Highway conditions in the Midwest
by grampi
07/01/16 08:22 AM
Indian head shellac or something?
by JHZR2
07/01/16 08:15 AM
Need Help! Tombstone
by AirgunSavant
07/01/16 07:38 AM
Truck bedliner - pros and cons and option
by ryan2022
07/01/16 07:33 AM
Delo 400 SD 15w30 From Amazon
by AirgunSavant
07/01/16 07:27 AM
GM LS 6.0 Suggestion
by akcooper9
07/01/16 06:58 AM
Penrite 5W-30 Full Synthetic
by KL31
07/01/16 06:08 AM
PP HM at Walmart
by dlundblad
07/01/16 04:55 AM
74/76mm x 15 Flutes
by Merkava_4
07/01/16 04:33 AM
Autozone - Pennzoil with the PP - Rebates
by Kwuality
07/01/16 03:29 AM
Old Toyota
by artbuc
07/01/16 03:18 AM
Shell Helix Ultra 5W-20 & 0W-20 in Australia
by SR5
07/01/16 03:03 AM
EdandSherry, Shalmaneser, Shipmate29, garytcosta, lifteddiesel90
58332 Registered Users
86 registered (ac_tc, ARCOgraphite, badtlc, AirgunSavant, b1amgm47, AEHaas, 6 invisible), 1582 Guests and 12 Spiders online.
58332 Members
66 Forums
251084 Topics
#1167327 - 06/07/08 12:59 AM 06 Nissan Titan 5.6L V8 GC 0w-30 3754 miles
Highroller Offline
Loc: Arlington, TX
Engine Make/Model: 2006 Nissan Titan V8 5.6L
Oil interval: 3754 miles
Engine mileage: 56679 miles on odometer
Oil/oil filter used: 6.7 qts M1 0w-40 & Pure1 filter
Makeup oil: none
Oil lab: Blackstone
Oil samples was taken on 5-31-08
The left is the most recent and the right is from my last three samples:
(GC 0w-30) (M1 0w-40) (GC 0w-30) (M1 5w-30TSUV)
5-31-08 9-12-07 10-31-06 5-24-06
miles on oil: 3754 2543 3006 2569
odometer: 56679 45386 21058 11634
Aluminum: 2 2 1 2
Chromium: 1 1 0 1
Iron: 6 7 3 6
Copper: 1 1 2 2
Lead: 6 1 1 2
Tin: 2 0 0 0
Moly: 4 68 1 75
Nickel: 0 0 0 0
Manganese: 0 0 0 0
Silver: 0 0 0 0
Titanium: 0 0 0 0
Potassium: 2 0 0 0
Boron: 5 118 0 38
Silicon: 15 13 19 12
Sodium: 7 8 3 8
Calcium: 1979 2557 2736 2173
Magnesium: 552 14 209 11
Phosphorus: 962 790 851 571
Zinc: 1286 917 964 672
Barium: 0 0 0 0
TBN: n/a 7.5 5.7 4.8
SUS visc 210F: 63.8 67.2 65.5 59.1
cST visc 100C: 11.28 12.21 11.74 9.95
Flashpoint: 390F 395F 385F 390F
Fuel: <0.5 <0.5 TR <0.5
Antifreeze: 0 0 0 0
Water: 0 0 0 0
Insolubles: 0.2 0.2 0.1 TR
Blackstone: Thanks for the note about changing your air filter. We'll likely see silicon lower in the next sample. At 56,679
miles the 5.6L that powers your Titan continues to wear very well. This is the longest oil run that we've seen from your
engine and other than the increase in lead very little change was found. Lead at this level isn't a problem and we
wouldn't be surprised if it retreated in the next sample. If you did any heavy towing or hard driving on this fill that would
explain the increase. No problems were found.
My thoughts:
2006 Nissan Titan SE 5.6L Flexfuel
Current fill: Amsoil SSO 0w-30 & Ea15k13 oil filter & Amsoil multi-vehicle ATF & Amsoil Gear 75w-140
#1167331 - 06/07/08 01:19 AM Re: 06 Nissan Titan 5.6L V8 GC 0w-30 3754 miles [Re: Highroller]
Highroller Offline
Loc: Arlington, TX
For clarification, this is indeed GC 0w-30 (the M07 batches), not the Mobil1 0w-40 that i copied and forgot to edit out. I've been driving fairly hard lately, i would probably admit to driving 80mph on the freeway to work almost everyday for the past month or so. The GC 0w-30 uoa of 2006 were mostly green GC with about a qt of gold GC.
