45519 Members
64 Forums
193823 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#1199752 - 07/22/08 10:31 PM
Re: My NuFinish Review (good stuff!!)
[Re: 1sttruck]
Loc: FL
A wax/sealant shouldn't require a coarse cloth to be removed. It would induce swirls.
#1199838 - 07/23/08 12:17 AM
[Re: 1sttruck]
Loc: FL
With the stuff (NXT, Synwax, 4* UPP,Meg's #26, PB's Natty's, TW Platinum) that I use, a soft microfiber can usually remove the product without much effort.
#1199959 - 07/23/08 07:05 AM
[Re: asiancivicmaniac]
Loc: NENC
Mothers and TW have always been super easy to remove but NXT? I was going to get the chisle when I applied it way to thick. The paste is extremely soft in the tin so you have to just dab the applicator and apply.
2011 Ford Ranger 56K M1 5W-20, M1 ATF in the manual trans, M1 Gear lube.
#1200104 - 07/23/08 11:09 AM
[Re: TaterandNoodles]
Loc: NC
I have never used NXT but from what I read you need to apply to a cool surface and apply very thinly. Do not let it sit very long on the paint once it passes the "swipe" test. I think a foam applicator is best for applying waxes thinly (as opposed to a mf applicator).
#1200114 - 07/23/08 11:25 AM
[Re: Schmoe]
Loc: Minnesota
It's not a wax. It doesn't come off like a wax. You probably want to use some type of cleaner/remover product. Most of the major wax manufacturers have a pre-wax cleaner designed to strip off old wax, dirt, oxidation, etc. That plus any mild polish swirl remover/glaze should get you prepped again for a fresh waxing.
I will say I do kind of like the look of NuFinish plus a wax top layer. It's not as mirror-like reflecting everything in sight but has a good shine to it. As long as the stuff lasts a while, I should be able to just apply a fresh coat of wax over the stuff every couple months and do well.
I just can't see using NuFinish alone though. It just doesn't do anything other than seal. You need a seperate cleaner, a seperate swirl/scratch remover/filler, and a seperate top coat (unless you don't want a wet/shine type of finish). I just hope it lasts a long time. If so, I don't mind including it in a multi-step process as a good sealer. As a stand-alone product, there are just better things out there, like a variety of cleaner waxes that do offer some cleaning ability, filler, and shine.
#1200269 - 07/23/08 02:45 PM
[Re: mvw2]
Loc: Calgary Canada
Like what? I'll admit, I'm interested. I just don't seem to have any desire to devote the time to do use anything more than a one-step! (Even though at times I can't resist buying the latest flavor of the week in auto-appearance). What I'm looking for would: 1. require only 1 application; 2. go on easy, come off easy, no power tools; 3. not stain any trim/plastic (no taping/preparation required); 4. provide a good finish that lasts a long time. This might be the holy grail, but given those requirements and not overly high expectations as to quality of finish, peoples thoughts would be appreciated!
Edited by Jim 5 (07/23/08 02:48 PM)
Jim A 07.5 GMC Sierra 2500HD LMM Rotella 15w-40 09 Odyssey EX-L CT 5w-20 66 Bronco QS 10w-30 08 BMW K1200S Rt 15w-40 08 Pitster Pro X4 Rt 15w-40
#1200420 - 07/23/08 09:08 PM
[Re: Jim 5]
Loc: Ohio
Like what? I'll admit, I'm interested. I just don't seem to have any desire to devote the time to do use anything more than a one-step! (Even though at times I can't resist buying the latest flavor of the week in auto-appearance). What I'm looking for would: 1. require only 1 application; 2. go on easy, come off easy, no power tools; 3. not stain any trim/plastic (no taping/preparation required); 4. provide a good finish that lasts a long time. This might be the holy grail, but given those requirements and not overly high expectations as to quality of finish, peoples thoughts would be appreciated! Collinite 476s
#1200469 - 07/23/08 09:57 PM
[Re: john1782]
Loc: Calgary Canada
As luck would have it I ordered some online just 2 days ago. Can't wait to try it!
