I have a question regarding the operation of a floating brake caliper. From my understanding, on a floating brake caliper, hydraulic pressure is applied to the caliper piston to activate the inner pad. As the hydraulic pressure increases, the caliper moves and the outer pad is then engaged. Therefore, is it true that the inner brake pad is responsible for more of the braking power as the caliper piston directly contacts the inner pad and more pressure is applied?
The reason I ask is that I saw a commercial for NAPA's Adaptive One Brake Pads. According to them, the inner pad is formulated to provide extra braking power compared to the outer pad. If I am understanding the principles of caliper operations, then this is a great idea as the inner pad plays a greater role than the outer pad.
Therefore, am I understanding this correctly? Is this Adaptive One concept a gimmick, or does it actually have some merit? Has anyone tried these pads before? They are awfully expensive.
