Repelling heat
by mjoekingz28
3 minutes 28 seconds ago
Wrong Dipstick? Honda Accord 2.4 Reading Low
by ThirdeYe
Today at 09:09 AM
radiator hose install, 08 Matrix.
by JustinH
Today at 08:56 AM
Bendix CT-3 Brake Pads
by RevelationLion
Today at 08:38 AM
Ever Have A Funniest Home Video Moment?
by coopns
Today at 08:20 AM
Parties
by AirgunSavant
Today at 08:02 AM
Static electricity accumulation of earth and human
by yvon_la
Today at 07:26 AM
18.14F this morning....
by Shannow
Today at 06:09 AM
Why it's a bad idea to ignore wheel-bearing noises
by Tegger
Today at 03:29 AM
Water decarbonization, does it work?
by FordCapriDriver
Today at 01:56 AM
Do I need a better tire for PNW trip?
by The_Eric
Yesterday at 11:51 PM
Turtle Beach PC headset hack
by asand1
Yesterday at 11:34 PM
hokieag07, Welder_Repairman, saredX, Corraun, kevinstoyhauler
58023 Registered Users
72 registered (0dyfamily, AlEinstein, bbhero, 69GTX, Al, adolan21, 7 invisible), 1835 Guests and 325 Spiders online.
58023 Members
66 Forums
249592 Topics
Page 1 of 3 1 2 3 >
#1157073 - 05/22/08 10:50 PM Question about GL4 vs GL5 gear oils.
aquariuscsm Offline
Loc: South Texas,USA
There`s something I`ve been wondering about concerning these two classifications of gear oils. GL4 is basically a "toned down" version of GL5 per se from what I understand (lower levels of certain additives),or am I uneducated about the chemistry of the two?
Reason I ask,is that if GL4 gear oils are "old technology" (I read that on some car forum somewhere,can`t remember where) and today`s GL5 oils are way more advanced than yesterday`s,would a GL5 (or at least one that`s rated GL5 and MT1) oil be better in a manual tranny because of better gear shock/load protection via extreme pressure additives? I keep hearing/reading about people using GL5 gear oils for years in their manual trannies with no issues at all. If a manual tranny has no ill effects (no brass syncho issue) would a GL5 oil be a better choice for gear protection?
If this makes no sense,I apologize in advance :^) I`m just trying to learn all I can.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Syntec 10W40/Fram Ultra
Amsoil MTG(tranny)
Amsoil 80W90 GL5(rear diff)
Mobil 1 ATF
Redline Water Wetter
#1157077 - 05/22/08 10:56 PM Re: Question about GL4 vs GL5 gear oils. [Re: aquariuscsm]
ewetho Offline
Loc: Kankakee, IL
Would use GL-4 in any trans that specs it. Never in a separate diff but in a trans.
They are different animals when tranmissions are concerned.
2004 Neon SE 2.0L Current Fill
Motorcraft 5W-30, Motorcraft FL-300
#1157086 - 05/22/08 11:19 PM Re: Question about GL4 vs GL5 gear oils. [Re: ewetho]
rationull Offline
Loc: California, USA
Not sure if this applies to the Z32 but I used to have a 280zx with MT. I remember reading that GL-5 gear oil would eat up the brass synchros so only GL-4 was acceptable. Don't know if it's true but IIRC I read it on the zcar.com forums and those guys are generally quite knowledgeable (at least on the S30/S130 forum, not sure about the others).
#1157088 - 05/22/08 11:23 PM Re: Question about GL4 vs GL5 gear oils. [Re: rationull]
rationull Offline
Oh and another note: good luck finding GL-4 in the chain auto parts stores. Around here only Napa had it, and the guys at the other stores didn't really know what it was or told me that GL-5 would be fine. Oh well, I like Napa better anyway.
#1157089 - 05/22/08 11:23 PM Re: Question about GL4 vs GL5 gear oils. [Re: rationull]
aquariuscsm Offline
What really got my curiosity going is that a guy on Twinturbo.net copied and pasted a Nissan TSB that said GL4 and GL5 gear oils are acceptable in the Z32 manual transmission and all other Nissan manual transmissions. Service manager at the Nissan dealer here said the same thing as well.
Amsoil MTG(tranny)
Mobil 1 ATF
#1157090 - 05/22/08 11:28 PM Re: Question about GL4 vs GL5 gear oils. [Re: aquariuscsm]
aquariuscsm Offline
Here`s a copy and paste of the post on tt.net:
TSB NTB 94-100 is titled "RECOMMENDED FLUIDS, LURICANTS AND CHEMICALS FOR NISSAN VEHICLES". For manual transmissions it specifies a GL-4 or a GL-5, 80W90(RWD), 75W90(FWD), mineral or synthetic. It further shows as a recommended aftermarket product Castrol Hypoid "C" or equivalent; Castrol Synthetic Gear Oil 75W90 P/N 00672 or Equivalent
Amsoil MTG(tranny)
Mobil 1 ATF
#1157091 - 05/22/08 11:29 PM Re: Question about GL4 vs GL5 gear oils. [Re: aquariuscsm]
rationull Offline
Huh. Any idea how far back that TSB goes? Like I said the advice I got was directed toward transmissions 13-26 years older than yours so it's possible it didn't apply after the S130. I'm also not sure whether it ever applied to the BorgWarner trannys that came in the turbo cars.
