately, how to achieve maximum marketing success by showing how green-friendly your cars are. Or some cars like Porsche use the 20,000 mile OCI as a marketing tool to show how infrequently the cars need to be serviced.
#1245384 - 09/28/08 03:39 PM Re: What exactly do the VW specs mean? [Re: jpr]
UG_Passat Offline
Loc: NJ
quick correctionss:
503.00 & 503.01 = variable service intervals (up to 30,000 km)
504 & 507 are suitable for both variable and fixed service intervals.
of course, there are 505.01, 506.00 and 506.01 for diesels also.
#1254711 - 10/10/08 07:58 PM Re: What exactly do the VW specs mean? [Re: jpr]
milehighassassin Offline
Loc: Fort Collins & Vail, CO
505.00 is not for ALL diesels. The PD Motor (2004-2006)requires 505.01 or better. So 507 would be fine, their oils are backwards compatible.
#1255877 - 10/12/08 03:36 PM Re: What exactly do the VW specs mean? [Re: milehighassassin]
glenncof Offline
Loc: Northern California
saaber1,
You can find lots of info related to VW testing. Here is one test lab on the T4 sequence: http://www.swri.org/4org/d08/global/volkswgn/default.htm
"Better" or "best" is relative. First you need to evaluate what the OEM testing means, then determine if it is relevant to yr app and how much so, and then evaluate other items like price/availability/OCI.
Generally I find meeting OEM spec's is "better to have" then not have. But having an OEM spec does not mean it's "better", for instance...testing cost money...if the market for the oil is perceived to be small ...why test ?
#1256326 - 10/13/08 08:51 AM Re: What exactly do the VW specs mean? [Re: glenncof]
1sttruck Offline
Loc: Camas, WA
"Oil is cheap here is USA, so change more often... "
Or oil needs to be changed more often in the US because it's cheap.....
#1257911 - 10/15/08 01:30 PM Re: What exactly do the VW specs mean? [Re: saaber1]
Volvohead Offline
Loc: SE Pa
They mean we can't use any of our existing oil every time we get a new VW.
We've got a new Sportwagen TDI coming in next month (got the VIN), which is a 507.00 engine. So despite having 100+ quarts of top shelf oils on hand (including GC, RL, RTS and Schaeffers), it's back to the VW dealer to buy a case of "507".
#1257997 - 10/15/08 03:14 PM Re: What exactly do the VW specs mean? [Re: Volvohead]
moribundman Offline
In your case, you really ought to choose your new car based on the oil you have in stock.
#1258259 - 10/15/08 08:21 PM Re: What exactly do the VW specs mean? [Re: moribundman]
firemachine69 Offline
Loc: Sudbury, ON, Canada
And people wonder why I mock VW...
I have a very bad mem... What were we talking about again?
#1258506 - 10/16/08 05:24 AM Re: What exactly do the VW specs mean? [Re: firemachine69]
lars11 Offline
Loc: Sweden
Well, the porsche intervals are not odd here in europe, its more like standard to require 20-30kkm or two years OCI for normal conditions. Often drivetrain warranties are valid for 100-120kkm.
I would like to know the average car life in years and km for US and Euro vehicles.
In spite of the longer intervals, I seldom hear about shot engines here. How long do you drive a car?
Page 1 of 2 1 2 >
