Gas prices do the ol' switcheroo
by grampi
9 minutes 44 seconds ago
Possible Valve adjustment needed?
by andrewp1998
38 minutes 5 seconds ago
Hey Dad, can I have some corn syrup, corns starch
by Shannow
Today at 06:47 PM
Idling question
by thunderfog
Today at 06:39 PM
Lodge Sportsman Grill
by hatt
Today at 06:07 PM
2016 Honda Civic factory filter, CUT OPEN
by car51
Today at 05:34 PM
Fishing reel drag grease
by bernau
Today at 04:26 PM
Sulfated Ash, wt%, ASTM D 874 test questions
by mbacfp
Today at 04:02 PM
HD radio
by 007
Today at 03:51 PM
Front end repair
by possum328
Today at 03:49 PM
Purolator 10111 Red Can
by FordBroncoVWJeta
Today at 03:30 PM
Carquest #R85372, 2013 E-250 van, 4,500k
by car51
Today at 03:03 PM
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
84 registered (8o8is, ActiveWolf, 2009Edge, 182RG, 123Saab, ag_ghost, 6 invisible), 1850 Guests and 7 Spiders online.
58632 Members
66 Forums
252417 Topics
#1104883 - 03/12/08 07:17 PM Duramax Oil and Lube Question
JRDM Offline
Loc: Michigan
Bought my first diesel, a used 06 Duramax with 28,000 miles. Considering syn oil, either Rotella or Amsoil. Amsoil makes claims of extended miles for oil change which offsets some of the cost. I can't find any extend miles claims for Rotella syn. Anyone have any info on Rotella or Amsoil syn oil change intervals?
Does anyone know where I can get a lubrication skematic or list. I didn't get one with the truck
#1104900 - 03/12/08 07:39 PM Re: Duramax Oil and Lube Question [Re: JRDM]
bmwtechguy Offline
Loc: South Carolina
You should be ok to start out with 10k miles on RTS (Rotella syn). Amsoil AME would probably be ok for 1 year or 15k miles. I would consider using that oil with an EaO oil filter for that long of an interval as well. And also would recommend a used or drain oil sample be sent off at some point to see how your engine and oil/filter are doing at those intervals. Two other great synthetic oils to consider would be Mobil 1 TDT 5W-40 at WM in gallon jugs and Schaeffers 5W-40 syn, available from the Schaeffer rep here, named salesrep (Mark).
#1104970 - 03/12/08 08:49 PM Re: Duramax Oil and Lube Question [Re: bmwtechguy]
junebug Offline
Loc: Minnesota
I was in Walmart today and did not see any Mobil 1 TDT 5W-40 in the local Supercenter,and it is the newest and largest one in the state of Minnesota!
#1105174 - 03/13/08 05:40 AM Re: Duramax Oil and Lube Question [Re: junebug]
Bambam Offline
Loc: CT
It says Turbo Diesel Truck 5w40 on it and you being in Minnesota I would almost guarantee they stocking it..
Enjoy the DMax,they are GREAT!
07 DMAX CC 4x4
265 Cooper AT3's
Bilstein 5100's
T-C pump rub fix
EGR Blocked
PCV rerouted
efi live tuned
#1105595 - 03/13/08 06:11 PM Re: Duramax Oil and Lube Question [Re: Bambam]
LateArrivalforLSU Offline
Loc: Louisiana
Get you some Rotella syn 5W-40. It's a good HDEO.
- 2008 Chevy 2500 HD
- LMM Duramax and Allison
- Flo~Pro Turbo Back & EFI Live
- 40 ft. Keystone Avalanche 5th Wheel
#1105604 - 03/13/08 06:21 PM Re: Duramax Oil and Lube Question [Re: Bambam]
Johnny Offline
Loc: Retired | Wausau, WI
You would be surprised what the Wal-Marts in Minnesota and Wisconsin don't stock. My local Wal-Mart does not carry 5W-20 in any brand. Just depends on the department manager, store manager, and regional manager. And believe me, they have some real winners up here.
#1105868 - 03/14/08 06:55 AM Re: Duramax Oil and Lube Question [Re: Johnny]
dnewton3 Offline
Loc: Indianapolis, IN
JRDM - welcome to the site!
For extended drain intervals (the REAL reason to go with synthetics in my opinion), you can't hardly beat the ones mentioned. Of the several brands (Amsoil, Mobil, Shell and Schaeffers), I'd have to say the RTS is possibly a "best buy" to coin the Consumer Reports phrase, because it typically turns in very good wear results and usually can be found at Wally World for a moderate price. On a performance/dollar ratio, it's flat hard to beat. The others are probably a bit on the higher end of development, but in no way is that meant to be a slight on the RTS. I personally use RTS, but I only drive around 10k miles a year in my truck (Dmax/Allison), and so I typically O/FCI once, and use UOA's as verificaiton. If I drove a lot more miles per year, I'd strongly consider a higher end product, and most likely use bypass filtration too.