Or, it's possible that the stuff I read was only true for older GL-5 oils.
#1157098 - 05/22/08 11:43 PM Re: Question about GL4 vs GL5 gear oils. [Re: rationull]
aquariuscsm Offline
Here`s a link where there`s some discussion about GL4/GL5-MT1 gear oils:
http://64.233.167.104/search?q=cache:8E-...clnk&cd=5&gl=us
Amsoil MTG(tranny)
Mobil 1 ATF
#1157136 - 05/23/08 01:11 AM Re: Question about GL4 vs GL5 gear oils. [Re: aquariuscsm]
rationull Offline
Very interesting. Honestly it seems most likely to me that the GL-5 is probably fine. Saying it will wear out your synchros feels kind of like saying YB Pennzoil will turn to wax :) When I was trying to decide what gear oil to get for my Z I had yet to discover BITOG and was changing my oil every 3000 miles. But I digress.
The fact that GL-5 is recommended in the diff instead of GL-4 may imply that the GL-5 is actually better if there are no materials issue. Or maybe not.
I think I'd still go for what's manufacturer recommended if it's available (especially if you can find something good like Redline MT90 which is GL-4 rated) but I wouldn't be surprised if the real truth is GL-5 is fine and it doesn't really matter.
#1157247 - 05/23/08 09:15 AM Re: Question about GL4 vs GL5 gear oils. [Re: rationull]
gtx510 Offline
Loc: CA
I bet it says GL-4 or GL-5 because GL-4's are tough to find in the US.
I think all GL-5's are now MT-1 rated and should not eat yellow metals.
http://www.lubrizol.com/products/automotive-gear-oil/GL5.asp
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=729255
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=729289
#1157269 - 05/23/08 09:54 AM Re: Question about GL4 vs GL5 gear oils. [Re: gtx510]
MolaKule Offline
Loc: Iowegia - USA
"You are free to choose, but you are not free from the Consequences of your choice." Dr. Laura. smile
#1157337 - 05/23/08 11:16 AM Re: Question about GL4 vs GL5 gear oils. [Re: gtx510]
aquariuscsm Offline
VERY good link. That completely explained all the different classifications where the complete and total layman (me) could understand it. Thanks gtx510!
Amsoil MTG(tranny)
Mobil 1 ATF
#2124259 - 01/01/11 10:50 PM Re: Question about GL4 vs GL5 gear oils. [Re: aquariuscsm]
Kaie Offline
Loc: Kenmore, WA
Bringing this out of the depths.
After reading this thread and http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=729255
I'm still unclear... Here is a quote about GL-4 and GL-5 from that link.
Originally Posted By: MolaKule
GL-4; Specified for hypoid gear service under severe service but without shock loading. This classification is essentially obsolete but is still specified by some manual transmission/transaxle manufacturers. Implies an EP/AW additive package that contains 30% to 50% less S-P additives than the GL-5 service classification. Some Marine Gear Lubes fall into this classification, especially the full Synthetic Marine Gear lubes and specialty blenders MT lubes that use high levels of esters.
GL-5; Specified for hypoid gear service but with shock loads and severe service operation. Usually meets Mil-L-2105D and in most cases, is the multipurpose automotive gear oil. Most 75W90 to 75W140 grades meet the GL-5 classification. This grade has a high level of Extreme-Pressure additives that could be mildly corrosive to nonferrous parts, such as brass, bronze and aluminum parts. Most of the modern GL-5 lubes contain metal deactivators that prevents attacks by the extreme-pressure additives. In addition to EP additives, these lubes contain rust inhibitors, defoamants, friction modifiers, thickeners, and Viscosity Index Improvers.
If an oil claim both GL-4 and GL-5 is it more likely to be safe for a GL-4 application? I find 'GL-5 lubes contain metal deactivators that prevents attacks by the extreme pressure additives' a little sketchy.
For the record i'm looking at Motul Gear300 75w90 for my VW GL-4 tranny.
#2124463 - 01/02/11 08:22 AM Re: Question about GL4 vs GL5 gear oils. [Re: aquariuscsm]
Bluestream Offline
Loc: Waterloo, ON
Use the GL-4 for tranny. It wont let you down!
2000 Cavalier 2.2 A4
2000 VW Beetle 1.8T M5
2000 Ford Explorer 4.0 4X4
1991 BMW 735iL
"A fool and his money are soon parted" - Thomas Tusser
#2124586 - 01/02/11 11:07 AM Re: Question about GL4 vs GL5 gear oils. [Re: aquariuscsm]
flyingtoaster Offline
Loc: Rancho Cucamonga, CA
My big question on this subject is whether I can use the same hand pump for GL-4 and GL-5 when changing my trans and diff fluid, which one I should change first, and whether I should flush the pump with the fluid I'm about to use.
2006 Honda S2000
Rotella T6 5w40, OEM Filter
Amsoil MTF
Amsoil 75w140
ATE SL.6
Page 1 of 3 1 2 3 >