#1200609 - 07/24/08 01:20 AM
[Re: Jim 5]
Loc: Minnesota
One step products are "cleaner waxes." They're basically waxes that incorporate light cleaning/polishing types of actions to try and give more of a total one step job.
The best route is to go through all the steps though. You sort of have to address all the different aspects that influence the overall process and final result.
Collinite 476s is a well loved wax. I don't think it's a cleaner wax though, so any dirt and swirl marks will still be sitting there when you coat over them. This is why you do other steps.
Wash - clean off the major [censored] Bug off - mild acid generally, gets ride of what washing can't Clay bar - it's clay, safely pulls dirt/debris from paint, dirt sticks to it Prewax cleaner - remove old wax, oxidation, dirt, etc. Polish - gets rid of large scratches Swirl remover - gets ride of small scratches and swirl marks Glaze - filler, fills scratches and swirl marks Cleaner wax - some cleaning agents plus wax Pure wax - just wax, pure and simple Sealant - synthetic product, contains no waxes
The goal is to combine the range of products to treat and protect the paint. In the most basic form, you simply wash and coat with a wax. You can use a plain wax, but a cleaner wax does more things.
I personally like to go through the steps, at least some to take care of all the major issues. In the end, you just get a better result. As well, it's not like you have to do all these steps every time. The prewax cleaner can be done once a year to strip old wax or prep a dirty, oxidized surface (great for rubber parts too). Polish and swirl remover are "as needed" type of products. A glaze can be used pretty much all the time as it can fill in and hide problem areas rather than strip away some of the clear coat. Sealers and waxes can be interchangable in the sense that both work towards the same end.
#1200614 - 07/24/08 01:30 AM
[Re: mvw2]
Loc: FL
I personally like to go through the steps, at least some to take care of all the major issues. In the end, you just get a better result. As well, it's not like you have to do all these steps every time. The prewax cleaner can be done once a year to strip old wax or prep a dirty, oxidized surface (great for rubber parts too). Polish and swirl remover are "as needed" type of products. A glaze can be used pretty much all the time as it can fill in and hide problem areas rather than strip away some of the clear coat. Sealers and waxes can be interchangable in the sense that both work towards the same end. I don't know if your steps were listed in order but some are either redundant or out of order.
#1200634 - 07/24/08 02:51 AM
Loc: Norwalk, CA not CT
Yeah that's a whole lotta steps. If you use good products you should be able to keep it to just wash, clay, polish and wax. If the surface is especially bad I'll use a heavier cut polish then swirl remover.
#1202084 - 07/26/08 08:51 AM
[Re: qwertydude]
Loc: MD
Go mention nufinish on autopia.org and get ready be be flamed big time. Reason being is its junk plain and simple. Its fine for somebody that wants something simple but doesnt care about getting the best look possible but even then I wouldnt use it on my cars even if you paid me to. I have been detailing for years and have used thousands of products including nufinish so dont come in here and try to tell me I dont know what I am talking about. This is my race car with 2 coats of zaino Z2 topped with a coat of p21s wax.  My fiances car that I polished with menzerna intensive polish then with Menzerna final polish then sealed with Mothers Reflections synthetic wax. The mothers reflections is the best over the counter sealant money can buy. Duragloss is also very good.  Here is my daily driver wearing mothers reflections. Lighting was not good so you really cant tell anything from this pic.
Edited by ProStreetCamaro (07/26/08 08:52 AM)
#1202086 - 07/26/08 08:59 AM
[Re: mvw2]
Loc: Northern CA
In order this list is not.
Edited by XS650 (07/26/08 08:59 AM)
Whenever you find yourself on the side of the majority, it is time to pause and reflect.
--Mark Twain
#1202784 - 07/27/08 10:16 AM
[Re: XS650]
Loc: va.
ProStreet: I agree Mothers Reflections is the best OTC you can buy I think it blows away Z5 and Z2. I love P21S so easy too use and great results esp. on dark colors.
