Form-A-Funnel
Oil recommendations please.
by matt_in_tulsa
34 minutes 47 seconds ago
Multiple quotes
by ChiTDI
54 minutes 28 seconds ago
What's the preferred flavor of weed-trimmer??
by deeter16317
Today at 09:16 AM
September Advance Auto Ad
by tenderloin
Today at 08:34 AM
Brake system bleed now fluid is really dirty
by plrprecision
Today at 07:55 AM
which equation does widman calculator use?
by lipadj46
Today at 07:55 AM
Redline MT-85.
by simple_gifts
Today at 06:10 AM
K 1 vs K 2 kerosene
by kkat
Today at 05:35 AM
jimo, porvdub, OADGTi, vicious_fishes, MASSMINI
32957 Registered Users
110 registered (addyguy, bdcardinal, AWDfreak, AlaskaMike, 97tbird, 12 invisible), 424 Guests and 48 Spiders online.
32956 Members
60 Forums
136839 Topics
Max Online: 941 @ 06/02/10 01:33 PM
Page 6 of 7 < 1 2 3 4 5 6 7 >
#1132636 - 04/19/08 09:30 AM Re: Pablo's finished bike [Re: eljefino]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
Is Youtube loading ok for you right now?
My clutch used to be nasty. I use a brake lever now, but you need to a) adjust the "plate" correctly and b) take apart the left side (use the supplied gear puller) and grease it up real good and put it back together c) lube the cable. After that and a little break in, it will be nice.
#1132701 - 04/19/08 12:05 PM Re: Pablo's finished bike [Re: eljefino]
Pablo Offline
Trust me - it will get faster as it breaks in and you tune it well.
Then get a jackshaft and wear double skivvies.
#1132908 - 04/19/08 08:08 PM Re: Pablo's finished bike [Re: Pablo]
eljefino Offline
Loc: maine
Cruises at 25, can get 29 mph.
The idle is up so I think it's breaking in. Did a 14 mile loop today.
#1137923 - 04/26/08 09:51 PM Re: Pablo's finished bike [Re: eljefino]
Pablo Offline
Man - now that the weather is nicer, I've been tearing around with mine as well. I must admit the power to the ground through the transmission is awesome. I can rip up any hill. So much fun, I can switch gears really quickly. Scary fast, but I can go down to first and start with the clutch at the bottom of a hill and just torque all the way shifting as I go.
#1139580 - 04/29/08 09:30 AM Re: Pablo's finished bike [Re: Pablo]
Pablo Offline
#1139589 - 04/29/08 09:44 AM Re: Pablo's finished bike [Re: Pablo]
moribundman Offline
How many miles do you expect the engine to last? Can it be rebuilt?
#1139597 - 04/29/08 09:55 AM Re: Pablo's finished bike [Re: moribundman]
Pablo Offline
I figure mine will go past 5000 miles with ease. Yes - simple engine. The Italian engine expect - I would last a tad longer, but more expensive parts:
Thread: http://motorbicycling.com/f3/life-expectancy-chinese-bicycle-engines-585.html
Humor: http://motorbicycling.com/f11/cranks-could-break-858.html
"I broke my crank"
#1139631 - 04/29/08 10:25 AM Re: Pablo's finished bike [Re: Pablo]
moribundman Offline
I might get in on this entertaining nonsense if Revopower's "Wheel" ever comes out or if I wreck a disc. Google "Revopower."
#1158994 - 05/26/08 01:31 AM Re: Pablo's finished bike [Re: moribundman]
oilboy123 Offline
Loc: Everett, Washington
Kool looks like fun........
Consider how hard it is to change yourself and you'll understand what little chance you have in trying to change others.
Jacob M. Braude
#1159102 - 05/26/08 08:49 AM Re: Pablo's finished bike [Re: oilboy123]
Pablo Offline
Now that the weather is nice, we've been riding fools. Here's the latest shots of my set-up:
Post #134 and 135
#1159360 - 05/26/08 04:37 PM Re: Pablo's finished bike [Re: Pablo]
eljefino Offline
Loc: maine
That looks insane. My bike is laid up with a busted motor mount stud. Chinasteel just lost cohesion.
Get some 6mm allthread made in, oh, pittsburgh, and redo everything if you haven't yet.
#1159380 - 05/26/08 05:09 PM Re: Pablo's finished bike [Re: eljefino]
Pablo Offline
I got sick of stripping the threads out of nuts....and never rely on China studs....easy enough to replace. The beauty of the new rear mount is not relying on two cheeseball studs.
#1167996 - 06/08/08 05:25 AM Re: Pablo's finished bike [Re: Fester]
Cutehumor Offline
Loc: Brentioch,TN
how much gas does it hold?
1996 Pontiac Sunfire, 2.2L, 170k miles, last OCI 8/7/10.
2009 Pontiac Vibe, 2.4L, 40k miles, last OCI 8/8/10
#1168025 - 06/08/08 08:12 AM Re: Pablo's finished bike [Re: Cutehumor]
Pablo Offline
A little over 1/2 gallon - I've never actually measured it though. There are larger tanks and an auxiliary rack mounted tank. I must be getting well over 100 mpg it take me stinking forever to use the tank up around town.
I just ported the works and made new gaskets.
First I attacked the intake manifold. I used a sander drum wheel - 80 grit - man how sweet. Went into the welds, made the flange match the tubing and then opened it up a bit. Also got the weld at the inside of the bend. Got the burr on the carb side.
Then I went after the exhaust manifold that came with my pocket bike expansion pipe. Had to cut considerable material off the thick flange. Worked it nice and finished up with a 120 grit wheel. It feels really smooth.
#1168836 - 06/09/08 01:33 PM Re: Pablo's finished bike [Re: Pablo]
Pablo Offline
