Who watches the oil co's?
by Camprunner
07/25/16 02:44 PM
Magnetec "Edged" out?
by ARCOgraphite
07/25/16 02:34 PM
Let's talk RUM
by car51
07/25/16 02:23 PM
Any .257 Roberts Reloaders On The Site?
by 2015_PSD
07/25/16 01:18 PM
Making tacos at home
by Reddy45
07/25/16 12:41 PM
Wiring a new garbage disposal
by Hokiefyd
07/25/16 11:38 AM
Power Steering Fluid
by DWC28
07/25/16 10:07 AM
Troy-Built 4.5hp running problem
by Kestas
07/25/16 09:26 AM
Conventional oil instead of synthetic
by corndogzombie
07/25/16 08:05 AM
kohler courage 15 issues
by tomm22
07/25/16 07:58 AM
Small overlap crash test?
by Huie83
07/25/16 07:39 AM
Top Tier Fuels and Tailpipe deposits
by virginoil
07/25/16 07:20 AM
Ken_Clifton, HotDog15, curiousaboutoil, 01CAMRY, corndogzombie
58589 Registered Users
91 registered (Alfred_B, 4WD, 182RG, AIRJAC3, 87sammy, 2015_PSD, 9 invisible), 2155 Guests and 23 Spiders online.
58589 Members
66 Forums
252234 Topics
#1130952 - 04/16/08 08:19 PM Flushing GM 3.1L coolant
FL-400S Offline
Loc: Southeast
2003 Buick Century
2002 Chevy Malibu x2
2001 Chevy Malibu
2005 Cavalier x2 (2.2L ecotec)
So we have 4 GM 3.1L V6's in the family and the first one is probably having the intake gasket problems. Ive read that its due to dexcool eating the nylon or silicone gasket, and that a new metal gasket will hold up better. I am thinking that I need to flush out the other three and probably our cavaliers to prevent this from happening (refill with G-05?). How do I go about doing this on the 3.1L's? Is there a good tutorial online?
Edited by FL-400S (04/16/08 08:19 PM)
#1130990 - 04/16/08 09:15 PM Re: Flushing GM 3.1L coolant [Re: FL-400S]
wapacz Offline
Loc: MI
From my understanding it is from a mix of problems. One being the dexcool. The next being bad gasket design. Then the third being bolts loosening up. By themselves there may be small problems. But mix them all togther and you have the perfect storm.
The engines in the cavaliers aren't know for bad gasket design or bolts loosening and such they don't have a problem with dexcool.
Edited by wapacz (04/16/08 09:16 PM)
#1131094 - 04/17/08 01:21 AM Re: Flushing GM 3.1L coolant [Re: wapacz]
dwendt44 Offline
Loc: Central Wisconsin
Those that I've worked on, it was easier to just loosen the lower radiator hose and drain the system that way.
It comes out fast at first.
Wapacz is correct. The factory dexcool is only part of the problem. Plastic gaskets and low torque specs are also major causes of manifold problems.
9 ft lbs. is ridiculously low.
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
#1131534 - 04/17/08 04:30 PM Re: Flushing GM 3.1L coolant [Re: dwendt44]
mstrjon32 Offline
Loc: Elkridge, MD
Open the lower radiator hose, turn on the heater, and stick a garden hose into the radiator, run it that way for a while, then drain all the water out and fill it with distilled water and a coolant mix.
#1131666 - 04/17/08 07:45 PM Re: Flushing GM 3.1L coolant [Re: mstrjon32]
Jim Spahr Offline
Loc: Lexington, SC
If you have Dexcool , you need to change it out to the new Prestone 'either-or' coolant. It you are determined to use the Dexcool, be sure to change out and flush every year. The big selling point on Dexcool was that it was Long Life. Not so. I have a 1994 Chev Impala SS V8 that came with the green coolant. I was convinced to 'upgrade' to the new long life Dexcool that came in the 1996 Impala's. Big mistake. The two interacted and turned into a brownish slush in the rad, the block, the heater core, and the reservoir. I drained and flushed the heater, the engine block, and the radiator three times and still had brown sludge in the coolant. I drained and flushed it again and drove it with straight water for a day and drained and flushed it one last time. It still showed some sludge, but I went ahead and put in 50/50 coolant and distilled water. BTW my car with an LT1 V8 has drain plugs on either side of the engine to allow you to drain the block. the first time I tried to open these two drains, they were so clogged, they wouldn't drain. I am saying -don't just drain the radiator. GM still won't admit the mistake of using dexcool in the 1996+ cars.
Chevy Impala SS 1994 LT1 5.7L V8
Chevy Blazer LS 4WD 2003 4.3L V6
Chevy Lumina 4 door 1996 3.1L V6
#1131729 - 04/17/08 09:04 PM Re: Flushing GM 3.1L coolant [Re: Jim Spahr]
wapacz Offline
Loc: MI
I wont say dex is the best stuff ever but it really isn't as bad as some people make it out to be. It has two large problems which only come about if the system wasn't design right for it. One is that the gasket material needs to be the right kind or it is weakened by dex. The other is that if a good amount of air gets into the system, it sludges up.
If I remember right in 2004-2005 the finally fixed the gasket issue. I forget when they went to a seal cooling system. Pretty sure you can tell if you look at the over flow and see if it has a screw on top.
#1131733 - 04/17/08 09:11 PM Re: Flushing GM 3.1L coolant [Re: FL-400S]
wapacz Offline
Loc: MI
 Originally Posted By: FL-400S
2003 Buick Century
2001 Chevy Malibu
Also now that I think about it the the interval for dexcool is 5 years. So all of them except for the cavaliers need it if it hasn't been done yet.
#1131735 - 04/17/08 09:16 PM Re: Flushing GM 3.1L coolant [Re: wapacz]
onion Offline
Loc: kansastan
IMO, you'd be crazy to refill with Dexcool. I prefer G05 as a replacement.
The invisible and the imaginary look exactly the same.
#1131787 - 04/17/08 11:05 PM Re: Flushing GM 3.1L coolant [Re: onion]
TomdieselS Offline
Loc: Houston, TX
I've done 2 LIM repairs, 97Malibu & 98 Lumina, 3.1's, both had block drains on both sides. Front easy to access, couple inches away from oil filter, rear is *&%$%; requires removal of RF wheel, then you can alternately see/manipulate. Be forewarned, if you allow the problem to fester and experience any overheating or other problem that might require removal of heads; the 'improved' LIM gasket is NOT included in most headsets because GM didn't recall it. So if you (or your mechanic) needs a headset, ask many questions first. I recommend the Felpro LIM gasket, it's got the best chance of stoping the problem.
#1132376 - 04/18/08 09:36 PM Re: Flushing GM 3.1L coolant [Re: TomdieselS]
onion Offline
Loc: kansastan
+1 on everything Tom said.
And put locktite on the bolts.