#1167393 - 06/07/08 07:51 AM Re: 06 Nissan Titan 5.6L V8 GC 0w-30 3754 miles [Re: Highroller]
Al Offline
Loc: Elizabethtown, Pa
You could be going at least 2 to 3 times further on an oil change.
#1167741 - 06/07/08 06:40 PM Re: 06 Nissan Titan 5.6L V8 GC 0w-30 3754 miles [Re: Al]
wapacz Offline
Loc: MI
yeah you could def run longer or start using cheaper oil.
Edited by wapacz (06/07/08 06:44 PM)
#1167809 - 06/07/08 08:07 PM Re: 06 Nissan Titan 5.6L V8 GC 0w-30 3754 miles [Re: wapacz]
Dale_Knight Offline
Loc: Alberta Canada
I would have liked to have seen the TBN at the end of the last oil usage.
2003 Rav4 manual 4WD 112K miles
Maxlife semisyn 5W30 + 1 quart 5W40 Redline euro / Fram Ultra
#1167876 - 06/07/08 10:02 PM Re: 06 Nissan Titan 5.6L V8 GC 0w-30 3754 miles [Re: Dale_Knight]
Highroller Offline
Loc: Arlington, TX
Thanks for all the inputs so far. i didnt feel the need to get a TBN based on my previous UOAs. I would assume the TBN would be either in the high 4's or around 5 but i did really beat on the oil by driving kind of hard for this sample. Any reason to worry about the increase in Tin and Lead?
Edited by Highroller (06/07/08 10:04 PM)
#1168097 - 06/08/08 10:27 AM Re: 06 Nissan Titan 5.6L V8 GC 0w-30 3754 miles [Re: Highroller]
Gary Allan Offline
Loc: Pottstown, PA
Random ticks. Just a spike in noise. Go longer and still sleep well at night. What's your time frame here? There has to be some gaps in the UOA testing.
http://lube-direct.com/gallan/
#1168500 - 06/08/08 10:47 PM Re: 06 Nissan Titan 5.6L V8 GC 0w-30 3754 miles [Re: Al]
Steve S Offline
Loc: East of IGO
There are so many that swear syn oil use saves money.
Why do people post I want the best for my car,,, When there isn't anything that is the best on the car to begin with.
#1168512 - 06/08/08 11:19 PM Re: 06 Nissan Titan 5.6L V8 GC 0w-30 3754 miles [Re: Gary Allan]
Highroller Offline
Loc: Arlington, TX
-I could extend my oil drains a bit longer but i drive fairly hard nowadays. Also not to mention alot of hauling. This truck is a tough beast to tame, can't help it much at times but to rev her up.
-Gary, what do you mean by my time frame? Well i don't know if this is the answer you wish to seek but I usually change out my oil around every 3-4k miles (which is around every 2 months for me due to my drivings). I plan on doing UOA every 10-15k miles. When i do the UOA sampling, i usually take the sample during the middle part of the drain. But for this most recent one, i took it when it was near the end part of the drain.
#1168655 - 06/09/08 08:26 AM Re: 06 Nissan Titan 5.6L V8 GC 0w-30 3754 miles [Re: Highroller]
addyguy Offline
Loc: Canada
Sorry to say this, but gas is $4/gallon, and you're driving a V-8 80 mph on the highway? You must have a LOT of money to burn!
:P
2010 Kia Soul 2U - 2.0L I-4, auto, 86k miles.
QSGB 5W-20, NAPA select filter(?)
#1170783 - 06/12/08 01:25 AM Re: 06 Nissan Titan 5.6L V8 GC 0w-30 3754 miles [Re: addyguy]
Highroller Offline
Loc: Arlington, TX
That's why my nickname is "highroller" hehe jk. Honestly, i feel i should drive slower. Gas prices aren't coming down anytime soon and im not getting a pay raise anytime soon either.
#1191444 - 07/11/08 01:25 PM Re: 06 Nissan Titan 5.6L V8 GC 0w-30 3754 miles [Re: addyguy]
Steve S Offline
Loc: East of IGO
:P
the oil changes prove it!!!
#1192239 - 07/12/08 02:10 PM Re: 06 Nissan Titan 5.6L V8 GC 0w-30 3754 miles [Re: addyguy]
JohnBrowning Offline
Loc: USA
I would go back to the M1 0W40 as it did better over all. Your lead level while still low is 6 times higher then it was with M1 0W40. While the total number is not that significant the 6 fold increase in it is. Yor lead number is not equal to tyour iron number which tells me that this engine likes something a tade thicker then the GC 0W30. So either go back to the M1 0W40 or try RTS 5W40.
