2 Months 3434 miles using Pennzoil Yellow Bottle 10W/30
I had my intake gaskets redone shortly after my last UOA. My mechanic changed the oil when the job was done. I changed it when I got it home and it obviously had lots of coolant in it still, oil doesn't normally steam. I then changed it again 10 days or so later with YB 10W/30 and a PF52 ACDelco filter. My intent was to go 3k miles and test but I went slightly over. Looks like the fix was successful.
I drive pretty gentle most of the time.
Wix air filter. Air filter changed at 60k miles on the odo.
Blackstone Coments:
We're sorry to hear about your engine but at least you found the coolant leak before it became a real problem. Silicon increased due to sealers used when reassembling your engine. It should improve with subsequent oil changes. All wear read normally. It looks like whoever worked on your engine did a good job. We found nothing in this data that would be cause for alarm. The viscosity of the oil read in the 5W/30 range rather than the 10W/30 that was listed. We don't think this is a problem. No harmful contaminants were found.
Comments welcome. I've got PP 10W/30 in it now with a Wix filter and plan to go 5k miles and test again.
Code:
OIL PYB10W30 PP5W30 M110W30 M110W30
MILES IN USE 3.4k 5.1k 5.7k 4.9k Uni Avg
MILES 87.1k 80.5k 70.4k 64.8k
SAMPLE TAKEN 6/10/08 2/28/08 9/2/07 7/3/06
ALUMINUM 2 3 3 2 3
CHROMIUM 1 1 1 1 1
IRON 9 24 14 8 13
COPPER 21 28 39 30 17
LEAD 9 4 21 19 8
TIN 2 1 0 0 1
MOLYBDENUM 3 52 98 83 57
NICKEL 0 1 0 0 0
MANGANESE 0 0 0 0 0
SILVER 0 0 0 0 0
TITANIUM 0 0 0 0 0
POTASSIUM 7 11 1 3 7
BORON 114 34 47 52 44
SILICON 29 13 12 12 11
SODIUM 8 10 5 4 15
CALCIUM 2018 2919 2184 2354 2079
MAGNESIUM 7 12 11 13 96
PHOSPHORUS 646 656 538 589 695
ZINC 784 819 675 745 848
BARIUM 0 0 0 0 0
INSOLUBLES 0.2 0.3 0.3 0.3
WATER 0 0 0 0
FLASHPOINT ºF 400 400 410 420
SUS VIS 210ºF 46.6 57.9 58.6 60.8
cSt @ 212ºF 9.24 9.63 9.83 10.44
TBN n/a 3.9 3.7 n/a
Blackstone Coments:
Code:
ALUMINUM 2 3 3 2 3
CHROMIUM 1 1 1 1 1
IRON 9 24 14 8 13
LEAD 9 4 21 19 8
TIN 2 1 0 0 1
NICKEL 0 1 0 0 0
MANGANESE 0 0 0 0 0
SILVER 0 0 0 0 0
TITANIUM 0 0 0 0 0
SODIUM 8 10 5 4 15
BARIUM 0 0 0 0 0
WATER 0 0 0 0
TBN n/a 3.9 3.7 n/a
