Keep it simple.
by JustinH
05/06/16 03:28 PM
Pennzoil Ultra Platinum, 5W-30, 5k OCI, 20k total
by Joshua_Skinner
05/06/16 02:26 PM
Amsoil 75w90, 45K, 04 Chevy Tahoe
by dhellman12
05/06/16 02:09 PM
What happened to this kind of oil change?
by OneEyeJack
05/06/16 01:44 PM
OH! OH! Gas/Diesel mixup
by azjake
05/06/16 01:09 PM
VOA Pennzoil Platinum Euro 5w40 - SN
by agpatel
05/06/16 12:36 PM
VOA Liqui Moly Leichtlauf High Tech 5w40
by agpatel
05/06/16 12:30 PM
VOA Castrol Edge with Ti - 0w40 - SN - Euro Form
by agpatel
05/06/16 12:27 PM
Magnatec 5w30 - Push Mower
by SavagePatch
05/06/16 11:31 AM
RAM 1500 EcoDiesel filter
by pb379
05/06/16 09:14 AM
Motul 8100 X-Cess 5W/40 11,568Miles BMW335i
by strongmad
05/06/16 08:52 AM
Lawn Tractor Utility Upgrade
by bigdreama
05/06/16 08:50 AM
waldawg, Defcon, drivingaford, funkyheff, Ralph62
57814 Registered Users
96 registered (agpatel, 69GTX, 137_Trenton, 2010Civic, 09_GXP, 12 invisible), 1 Guest and 0 Spiders online.
57814 Members
66 Forums
248551 Topics
#1234028 - 09/11/08 12:14 PM Dino 5w20 good enough for Canadian winter weather?
byez Offline
Loc: Canada,North America,Western H...
I own a new 5.7 Tundra with a 7.5 L oil capacity. Warranty still in tact and I plan on doing my own oil changes and documenting everything. Manual specs 5w20 but prefers 0w20 at 5k intervals (8 kilometers).
Just wondering if you were me and you planned on keeping the vehicle for a long time.Would you rather use a dino 5w20 or synthetic 0w20? I do plan on taking lots of snowboarding trips to the mountains and here in Edmonton it does occasionally dip into the -30 Celsius range.
#1234035 - 09/11/08 12:22 PM Re: Dino 5w20 good enough for Canadian winter weather? [Re: byez]
Quest Offline
Loc: beaver land EH?
in terms of semantics, there's no such thing called "dino" 5W20 for in order to meet ILSAC GF-4/API SM gradings, all 5W20 are blend of GpII and beyond.
most 0W20 that I know of are at least syn blend or beyond.
Q.
I'm running MCraft 5W20 in my fit and I'm intended to do so for at lesat 20+yrs (until I decided to move on with my life and/or sell it off for whatever reasons).
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#1234036 - 09/11/08 12:23 PM Re: Dino 5w20 good enough for Canadian winter weather? [Re: byez]
double vanos Offline
Loc: Bisbee, Arizona
I think 0w20 Mobil 1 would be ideal for that job - excellent pour point and easily able to tackle the lenghth of your OCI's.
I know Bill in Utah can expound on dino oils in cold climates better than me because the coldest it gets in Houston is maybe 30 degrees F.
Cheers!
Svetlana Kapanina is harder core than Sabine Schmitz.
www.kapanina.com
#1234054 - 09/11/08 12:44 PM Re: Dino 5w20 good enough for Canadian winter weather? [Re: double vanos]
Pesca Offline
Loc: Montreal, Quebec in Canada
Is the Tundra parked in a garage during the nights?
Does it have a blockheater?
Depending of the answers, that could change the recommandations. Is it that cold overthere? I thought it would be more in the -15 -20C range.
If you have one of the above, I think a thin dino or synblend 5W20 oil will be good enough until you are out of warranty as I said in the Corolla 09 thread.
Still my 2.2 CAN cents, 1.5 euro cents.
2009 BMW 328Xdrive - BC 0w-40 with Mann filter
2002 Miata LS - PP 5w-20 with Amsoil filter
#1234085 - 09/11/08 01:37 PM Re: Dino 5w20 good enough for Canadian winter weather? [Re: Pesca]
byez Offline
It is parked outside and it does have a block heater which I use on the very cold days.
It can get that cold over here, but -15 -20 is more typical with the windchill.
#1234106 - 09/11/08 02:14 PM Re: Dino 5w20 good enough for Canadian winter weather? [Re: byez]
Pesca Offline
My 2 cents are still on a good dino or a synblend. Check the manufacturer data sheets for low CSC and MRV (the Petrocanada oils are quite impressive). I don't see the absolute need of a synthetic oil, still too expensive for 5 Kmiles.
