Form-A-Funnel
Pennzoil YB $1.79/Quart after MIR (Limit 5)
by akk944
6 minutes 51 seconds ago
Oil recommendations please.
by matt_in_tulsa
46 minutes 53 seconds ago
Multiple quotes
by ChiTDI
Today at 09:30 AM
What's the preferred flavor of weed-trimmer??
by deeter16317
Today at 09:16 AM
September Advance Auto Ad
by tenderloin
Today at 08:34 AM
Brake system bleed now fluid is really dirty
by plrprecision
Today at 07:55 AM
which equation does widman calculator use?
by lipadj46
Today at 07:55 AM
Redline MT-85.
by simple_gifts
Today at 06:10 AM
jimo, porvdub, OADGTi, vicious_fishes, MASSMINI
32957 Registered Users
99 registered (addyguy, asamek, akk944, bdcardinal, AWDfreak, 10 invisible), 506 Guests and 42 Spiders online.
32957 Members
60 Forums
136840 Topics
Max Online: 941 @ 06/02/10 01:33 PM
#1228113 - 09/01/08 07:13 PM Oil pan gasket leaking, know how to replace but...
PandaBear Offline
Loc: Silicon Valley
Oil pan gasket leaking, know how to replace but I need to know how to get around the transmission that is covering one side of the pan, partly over the bolts.
Car of interest is a 97 Integra automatic. Everyone that tells you how to do it online said you just remove the cover on the manual transmission, the lower exhaust manifold (B pipe), and then the bolts. Reverse for installation (plus the correct torque and sequence with a small amount of permatex at the designated area.
Anyone tried it on an auto integra?
Worked for SanDisk, will try my best to help!
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife..." - Camu Mahubah
#1228124 - 09/01/08 07:28 PM Re: Oil pan gasket leaking, know how to replace but... [Re: PandaBear]
bdcardinal Online   content
Loc: santa barbara, ca
thats how you do it, its a pretty straight forward job. i would look at replacing the oil pan too, considering they strip out really easy.
2004 Volvo S60R 6 speed
Ford Master Parts Counterperson
"Fear disturbs your concentration."
-Sabine Schmitz
#1228126 - 09/01/08 07:30 PM Re: Oil pan gasket leaking, know how to replace but... [Re: PandaBear]
ThirdeYe Offline
Loc: Grand Rapids, MI
I have one myself, but it's a 95 automatic (same exact setup though). Sorry I haven't had to replace my oil pan gasket yet, it's original so I wouldn't know how to get around the automatic transmission.
Are you positive it's the oil pan gasket? A very, very common thing with the B18 engine in the Integra is the cam plug to leak down the block causing you to believe it's the oil pan gasket, etc.
1995 Acura Integra LS - 174,3xx - Valvoline SynPower 5W-30/Purolator PureONE PL14459
161 quarts and counting!
#1228183 - 09/01/08 08:50 PM Re: Oil pan gasket leaking, know how to replace but... [Re: ThirdeYe]
PandaBear Offline
Loc: Silicon Valley
80% positive. I checked around the cam plug and the valve cover gasket to make sure that they are clean all around. The +/- 2 inches around the oil pan gasket are all sticky with dirt on oil. The top end is recently rebuild so I'd imagine it is either the main seal or the oil pan gasket.
#1228336 - 09/02/08 01:37 AM Re: Oil pan gasket leaking, know how to replace but... [Re: PandaBear]
ThirdeYe Offline
Keep in mind that when the cam plug leaks, it won't look like it's leaking. But, the oil pan gasket is indeed possible. Just thought I'd throw that suggestion out there and possibly save you the hassle if it wasn't actually the oil pan gasket. \:\!
#1228356 - 09/02/08 03:00 AM Re: Oil pan gasket leaking, know how to replace but... [Re: ThirdeYe]
PandaBear Offline
Loc: Silicon Valley
ThirdeYe,
Thanks for the recommendation, I will check the cam seal/plug. I know they are famous to leak, just replaced the coolant hoses that was expanding like a ballon this weekend and checked for the condition around, doesn't look like a leak anywhere. My mechanics rebuild the top end after an overheat related head warp, and verified that it is fine. Was told that the cam seal problem is fixed starting at around 97, so I should be ok.
Kind of found out that there is a "Torque converter cover" that I can remove to access the blocked bolts/nuts.
#2 in photo here.
Edited by PandaBear (09/02/08 03:01 AM)
#1228556 - 09/02/08 12:24 PM Re: Oil pan gasket leaking, know how to replace but... [Re: PandaBear]
eljefino Offline
Loc: maine
That TC cover is common, used to be called the "flywheel inspection plate" on manual transmission cars... like you'd ever have to inspect the thing.
The only thing you need worry about is clearance on the oil pan bolts right up against the flexplate; may need wobblers, u-joints and or 1/4" drive sockets.
#1228963 - 09/03/08 01:21 AM Re: Oil pan gasket leaking, know how to replace but... [Re: eljefino]
AcuraTech Offline
Loc: St. Paul, MN
Remove a-pipe, inspection cover, removable frame crossmember, and the brackets that connect the trans to the engine block. This is off of memory, so I think that's all you need. Can be done relatively easily with some common tools and patience.
It's kind of a messy job, so if you do it in the garage or whatever, make sure to lay some cardboard down so the wife doesn't get mad.
I recommend applying a THIN layer of liquid gasket, such as Hondabond HT, to the oil pan gasket before installing. Hondabond HT is oil and gas resistant, good stuff! Can be found at all local Honda and Acura dealers. That's what Honda uses to seal the aluminum gasketless oil pans to the block. It's somewhat tacky, so it holds the new gasket to the pan while your putting it back together.
Make sure to not overtighten the oil pan bolts, because you'll just end up crushing the gasket and it'll eventually leak again.
And yes, the oil pan gasket leaking is common especially on high mileage Integras.
Good luck!
Edited by AcuraTech (09/03/08 01:24 AM)
*The above post is not to be construed as professional advice. For entertainment purposes only.*
