Guess my TBN
by jimbrewer
05/19/13 11:32 PM
Is OEM filter for 07 4 cylinder Camry good for10K
by teddyboy
05/19/13 10:45 PM
please explain to me all the FRAM hating! - why?
by LScowboy
05/19/13 10:44 PM
Bad CV Boot or Scam
by SIXSPEED
05/19/13 10:28 PM
ecoboost oil
by mobilaltima
05/19/13 10:25 PM
Cyclo C-2290 Ultimate Oil Treatment
by man114
05/19/13 10:01 PM
valve tick honda 2.4
by gregk24
05/19/13 09:57 PM
Keurig Brewers
by Pop_Rivit
05/19/13 09:55 PM
The Grocery Store
by KeithS_NW_Ohio
05/19/13 09:40 PM
Fram Tough Guard Filter
by measureman
05/19/13 09:36 PM
Acid indigestion?
by GreeCguy
05/19/13 09:07 PM
to change or not to change: this IS the question
by kc5mfu
05/19/13 08:33 PM
sandmangtp, RichAddison, Markspainting, bryznet, JayM
45462 Registered Users
78 registered (2010_FX4, Art_Vandelay, ammolab, ajchien, AmishFury, 6 invisible), 1060 Guests and 251 Spiders online.
45462 Members
64 Forums
193639 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
Page 1 of 4 1 2 3 4 >
#1217344 - 08/15/08 11:11 PM Toyota T-IV = Dexron III ?
sunfire Offline
Loc: Ca, US
I found this interesting TSB released by Toyota regarding their T-IV ATF:
http://www.ncttora.com/fsm/2000/Service%20Bulletins/tc001t02%20ATF%20Fluid%20Requirements.pdf
TSB: TC001-02
Title:
AUTOMATIC TRANSMISSION FLUID REQUIREMENTS
Models:
All ’00 – ’02 Models & ’03 Corolla & Matrix
MODEL----- 2000 -----|---- 2001 ----|---- 2002 ----|---- 2003
Corolla A131L, A245E | A131L, A245E | A131L, A245E | A245E
ATF----- DexronIII --|-- DexronIII -|-- DexronIII -|--- T-IV
Look at the row for the Corolla. The columns are the Aisin automatic transmission model numbers. Toyota recommends Dexron III in the A245E AT before and including 2002. However, Toyota goes to recommend Type T–IV in the SAME... I repeat the SAME 2003 Aisin A245E AT. There might be some very minor improvements in the AT from year to year. But I doubt anything significant enough to require an ATF with entirely different characteristics. Which leads me to conclude that T-IV is perhaps a higher grade Dexron III. I am speculating that they did this so they can promote their "life time ATF" to raise the Corolla value's because of less maintenance. And would also explain Toyota's naming convention (4 comes after 3) for their improved Dexron III+ ATF.
Here are a few after market ATFs that claim meets T-IV specs and the reason they meet T-IV is because they are already meet Dexron III specs... again this statement is sepeculation:
Mobil 1 Synthetic ATF
Mobil Multi-Vehicle
Mobil ATF 3309 (approved against Type T-IV, JWS 3309)
CASTROL Import Multi-Vehicle
PENNZOIL MULTI-VEHICLE
If the above is true then that would leave a lot full synthetic and synthetic blend alternatives for T-IV ATF users. I believe T-IV is still a conventional as people here and on other forums have stated.
Do YOU agree with what I said?
Edited by sunfire (08/15/08 11:17 PM)
2005 Toyota Corolla LE | 58,000 | PP 5W-20
#1217367 - 08/15/08 11:40 PM Re: Toyota T-IV = Dexron III ? [Re: sunfire]
sunfire Offline
Loc: Ca, US
I forgot to list everyone's favorite alternative ATF which does meet Dexron III and Toyota Type T-IV (JWS 3309) specs:
AMSOIL Synthetic Universal Automatic Transmission Fluid
Edited by sunfire (08/15/08 11:41 PM)
#1217405 - 08/16/08 01:00 AM Re: Toyota T-IV = Dexron III ? [Re: sunfire]
onion Offline
Loc: kansastan
Oh Cheezus... here we go.
The invisible and the imaginary look exactly the same.
#1217458 - 08/16/08 05:34 AM Re: Toyota T-IV = Dexron III ? [Re: onion]
crinkles Offline
Loc: New South Wales
I don't know... there's a lot of extrapolation from one small observation in there... I don't necessarily agree that Toyota should keep its customers to its own brand, but for what I pay for it it is really good value. down here it is close to the cheapest stuff... the aftermarket names claiming to meet T-IV specs are more expensive than T-IV from the dealer, so why bother?
2005 Camry, 2AZ-FE, 15w-40 Valvoline Nextgen SN - ACEA A3/B4
#1217496 - 08/16/08 08:00 AM Re: Toyota T-IV = Dexron III ? [Re: crinkles]
bmwtechguy Offline
Loc: South Carolina
Er, because you may want a better fluid? If I want a basic T-IV fluid that costs less than the dealer fluid, I will use one of 2 SuperTech ATF's at WM that list the spec. Otherwise I use Mobil 1 or Amsoil. All work very well.
#1217546 - 08/16/08 10:07 AM Re: Toyota T-IV = Dexron III ? [Re: sunfire]
Curtis Newton Offline
Loc: Colorado
Perhaps I am not following the paragraph above, but Type-IV is not a lifetime fluid. The Toyota WS (believe it stands for World Standard) is the fluid they claim is good for the life of the tranny.
