Oil Reccomendation - 2009 Jetta 2.5l
by Chewi5150
56 minutes 8 seconds ago
Rock Auto Discount Code
by R80RS
Today at 02:46 PM
TV late night talk show hosts
by HTSS_TR
Today at 02:39 PM
Craftsman riding mowers
by BrianF
Today at 01:39 PM
Pirelli Scorpion Verde All Season Plus
by Ddub
Today at 01:36 PM
Do I need an alignment?
by Lolvoguy
Today at 01:36 PM
Switching to HM Oil to fix consumption; Didnt work
by TexasTea
Today at 01:33 PM
More refined, smoother CVT - Corolla or Civic?
by flinter
Today at 12:46 PM
New pcv valve ringing noise when revving
by THafeez
Today at 12:45 PM
Best oil for stock 1982 Beetle 1200?
by FordCapriDriver
Today at 12:37 PM
Question on Valvoline's new High mileage oil
by NattyBoh
Today at 11:47 AM
2017 Harley Davidson Milwaukee-Eight 107 Released
by DuckRyder
Today at 11:43 AM
TonyG9050, krishna, Chuck1970, skylerG, LeeG
58890 Registered Users
84 registered (Al, 440Magnum, apwillard1986, Bandito440, Americana, ARB1977, 10 invisible), 1834 Guests and 7 Spiders online.
58890 Members
66 Forums
253461 Topics
#1201138 - 07/24/08 06:15 PM Kohler Courage 25 Pro on Gravely ZT2552 HP Mower
Bebop367 Offline
Loc: Louisiana
Trying to decide whether to buy a new Gravely Zero Turn Mower with 25 HP Kohler Courage PRO.
Should I buy or keep looking.
I have no Experience good or bad with any Kohler engines.
Any comments or experiences welcome.
#1201140 - 07/24/08 06:19 PM Re: Kohler Courage 25 Pro on Gravely ZT2552 HP Mower [Re: Bebop367]
JTK Offline
Loc: Buffalo, NY
Check Kohlerengines.com. The specs between the Courage V-twins and Command V-twins nearly the same. The Courage series single cylinder engines are a bit different though. I don't have personal experience with Gravely ZTRs, but they seem like nice compact, solidly built machines. Gravely has always been top-knotch IMO.
Joel
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#1201146 - 07/24/08 06:27 PM Re: Kohler Courage 25 Pro on Gravely ZT2552 HP Mower [Re: JTK]
Bebop367 Offline
Loc: Louisiana
Seems the main difference in the Command and the Courage in Twins is the Command has Hyd. Lifters.
Also appears the Torque is different:
25HP Command list 41 ft. lbs. @ 2400 RPM
25HP Courage Pro list 44.8 ft. lbs. @ 2200 RPM.
#1201156 - 07/24/08 06:37 PM Re: Kohler Courage 25 Pro on Gravely ZT2552 HP Mower [Re: Bebop367]
JTK Offline
Loc: Buffalo, NY
Both the V-twin series have identical valve trains with hydraulic valve lash adjusters. I've been told that the Kohler lifters are identical to Chevy small block lifters.
Joel
#1201169 - 07/24/08 07:15 PM Re: Kohler Courage 25 Pro on Gravely ZT2552 HP Mower [Re: JTK]
Barkleymut Offline
Loc: Richmond, VA
FWIW- Kohler is generally a very good manufacturer of small engines. I have been out of the biz for over 3 years now and haven't heard of the Courage line. I had a 25HP Kohler Command engine that had a serious problem at 25 hours but after that ran very strong for over 2000 hours thereafter and I sold it. The problem was handled with zero problems and covered under warranty. I would buy a Kohler in a second. Just make sure that the dealer that you are buying from is solid. What kind of air filtration is on the unit you plan on buying?
09 Vue(95K) 2.4 4spd AT -PU 5w30 / 09 Flex(52K)3.5L PU / Moms car 04 Pilot(105K) 5w20 PP + Puro
#1201174 - 07/24/08 07:29 PM Re: Kohler Courage 25 Pro on Gravely ZT2552 HP Mower [Re: Barkleymut]
Bebop367 Offline
Loc: Louisiana
The air filter and pre filter (foam) are larger (60% I think it said) than the non Pro version. Its not a commercial canister type.
#1202068 - 07/26/08 07:41 AM Re: Kohler Courage 25 Pro on Gravely ZT2552 HP Mower [Re: Bebop367]
Brett Miller Offline
Loc: Arizona
The Courage line is not the quality the Command line was. It is meant for the lower end market. Commercial equipment still uses the Command and Command Pro line.
#1202455 - 07/26/08 07:27 PM Re: Kohler Courage 25 Pro on Gravely ZT2552 HP Mower [Re: Brett Miller]
coobie Offline
Loc: S.Michigan
I fully agree.From what I have read the courage line of engines are JUNK.
#1202644 - 07/27/08 12:40 AM Re: Kohler Courage 25 Pro on Gravely ZT2552 HP Mower [Re: coobie]
JTK Offline
Loc: Buffalo, NY
I think you guys are confusing the 25hp Courage twin for one of the single cylinder Courage series engines. Those are very different engines and supposedly had issues early on, albeit caused more by the owner. Look at the specs for a Courage V-twin like the OP's 25hp question. They are nearly identical to the Command series twins.
Joel
