STP 3614 Purolator cut and view
by sprite1741
05/27/16 12:58 PM
Finally saved up and bought my 1st car
by rocky8314
05/27/16 12:33 PM
Yellow dot and valve stem alignment
by qdeezie
05/27/16 12:30 PM
Shipping from Amazon
by grampi
05/27/16 12:14 PM
Do you have a fave Motorcycle Oil?
by ZZman
05/27/16 12:08 PM
Cruise control?
by OneEyeJack
05/27/16 11:38 AM
What Brand or Octane gas do you like to use?
by ZZman
05/27/16 11:31 AM
Got a great deal at Walmart yesterday.
by wtd
05/27/16 11:25 AM
2016 Camaro SS 5W-30 vs 5W-40
by mbar1
05/27/16 10:42 AM
Nissan Sentras
by Peakboy91
05/27/16 10:27 AM
ACDelco 75W-90 Syn Axle Lube, 13.7k mi OCI, 34k mi
by Emperors6
05/27/16 10:10 AM
Flux core welding wire
by Trotter
05/27/16 10:07 AM
LEVY, Timmytimmy, Peakboy91, TimingBeltKing, watergate528
57997 Registered Users
101 registered (69GTX, ABerns, 440Magnum, 901Memphis, 2015_PSD, 10 invisible), 1773 Guests and 301 Spiders online.
57997 Members
66 Forums
249484 Topics
#1159843 - 05/27/08 10:36 AM neutralizing brake fluid with water
JHZR2 Offline
Loc: New Jersey
Hello,
This doesnt really go into the brake fluid forum because it is multifaceted...
I was doing a brake flush yesterday on my saab and BMW. On the BMW, there is a 17 y.o. rubber hose that goes from the reservoir to the clutch master cylinder, which is only held on with a barb (no clamp on there as OE, because it is a low pressure system). Ive done the pressure bleed before, keeping presure low, around 10 psi, without issues. But the hose is 17 years old and a bit cracked around the end. It blew and got brake fluid all over the underside of the car.
My concern - paint/undercoat damage, as well as what dripped on my driveway. I took the car into the street and washed off everything that I could. I think I got it all. It made the water a whitish color.
Reading on the internet, it claims that water "neutralizes" brake fluid. But there is no explanation of why/how. Im not sure if it is purely a pH type neutralization, or if the claim is that the ethers/alcohols dissociate or break down in water.
So, will putting water onto brake fluid that is on paint prevent the fluid from damaging the paint? Does water help the brake fluid break down?
I used oil absorber on the spots on my driveway. I also used water on some of them, and it seems to have done well. Does water help destroy the toxicity or issues pertaining to brake fluid? Is there anything else that I should do to break it down?
Any thoughts would be most appreciated.
Thanks!!!
JMH
#1159857 - 05/27/08 11:08 AM Re: neutralizing brake fluid with water [Re: JHZR2]
eljefino Offline
Loc: ME
maybe since the brake fluid absorbs water it'll absorb so much it disintegrates.
You could always take a vial and throw some brake fluid and water in it, cap it, shake, and see what comes out. Then dribble it on some painted metal from the junk pile.
#1159897 - 05/27/08 12:13 PM Re: neutralizing brake fluid with water [Re: JHZR2]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
I'm pretty sure it's not nuetralizing in the chemical sense - more of a rinsing off. Sounds like you did the right thing. Where did the run-off go?
#1159978 - 05/27/08 02:09 PM Re: neutralizing brake fluid with water [Re: Pablo]
JHZR2 Offline
Loc: New Jersey
most of the spill is on my driveway, covered in some of the oil-dry stuff. What washed off went in the street, and is part of the pile of dirt and rotten leaves along my curb. All will be disposed - containment and disposal is easy - etching of my paint, undercoating, and rust on my car is not.
Thanks,
JMH
#1159980 - 05/27/08 02:11 PM Re: neutralizing brake fluid with water [Re: JHZR2]
Oldmoparguy1 Offline
Loc: Charlotte, NC
The good news is the brake fluid is biodegradable. Sounds like you handled it correctly..
Experience is a hard teacher, she gives the test before the lesson.
Oscar Wilde
#1160029 - 05/27/08 03:13 PM Re: neutralizing brake fluid with water [Re: Oldmoparguy1]
Kestas Offline
Loc: The Motor City
I don't think water neutralizes brake fluid as much as it dilutes the fluid. Brake fluid is an alcohol, and like any alcohol (such as antifreeze or vodka) it is perfectly miscible with water.
#1160047 - 05/27/08 03:50 PM Re: neutralizing brake fluid with water [Re: Kestas]
JHZR2 Offline
Loc: New Jersey
It is an alcohol with an ether or an amine. I did see a coloration change, but that doesnt necessarily mean much.
Its just funny that on the net the term "neutralize" is used a lot. Ive not run the experiment, so I dont know... dilution makes sense...
JMH
#1160058 - 05/27/08 03:59 PM Re: neutralizing brake fluid with water [Re: JHZR2]
Pablo Offline
You just keyed something in my brain - I'm foggy after the 3 day break. Of course, brake fluid contains amines, and the they are basic by nature. (And very agressive toward organic coatings). So in a sense, by dilution, enough water will "neutralize" the base......