The blockheater will help for the rough mornings to be back in more agreable territories.
When you will be able to extend your OCIs, you will have the double benefits of using the 0W20 oil.
#1234120 - 09/11/08 02:34 PM Re: Dino 5w20 good enough for Canadian winter weather? [Re: Pesca]
byez Offline
I see that the Petro Canada 5w20 outperforms Pennzoil 5w20 in ccs & mrv. So where do I find it?
#1234127 - 09/11/08 02:42 PM Re: Dino 5w20 good enough for Canadian winter weather? [Re: byez]
addyguy Offline
Loc: Canada
Either at PC gas stations (expensive), or at PC bulk lube depots (have to buy quantity).
If you don't change the oil yourself, there are a few OC franchises that use PC oil - 'Oil Changers' is one of them.
2003 Mazda Tribute LX V-6, 196,850 miles...DEAD.
MM F1 5W-20 conventional + Bardahl + top-offs.
MM MPH2 filter.
#1234151 - 09/11/08 03:07 PM Re: Dino 5w20 good enough for Canadian winter weat [Re: addyguy]
sunfire Offline
Loc: Ca, US
The additives and VII in dinos wear out quicker than synthetics in extreme hot and cold conditions. That might be something to consider.
Edited by sunfire (09/11/08 03:13 PM)
2005 Toyota Corolla LE | 65,000 | PYB 5W-30
#1234217 - 09/11/08 04:58 PM Re: Dino 5w20 good enough for Canadian winter weat [Re: sunfire]
Drivebelt Offline
Loc: Alberta
Hey, a fellow Edmontonian.
You should have no problem running a 5W-20 in the winters here. I run 5W-30 conventionals year round in a vehicle that sits outside here in Edmonton. No problem down to -30C, although when it gets in the low -30C's, cranking gets a little sluggish.
5W oils are rated at -35C for cold MRV pumpability (and they are usually well below the specification limit). That is about how low I am comfortable with 5W oils. If it regularly hit -40C (like Ft. McMurray) in the winter, then I would probably be using a 0W oil, but here in Edmonton, I think 5W oils are fine.
5W-20's are also generally blended to a little lower CCS and MRV (cold specifications) than the 5W-30 oils, so 5W-20's should be a little better in the winter than the 5W-30's I use.
#1234224 - 09/11/08 05:18 PM Re: Dino 5w20 good enough for Canadian winter weat [Re: Drivebelt]
eddiedz Offline
Loc: Saint John, NB
i'd say go full synthetic.. :) it'll give you the best pumpability for cold winters. here in new brunswick im going to use dino this winter but its only cause im going to run auto rx in it to clean it (then dino again to rinse it) i plan on driving down to maine (1hr drive) more then once too :) .. after that im going PP 5w-30 on my caravan.
#1234236 - 09/11/08 05:37 PM Re: Dino 5w20 good enough for Canadian winter weat [Re: eddiedz]
Bryanccfshr Offline
Loc: Durango, Co
We use 5w20 in our Ford gasoline Trucks on the North Slope of Alaska. -30 is common (we plug in, block heaters). (we are starting to opt for gas instead of diesel power for our vehicles due to the low sulfer diesel requirments makingdiesels simply uneconomical fo r our fleets.
Integrity is what we do when no one's looking.
2010 FJ Cruiser
Mobil 1 0w20 10k mile or 1 year WECF OCI's
2012 BMW F30 with the new N20
Tbd
#1234302 - 09/11/08 08:22 PM Re: Dino 5w20 good enough for Canadian winter weat [Re: Bryanccfshr]
blackhondaccord Offline
Loc: GTA/North Of The Border
try pennzoil 5w20 yellow bottle or
quakerstate 5w20 peak performance
pz pour point is -39 c
qs pour point is -36 c
excellent for dino, don't think any other dino comes close,
i think even petrocanada 5w20 dino is at - 30c
#1234509 - 09/12/08 07:19 AM Re: Dino 5w20 good enough for Canadian winter weat [Re: blackhondaccord]
Pesca Offline
Petrocanada 5w20 dino pour point is -36C (-33F).
As said by others, the problem is to find it and not pay to much for it compare to the other oils.
If you can, go for it, you should be happy with it. If you cannot find it or find it too expensive compare to PZ, go with PZ Yb.
#1234900 - 09/12/08 05:48 PM Re: Dino 5w20 good enough for Canadian winter weat [Re: Drivebelt]
chet2 Offline
Loc: NH
i think i would go with a synthetic in real cold weather
