Greyhound Chonda Cold Start
by SEMI_287
06/18/13 06:39 PM
Saw a big dog tic on my pillow
by TechnoLoGs
06/18/13 06:24 PM
AAP job question...
by Tuffy1760
06/18/13 06:15 PM
Castrol Edge 10W-30 $4 at Autozone
by mattwithcats
06/18/13 05:38 PM
Power steering fluid question '98 Continental
by CHL59
06/18/13 05:12 PM
dog food recall
by spasm3
06/18/13 04:58 PM
Ever use Regenix or ovation for hair loss?
by daves66nova
06/18/13 04:26 PM
Chevy Volt oil analysis at 26,800 miles - UOA
by blackman777
06/18/13 04:09 PM
'06 Supercharged GTO-What 1 Qt. to go w/5 Qt. VR1?
by Turk
06/18/13 04:07 PM
Bought items direct from China on eBay?
by mrsilv04
06/18/13 03:44 PM
FRPP BOSS 302 head options
by bdcardinal
06/18/13 02:35 PM
2010 Rav4 I4 transmission maintenance?
by Brons2
06/18/13 02:33 PM
gl10, ufomorme, krz, colburnr, richard8988
45901 Registered Users
136 registered (2James1, 99Saturn, 440Magnum, 97tbird, 2010_FX4, 04SE, 9 invisible), 1586 Guests and 254 Spiders online.
45901 Members
64 Forums
195316 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
Page 1 of 7 1 2 3 4 5 6 7 >
#1107726 - 03/17/08 10:01 AM M1 0W40...GM 6.0L....24,000 miles OMG!!!
Bambam Offline
Loc: CT
2005 GM 2500HD 6.0L auto 4x4 80,000 miles on truck,and yes 24,000 on the oil using a supertech filter.
My nephews truck,I change the oil when he brings it to me,which has been 3 times in the trucks life. So obviously he doesn't do anything but beat on this thing. I changed the airfilter after this sample(1st time for this motor). It was also at least 2 quarts low and ticking when he pulled in..
Iron...203
Chromium..5
lead.....365
copper...130
tin.......0
aluminum...21
nickel...6
silver....0
silicon...43
boron.....114
sodium.....53
magnesium...37
calcium....3261
barium.....0
phosp.....955
zinc....1226
fuel <1
vis@100c - 24.86
coolant- yes
Staveley services did analysis and commented = suspect abnormal main/conn rod bearing wear. severe level of oxidation and nitration products detected. sodium levels high.
I didn't do a TBN,what was the point right?? Other than abuse what do you see happening to this in the short term,is there any future???
07 DMAX CC 4x4
265 Goodyears
Bilstein 5100's
T-C pump rub fix
EGR Blocked
PCV rerouted
efi live tuned
Student of dnewton's dino teachings
#1107729 - 03/17/08 10:06 AM Re: M1 0W40...GM 6.0L....24,000 miles OMG!!! [Re: Bambam]
steve20 Offline
Loc: NJ
I'd give your nephew a spanking
hooked on TORQUE-----there is no substitute---
#1107736 - 03/17/08 10:13 AM Re: M1 0W40...GM 6.0L....24,000 miles OMG!!! [Re: Bambam]
Turk Offline
Loc: MN
Oh man...
I would have him run it a while and use something to clean out that motor. Then change the oil & filter soon after that.
On the following oil change I would then do another UOA to see where the motor is at...
btw: If he's gonna keep it, change all of the drivetrain oils soon!
03 GMC Sierra 4x4 188k PU
00 Saturn SL2 89 YO Lady Car. 65k Miles! PU
97 Camry 187k ML Full Syn
06 GTO Supercharged 6M 500HP/TQ! *Amsoil Z-Rod*
#1107743 - 03/17/08 10:16 AM Re: M1 0W40...GM 6.0L....24,000 miles OMG!!! [Re: steve20]
buster Offline
Loc: NJ
WOW. This is the danger you run when trying to do extended drains. Obviously there is a coolant leak and it destroyed this oil. Take the truck in asap with this analysis.
#1107747 - 03/17/08 10:19 AM Re: M1 0W40...GM 6.0L....24,000 miles OMG!!! [Re: steve20]
addyguy Offline
Loc: Canada
Well, if there's ANY hope for this engine, you need to fix the coolant leak first. With only 53 for sodium, it doesn't seem to be too bad a leak, but it has done a number on the engine.
