Highway conditions in the Midwest
by grampi
07/01/16 08:22 AM
Indian head shellac or something?
by JHZR2
07/01/16 08:15 AM
Need Help! Tombstone
by AirgunSavant
07/01/16 07:38 AM
Truck bedliner - pros and cons and option
by ryan2022
07/01/16 07:33 AM
Delo 400 SD 15w30 From Amazon
by AirgunSavant
07/01/16 07:27 AM
GM LS 6.0 Suggestion
by akcooper9
07/01/16 06:58 AM
Penrite 5W-30 Full Synthetic
by KL31
07/01/16 06:08 AM
PP HM at Walmart
by dlundblad
07/01/16 04:55 AM
74/76mm x 15 Flutes
by Merkava_4
07/01/16 04:33 AM
Autozone - Pennzoil with the PP - Rebates
by Kwuality
07/01/16 03:29 AM
Old Toyota
by artbuc
07/01/16 03:18 AM
Shell Helix Ultra 5W-20 & 0W-20 in Australia
by SR5
07/01/16 03:03 AM
EdandSherry, Shalmaneser, Shipmate29, garytcosta, lifteddiesel90
58332 Registered Users
86 registered (ac_tc, ARCOgraphite, badtlc, AirgunSavant, b1amgm47, AEHaas, 6 invisible), 1582 Guests and 12 Spiders online.
58332 Members
66 Forums
251084 Topics
#1117845 - 03/30/08 04:43 AM 1998 Toyota Camry Sludge Engine oil change?
Kitto Offline
Loc: USA - IL
Hi, my friend have 1998 Toyota Camry I4 which is infamous for sludge. I look through the oil cap and sure it's not pretty. I don't know how bad is the sludge, maybe just coat a thin layer, maybe a lot, I don't know... If I want to help out with oil change, what should I do and what should I look for?
Choices:
1.) PP (my stash)
2.) QS Horsepower (my stash)
3.) Valvoline SynPower (my stash)
4.) Valvoline Maxlife Semi-Syn (need to buy)
5.) Pennzoil Dino (need to buy)
I don't mind to use more expensive syn oil as I got those on sale. I just worry if I use syn oil, will the sludge fall apart and cause problem which is what I don't want. Oil change history unknown... probably yearly or semi-yearly oil change b4... millage around 95000 miles. Thanks all!
Edited by Kitto (03/30/08 04:46 AM)
Current:
95 Toyota Camry I4 5MT 180k+
99 Toyota Camry I4 4AT 100k+
95 Subaru Legacy H4 5MT 165k+
Gone:
96 Subaru Legacy, 94 Acura Integra, 96 Mazda Miata
#1117849 - 03/30/08 05:20 AM Re: 1998 Toyota Camry Sludge Engine oil change? [Re: Kitto]
ZZman Offline
Loc: Michigan
Use Auto-RX following recommendations for heavy sludge. Then use syn oil after that.
PP would be good choice.
Try using Napa Gold or Purolator Pure One filters
Edited by ZZman (03/30/08 05:25 AM)
2002 Buick Regal GS (3.8 Supercharged) PP, Pure 1 filter
2008 Sebring Hardtop convertible (2.7) PP, Pure 1 filter.
2006 Kawasaki Vulcan 900 LT
#1117850 - 03/30/08 05:22 AM Re: 1998 Toyota Camry Sludge Engine oil change? [Re: ZZman]
Kitto Offline
Loc: USA - IL
I will try to skip Auto-Rx because it is not my car, but a good suggestion.
Current:
Gone:
#1117851 - 03/30/08 05:27 AM Re: 1998 Toyota Camry Sludge Engine oil change? [Re: Kitto]
ZZman Offline
Loc: Michigan
You might want to keep the first few oil changes short then. Maybe 3,000-5,000 miles so the oil will have enough additives in it to work on the deposits.
