I'm planning to do the transmission, differential and transfer case fluid change on our '06 Honda Pilot EX 4WD.
I am having a hard time finding the correct fluid type for the transfer case as Honda does not sell the genuine stuff. On various forums, I am reading people using GL-5, GL-4, 75W-90 and 80w-90 fluid. When I look at the Amsoil website, it lists the following:
Transfer Case,.....GL-4
Above 0°C......90
Synthetic Manual Transmission and Transaxle Gear Lube 75W-90
Below 0°C......80W-90
Transfer Case,.....GL-5
Above 0°C......90
SAE 80W-90 Synthetic Gear Lube
Severe Gear 75W-90
SAE 75W-90 Synthetic Gear Lube
Severe Gear 75W-90
Which should I use?
Thanks
Above 0°C......90
Above 0°C......90
Severe Gear 75W-90
Severe Gear 75W-90
Which should I use?
Thanks