Fix that, do two or three short flush runs (1-2k miles) with a cheap dino 10W-40; then see how the engine is running. If a slightly thisker oil is used (10W-40 or 5W-40), and the level isn't allowed to go low again, this truc might have a suprising amount of life left to it...GM engines, if nothing else, are fairly tough....
No offense, but why the heck would anyone abuse a top-of-the line, 3 year old truck like this? In Canada, that model of truck HAS to be somewhere around $45-60k new, with all the options - does this guy really have enough money to replace a truck like this every 3-4 years?
2003 Mazda Tribute LX V-6, 147K miles.
Oil: GTX/QSUD/STP/MM frankenblend + PL24651.
#1107749 - 03/17/08 10:21 AM Re: M1 0W40...GM 6.0L....24,000 miles OMG!!! [Re: buster]
glennc Offline
Loc: Colorado
How about insolubles?
#1107760 - 03/17/08 10:36 AM Re: M1 0W40...GM 6.0L....24,000 miles OMG!!! [Re: glennc]
REDDOG Offline
Loc: Hermon, ME
I would not jump to the conclusion there was a coolant leak just yet-what was the potassium level?
REDDOG
"Many on here
are OCD to some degree,
that's WHY we flock to this
site!"-OVERKILL
#1107768 - 03/17/08 10:48 AM Re: M1 0W40...GM 6.0L....24,000 miles OMG!!! [Re: REDDOG]
Turk Offline
Loc: MN
What does coolant = yes mean? What amount?
#1107769 - 03/17/08 10:52 AM Re: M1 0W40...GM 6.0L....24,000 miles OMG!!! [Re: Turk]
badtlc Offline
Loc: KC
This thing needs some serious AutoRX luvin once the coolant leak is stopped.
2007 Ford Escape XLS 2.3L ATX Kendall GT1 Blend 5w-20
2012 Mazda 3i Skyactiv PP 0w-20, 6spd MTX Redline MTL
#1107771 - 03/17/08 10:57 AM Re: M1 0W40...GM 6.0L....24,000 miles OMG!!! [Re: Turk]
REDDOG Offline
Loc: Hermon, ME
That's why I'd like to know the potassium number-I've seen labs flag coolant just because the sodium is high. This looks like it could be an air intake issue if the potassium isn't elevated.
Silicon, chromium, nickel, iron all elevated.
Regardless of cause this oil is totally destroyed-and the engine is looking to follow suit.
REDDOG
"Many on here
site!"-OVERKILL
#1107780 - 03/17/08 11:21 AM Re: M1 0W40...GM 6.0L....24,000 miles OMG!!! [Re: REDDOG]
addyguy Offline
Loc: Canada
Bambam;
What oil did you use on the change? More M1 0W-40?
#1107781 - 03/17/08 11:22 AM Re: M1 0W40...GM 6.0L....24,000 miles OMG!!! [Re: REDDOG]
Bambam Offline
Loc: CT
Titanium,vanadium and potassium all 0.
All drive-line fluids are original,except the rear which blew up winter of 06...
I know he pays 700+ a month truck payment but he beats the snot out of everything he owns...Some people get it ,some don't....He DOES NOT!!! I call him religiously about stopping by for an oil change,I started asking last october,he said the light was on and be by soon...
07 DMAX CC 4x4
265 Goodyears
Bilstein 5100's
T-C pump rub fix
EGR Blocked
PCV rerouted
efi live tuned
#1107785 - 03/17/08 11:28 AM Re: M1 0W40...GM 6.0L....24,000 miles OMG!!! [Re: Bambam]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
Viscosity went up a tad.
#1107795 - 03/17/08 11:41 AM Re: M1 0W40...GM 6.0L....24,000 miles OMG!!! [Re: Pablo]
o2man98 Offline
Loc: Manitowoc, Wisconsin
Someone that forgets or does not care about changing oil is a good candidate for an EaO oil filter IMO. What's $15 every 24,000 miles???
#1107796 - 03/17/08 11:42 AM Re: M1 0W40...GM 6.0L....24,000 miles OMG!!! [Re: REDDOG]
Turk Offline
Loc: MN
...but, but, but it's Mobil 1!
I wonder how he drives this thing. It is a good motor. TBN would've been great to know for a reference point.......
Get 'er in like Buster mentions and go from there.
I want to see the future of this engine - can ya keep us posted along the way and further in the future...??