#1117855 - 03/30/08 05:45 AM Re: 1998 Toyota Camry Sludge Engine oil change? [Re: Kitto]
momomeister Offline
Loc: USA
+1 on the AutoRx, with Castrol GTX. We used to have a 98 Sienna, which we got used from my sister-in-law.
Using the AutoRx should slowly dissolve the sludge, based on what has been said here.
Personally, I'd be wary as if something happens to the engine due to the sludge, you don't want to be blamed for it.. My 2 cents...
#1117857 - 03/30/08 05:55 AM Re: 1998 Toyota Camry Sludge Engine oil change? [Re: momomeister]
H2GURU Offline
Loc: Boston
That 4 cyl. is NOT the sludger. The 3.0 is the one that had the issue and only for several model years. That 4 cyl. is bullet-proof with average care as many get to OVER 250,000 miles! If there is sludge there, neglect is probably the cause? A diesel type oil such as DELO 10W-30 IS what I would use as this may clean it up somewhat. A little varnish coating, although annoying, is normal and immpossible to get rid of unless a high grade synthetic was used from day one.
#1117868 - 03/30/08 06:43 AM Re: 1998 Toyota Camry Sludge Engine oil change? [Re: H2GURU]
simple_gifts Offline
Loc: Middlesex County CT
The issue involved some 4 cyl.
2003 Echo >392K miles; Castrol 5W-50
2006 B2300;108K;ALM
Please conserve paper; it is not like it grows on trees.
#1117878 - 03/30/08 07:05 AM Re: 1998 Toyota Camry Sludge Engine oil change? [Re: simple_gifts]
ZZman Offline
Loc: Michigan
#1117974 - 03/30/08 09:36 AM Re: 1998 Toyota Camry Sludge Engine oil change? [Re: ZZman]
Curtis Newton Offline
Loc: Colorado
On the Toyota/Lexus products, there is a baffle where you fill the oil at and if what you are seeing is that black thin (kind of gritty looking) coating on there, that is typical.
I have used Mobil 1 and now PP since my wife's RX330 was new. We had a 1999 Lexus ES300 prior to our RX and it had the same black coating as did my Mom's 1999 Camry.
On our RX, at the 90K interval, the shop pulled the valve cover and said the engine was very clean. So, I would advise you to pull the valve cover to get a good indication of if the engine has any sludge issues. As usual, YMMV.
'12 Jeep Grand Cherokee V6 AWD, Pennzoil blend, 45K
'04 Lexus RX330 AWD, Pennzoil HM blend, 210K
'77 MG-B, MaxLife HM 10W40, 40K
One filter, two OCI
#1117975 - 03/30/08 09:40 AM Re: 1998 Toyota Camry Sludge Engine oil change? [Re: Curtis Newton]
Triple_Se7en Offline
Loc: 1/2 hr. north of Detroit
If your friend has limited money, just use a correct viscosity high mileage oil and change every 3K/twice a year - including filter.
#1117976 - 03/30/08 09:41 AM Re: 1998 Toyota Camry Sludge Engine oil change? [Re: Curtis Newton]
dargo Offline
Loc: USA
100% correct! Most people think they have sludge and freak; when most times they do not.
#1118040 - 03/30/08 11:21 AM Re: 1998 Toyota Camry Sludge Engine oil change? [Re: dargo]
csaxon Offline
Loc: USA
THIS IS NOT SLUDGE!
This is a factory applied coating.
#1118169 - 03/30/08 02:20 PM Re: 1998 Toyota Camry Sludge Engine oil change? [Re: Triple_Se7en]
Durango Offline
Loc: Los Angeles, California
Kitto,
Like the others said is too FLUSH out the engine well and then convert to use a synthetic oil of your choosing. Many brands on the market that'll give that Toyota a good cleaning inside. My 89' Camry 4 cylinder has had/been useing Mobil 1 ever since I've been able to buy it.
Good luck,
Durango