2012 Jeep Grand Cherokee V6 AWD Limited, Pennzoil 5W30, 7K
2004 Lexus RX330 AWD, Pennzoil HM 5W30, 165K
1977 MG-B, GTX HM 10W40, 40K
#1217741 - 08/16/08 02:24 PM Re: Toyota T-IV = Dexron III ? [Re: onion]
friendly_jacek Offline
Loc: southeast US
here we go what?
#1217744 - 08/16/08 02:32 PM Re: Toyota T-IV = Dexron III ? [Re: crinkles]
Loc: southeast US
Well, T-IV is dino oil with dubious quality (gray color in 20000-30000 miles). Most replacements are synth with proven quality.
I like this info. I have left over Mobil 1 ATF from my previous car. I will go ahead and use it in my Corolla in the next ATF change (drain and refill I do every 30000 miles).
#1217819 - 08/16/08 05:32 PM Re: Toyota T-IV = Dexron III ? [Re: friendly_jacek]
NHHEMI Offline
Loc: NH
Royal Purple MaxATF also handles T-IV. I will run it in my tranny that calls for T-IV when I have the fluid changed.
Royal Purple User Since 1990 thumbsup
2011 Jeep Patriot
"Latitude"
2.4L 4WD
#1218154 - 08/17/08 08:54 AM Re: Toyota T-IV = Dexron III ? [Re: NHHEMI]
Char Baby Offline
Loc: Rochester NY
Well, let's look at a couple of things here first.
1) The 2003 Corolla is the newer version of the Corolla. 2002 was the last year of the Corolla/Prism versions. So maybe Toyota made some changes to the Corolla/Matrix/Vibe tranny to require T-IV.
2) Mobil 1 is no longer DexronIII/Mercon, it's Mercon V now at least in my neck of the woods. And the bottle that Im holding in my hand as Im writing this doesn't say anythinhg about being used in a Toyota as a replacement for T-IV but can probably be used in Toyota auto trannys using Dexron.
I haven't seen any new Mobil 1 syn atf in my area that states what sunfire is saying. I do beleive sunfire and I would like to see/use this Mobil 1.
"The hurrier you are, the behinder you get!"
#1218171 - 08/17/08 09:41 AM Re: Toyota T-IV = Dexron III ? [Re: Char Baby]
Donald Offline
Loc: Upstate NY
According to the Mobil 1 website their Mobil 1 ATF does not mention anything about Toyota T-IV so it should not be used. End of discussion.
Amsoil ATF does mention T-IV and should be an excellent choice if you want a top tier full synthetic.
2001 Jeep Grand Cherokee Laredo 4.0 - PU 10W30 & D+
1999 Dodge Ram 2500 w/Cummins - Rotella T6 & M1
Amsoil ATF in both vehicles & Magnefine filter.
#1218314 - 08/17/08 02:27 PM Re: Toyota T-IV = Dexron III ? [Re: Char Baby]
Loc: southeast US
I have 2003 corolla. The changes in engine mostly dealt with oil consumption (very common in 1998-2002 corollas) such as new oil rings and oil holes. I doubt there were significant changes in tranny, except for software and shifting points. Possible optimized for the new fluid.
As for Mobil 1 ATF suitable for T-IV is shown here:
http://www.mobil.com//USA-English/Lubes/PDS/NAUSENPVLMOMobil_1_Synthetic_ATF.asp
I doubt the formula changed regardless what is printed on the bottle.
#1218316 - 08/17/08 02:28 PM Re: Toyota T-IV = Dexron III ? [Re: Donald]
Loc: southeast US
It's not end of the discussion if you read here:
#1218433 - 08/17/08 06:37 PM Re: Toyota T-IV = Dexron III ? [Re: Donald]
dorkiedoode Offline
Loc: los angeles
 Quote:
Mobil 1 Synthetic ATF is also suitable for use in vehicles that specify the following fluid requirements:
Audi G 052 025-A2, G 052 162-A1
BMW LA2634
Esso LT 71141
ETL-7045E, ETL-8072B, N402
Ford* MERCON*, MERCON V, MERCON LV
All 2005 and earlier GM vehicles**
Honda ATF-Z1*
Hyundai SP-II, SP-III
Idemitsu K17
JWS 3309
Kia SP-II, SP-III
MAN 339F, V1, V2, Z1, Z2, Z3
Mazda ATF-III, ATF-MV
Mercedes-Benz 236.1, 236.2, 236.5, 236.6, 236.7, 236.9
Mitsubishi Diamond SP-II, SP-III
Nissan Matic-D, Matic-J, Matic-K
Subaru ATF
Toyota T-III, T-IV
Voith 55.6335.XX (G607, G1363),
Volvo 97340
ZF TE-ML 03D, 04D, 09, 14A, 14B, 16L, 17C
Edited by dorkiedoode (08/17/08 06:42 PM)
2010 honda accord exl v6 navi
2006 honda civic si
1999 honda accord exl v6
1998 toyota corolla ce
#1218479 - 08/17/08 07:43 PM Re: Toyota T-IV = Dexron III ? [Re: friendly_jacek]
mikered30 Offline
Loc: PA
Nice find, from what I remember, M1 ATF was not always a replacement for T-IV. Is this a new formulation? Who will be the first to try it?
