Does BG 44K work?
by j_mac
7 minutes 20 seconds ago
First CEL on the SRT-8
by OVERKILL
Today at 04:00 PM
How wide are the error bars on Seq IIIG tests?
by bulwnkl
Today at 03:15 PM
Who watches the oil co's?
by Camprunner
Today at 02:44 PM
Magnetec "Edged" out?
by ARCOgraphite
Today at 02:34 PM
Let's talk RUM
by car51
Today at 02:23 PM
Any .257 Roberts Reloaders On The Site?
by 2015_PSD
Today at 01:18 PM
Making tacos at home
by Reddy45
Today at 12:41 PM
Wiring a new garbage disposal
by Hokiefyd
Today at 11:38 AM
Power Steering Fluid
by DWC28
Today at 10:07 AM
Troy-Built 4.5hp running problem
by Kestas
Today at 09:26 AM
Conventional oil instead of synthetic
by corndogzombie
Today at 08:05 AM
Luuey, Eskimio, Jngoose76, Ken_Clifton, HotDog15
58592 Registered Users
86 registered (AnthemBassMan, 69GTX, 1JZ_E46, 182RG, 2010Civic, 440Magnum, 8 invisible), 2001 Guests and 22 Spiders online.
58592 Members
66 Forums
252236 Topics
#1159929 - 05/27/08 01:10 PM Are Hayden/Imperial fan clutches garbage?
brianl703 Offline
Loc: Manassas, VA
My friend has a 1999 3.9L Dodge Dakota and the original clutch failed, so he replaced it with a Hayden. This one was locked up so the fan ran at full-blast all the time. At least the engine didn't overheat.
Then he replaced it with an Imperial. This one doesn't seem to lock up enough and allows the engine to overheat at idle and when driving at low speeds. At idle, the air coming off the fan is VERY HOT, but the fan clutch does not appear to engage as it should to speed up the fan. Turning on the heat at full-blast is enough to keep the engine from overheating.
The Hayden and the Imperial look identical except for a 2-digit number cast into the housing. I expect they're made by the same company in the same factory.
I found a thread on dieselstop where someone was complaining about their experiences with Hayden fan clutches..the first one they got was locked up, the second one didn't engage right, neither did the third one so they gave up and reinstalled the OEM clutch (which they replaced because they thought it was engaging too much at lower temperatures).
My friend is going to return the Imperial clutch and get another Hayden one. I suspect he'll end up getting the same one he got the first time, they had exactly one on the shelf when he called and I bet it's the one he returned as defective the first time (this is NAPA by the way).
#1159956 - 05/27/08 01:45 PM Re: Are Hayden/Imperial fan clutches garbage? [Re: brianl703]
Gary Allan Offline
Loc: Pottstown, PA
I don't have anything to offer on Hayden fan clutches ..but I want to know how your friend defined "overheat". At low speeds or idling my Wrangler will gain temp, but it won't "run away" and boil over. It just stabilizes at a slightly higher temp.
http://lube-direct.com/gallan/
#1160043 - 05/27/08 03:47 PM Re: Are Hayden/Imperial fan clutches garbage? [Re: Gary Allan]
brianl703 Offline
Loc: Manassas, VA
It's going over 220F and once it starts it continues to run hotter and hotter. What makes me think it's the fan clutch is that there is no "roar" like you get at startup. It's like the fan clutch just doesn't respond properly to the heat from the radiator. And there is heat from the radiator--plenty of hot air coming off that fan.
#1160226 - 05/27/08 08:04 PM Re: Are Hayden/Imperial fan clutches garbage? [Re: brianl703]
Chris142 Offline
Loc: apple valley, ca
Hayden is about the only game in town. If you get a good one it will work well. We put 4 on my boss's Blazer before we got one that worked right.
Quite often we will put on a new one that won't hook up. Never seen one that wouldn't unhook. If the center of the Radiator is plugged the fan clutch won't hook up right. It will be getting cooler air instead of hot to make the spring turn.
Edited by Chris142 (05/27/08 08:06 PM)
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#1160233 - 05/27/08 08:19 PM Re: Are Hayden/Imperial fan clutches garbage? [Re: Chris142]
alreadygone Offline
Loc: North Arkansas
For many models Hayden has two application levels. Economy usually ok for most vehicles, as by the time original goes out economy version will last as long as the rest of the vehicle. Better grade is more like original with better thermostatic reaction.
'bout time for someone to jump in with "I only use OEM on MY marvel of engineering"!
Bob
To which version of reality would you like to convert me?
Bob
#1161887 - 05/30/08 12:11 AM Re: Are Hayden/Imperial fan clutches garbage? [Re: alreadygone]
brianl703 Offline
Loc: Manassas, VA
Looks like the 4th one is the charm. This one apparently had a bit of silicone oil on it, was it leaking?
I guess the customer truly is the final quality control inspector...and in the case of these things, the ONLY quality control inspector.
