VR1 Only suitable for 3 month / 3000mi oci's?
by FordCapriDriver
04/29/16 04:07 AM
4-year old oil in a sealed container
by rickeroo
04/29/16 12:05 AM
Cowboys fans should be happy tonight.
by deven
04/28/16 11:03 PM
2012 Civic - MaxLife ATF update
by sw99
04/28/16 10:58 PM
Champ PH820 on closeout at Rockauto
by sw99
04/28/16 10:52 PM
Is two years too long?
by kohnen
04/28/16 10:34 PM
Keep getting TR.APK popup on S III cell phone...
by daves66nova
04/28/16 10:16 PM
Curse You Road Salt Version 2
by Oldtom
04/28/16 07:34 PM
Anyone have advice for moving a cat cross-country?
by earlyre
04/28/16 07:23 PM
MLB baseball games are very expensive
by Joe1
04/28/16 07:20 PM
Additive technology used in Euro mid-saps oils
by skyactiv
04/28/16 05:41 PM
Would I be crazy if I did this:
by Doog
04/28/16 05:36 PM
carver1, Handy7rick, sicilien, Crater_77, hiker17
57737 Registered Users
30 registered (Astro14, AirgunSavant, 1foxracing, Bandito440, alcyon, 5 invisible), 606 Guests and 308 Spiders online.
57737 Members
66 Forums
248196 Topics
Page 1 of 2 1 2 >
#1195354 - 07/16/08 08:20 PM Bead Seating
Jonny Z Offline
Loc: Austin, TX
What exactly is bead seating?
Michelin says do not inflate past 40 PSI to seat the bead - even the tire is rated for max 44 psi cold.
Is this something done at installation and once the tire is on it can safely carry 44PSI?
02 Camry SE 4 cyl 5sp manual. 120K. Vavoline MaxLife Blend 5W30 + Purolator Classic / Redline MT90 / Michelin HydroEdge
#1195374 - 07/16/08 08:33 PM Re: Bead Seating [Re: Jonny Z]
wantin150 Offline
Loc: Columbia, SC
Ever watch a tire being installed? They have to get the tire bead to seat on the rim. The bead will usually make an audible "pop" when it seats. Excessive pressures can explode the tire and rim assembly (or so I was told by the dealer).
2003 Toyota Matrix XRS 87,000 miles
2008 Scion xD 14,500 miles
2007 Yamaha YZF600r 8,400 miles
#1195418 - 07/16/08 09:09 PM Re: Bead Seating [Re: wantin150]
eljefino Offline
Loc: ME
bead seating, eljefino style:
http://youtube.com/watch?v=NlYvKi89Q_U
1:47 into video
Personally they usually pop in for me at about 7 psi. They use cages for heavy truck tires b/c if they let go it'll cut you up.
#1195518 - 07/16/08 11:00 PM Re: Bead Seating [Re: eljefino]
bdcardinal Offline
Loc: Santa Barbara, CA
most tires will seat with a lot less than 40psi. the seat pressure had no effect on normal operating pressures. when i did tires, certain brands would seat at extremely high pressures. michelin pilot sports, and a lot of other high end tires will seat high because they have thin widewalls are are usually being stretched on a narrow wheel.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
#1195624 - 07/17/08 06:33 AM Re: Bead Seating [Re: bdcardinal]
alreadygone Offline
Loc: North Arkansas
As bdc said, most will seat well under 40. Occasionally, though, they don't. Proper procedure is then to deflate, relube to include lubing wheel mounting surfaces, and try again. Occasionally this is still not enough. Thats when you stand waaaayyy back, use the tip of the toe on inflator, and air till she goes! Have hit 80 a few times! Pucker factor goes through the roof!
Truck tires in cages are a whole 'nother spincter tightener.
Bob
To which version of reality would you like to convert me?
Bob
#1195656 - 07/17/08 07:43 AM Re: Bead Seating [Re: eljefino]
CapriRacer Offline
Loc: Somewhere in the US
1:47 into video
All I can say is: WOW!!! Amateurs!! \:\(
CapriRacer
Visit my web site: www.BarrysTireTech.com
#1195736 - 07/17/08 10:19 AM Re: Bead Seating [Re: CapriRacer]
Jonny Z Offline
Loc: Austin, TX
Hmm. When I get new tires I usually get some gummy looking thing around the edge of the rims. I surmise this was lubricant of some sort? I thought it was a sealant.
#1196248 - 07/17/08 10:34 PM Re: Bead Seating [Re: Jonny Z]
bdcardinal Offline
its probably the lubricant from mounting. i was always thougtful and wiped it off.
#1196392 - 07/18/08 03:56 AM Re: Bead Seating [Re: Jonny Z]
CapriRacer Offline
Another guess: protect the rim edge during shipping and mounting?
CapriRacer
#1206219 - 08/01/08 03:14 AM Re: Bead Seating [Re: CapriRacer]
Dualie Offline
Loc: SF bay area, San leandro, Ca
www.KILLCARB.ORG
#1206236 - 08/01/08 06:23 AM Re: Bead Seating [Re: Dualie]
alreadygone Offline
Loc: North Arkansas
freaking idiot
Bob
Bob
#1207999 - 08/04/08 03:45 AM Re: Bead Seating [Re: alreadygone]
mechtech2 Offline
Loc: Chicago Area
We had some very low profile tires that would not seat [AMG].
We ended up using starting fluid and a match.
Well, it worked.
#1208017 - 08/04/08 05:56 AM Re: Bead Seating [Re: mechtech2]
CapriRacer Offline
Well, it worked.
This is very dangerous!!! There are a few Youtube videos of tires catching on fire and once that happens the rubber is no longer fit for use.
Not to mention that this is a good way to break beads. People sometimes get killed when beads break in mounting.
If you can't get the tire to seat doing it the normal way, something is wrong. You need to figure out what is wrong and correct it.
CapriRacer
#1213797 - 08/11/08 10:17 PM Re: Bead Seating [Re: CapriRacer]
TylerL Offline
Loc: Mishawaka, IN
I just mounted a tire using only screwdrivers. It was to test for rim leaks. My mom came out to see what the bang was when the bead seated. I wish I could mount all my tires myself but it's not worth the risk to save $50. I'll stick to bike tires.
#1213977 - 08/12/08 07:48 AM Re: Bead Seating [Re: TylerL]
Kestas Offline
Loc: The Motor City
I've mounted at least a couple dozen tires in my basement. I put a little lube on the rim and stand the tire upright (for safety) to seat the beads. It makes a loud pop but I've never had problems.
Page 1 of 2 1 2 >