I would suggest you analyze what your driving patterns are going to be. Weigh your typical mileage per year against the cost of the oil changes, including the full flow filter options as well. Let the math and UOA's guide your conscience, not rhetoric.
The upside to a Dmax is that they seem to be very easy on oil; they don't shear it much and they don't seem to contaminate much. In this regard, nearly any oil will perform well in a Dmax.
Some of the core concepts many of us here at BITOG try to educate newcomers on are oil analysis and "synthetics". These are probably two of the most mis-understood and often nearly mythical topics in the world of lubricants. I, for one, have learned a great deal from contributors here like Johnny, Bruce381, Pablo, Gary Allan, The Critic, and many others. WE DON'T ALL AGREE ALL THE TIME, TO SAY THE LEAST. But if you take away one thing from this site, please try to help educate others with thought provoking facts, rather than lore and "they say that ..." generalizations. I think it's good when we all share experiences and facts. But be careful to seperate opinions from facts. There's nothing wrong with opinions, but they sometimes take on a "herd" mentality, and grow in strength without merit.
Rather than my rambling on here about "synthetics", use the search funciton on this site (it actually works, contrary to the actions of some members) and spend time studying the UOA diesel section and this section. You'll learn a lot.
However, if you want a "Synthetic Oil for Dummies" quick answer to your post, I'll say only this:
(Caution! the following is my opinion!)
There are plenty of good brands of oil out there, in many variations of weight, price, and performance enhancing attributes. If you can get out of the "gotta change oil at X,xxx miles" mentality, then UOA's and synthetics will pay you back in spades. If not, then a conventional group II oil will do a wonderful job for short OCI's, and there are millions of vehicles in service right now as proof. Synthetic lubricants and UOA's and Bypass Filtration are tools; if you don't use them correctly, they are a waste. But if you can, you will reap the benefits for years to come.
Again, welcome; you've officially entered the world of lubricant insanity. \:\!
Edited by dnewton3 (03/14/08 07:00 AM)
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#1106097 - 03/14/08 01:39 PM Re: Duramax Oil and Lube Question [Re: dnewton3]
BoiseRob Offline
Loc: Idaho
x2 to what dnewton3 said. You can also check out other Duramax owners at dieselplace.com. It's a website for us Duramax guys... \:\!
Rob
#1106306 - 03/14/08 06:55 PM Re: Duramax Oil and Lube Question [Re: BoiseRob]
Loc: Louisiana
Nice to see you here BoiseRob. There's starting to be a collection of Diesel Place guys over here
#1106420 - 03/14/08 09:35 PM Re: Duramax Oil and Lube Question [Re: LateArrivalforLSU]
BoiseRob Offline
Loc: Idaho
Heck ya. Schaeffer Oil, Duramaxes and BITOG... \:\!
#1106853 - 03/15/08 06:18 PM Re: Duramax Oil and Lube Question [Re: BoiseRob]
dntfxr77 Offline
Loc: sportsman's paradise
Yeah, count me in too! I'm running RTS but may check out Shaeffer's at my next OC. Moly can't be a bad thing...
2007 Chevy 25000HD Classic LBZ Duramax/Alison
#1106885 - 03/15/08 07:36 PM Re: Duramax Oil and Lube Question [Re: dntfxr77]
Loc: Louisiana
dnt,
You get my PM on TDP?
Off topic here....you watching the SEC tourney? Go Hogs!!!!
#1106894 - 03/15/08 07:53 PM Re: Duramax Oil and Lube Question [Re: LateArrivalforLSU]
dntfxr77 Offline
Sure did Arka,thanks.
Thats the thread I made my first post on, I wish I could have got in touch with Ralph a few weeks before, but I'll definitely look him up for future needs.
Oh yeah and uh, I'll give a ya a lil' Pig Suey!;D
Edited by dntfxr77 (03/15/08 07:54 PM)
#1107027 - 03/15/08 11:06 PM Re: Duramax Oil and Lube Question [Re: BoiseRob]
-SyN- Offline
Loc: Tornado Alley
Just come back from our local WM. M1 Turbo Diesel Truck 5w40 Gal Jugs was on the mark down shelf for $19.95 a gal. The clerk sayed they are going to stop stocking it. Everytime I went into the store the shelf was empty. They could never keep the gal jugs in stock. Now they are going to quit stocking it. I'll never understand this Company!!
14 Ram 5.7L->PUP 5W-30 & SRT 0W-40 Combo!
08 Ford F150 FX4-->PP 10W-30
12 Ford Edge-X2 Limited & SE->PP 5W-30
#1107732 - 03/17/08 10:08 AM Re: Duramax Oil and Lube Question [Re: -SyN-]
cowhorse01 Offline
Loc: Oceanside, California
Hey guys....also coming over from DMax Diesel place. I was going to ask question about RTS vs.Amsoil for 10,000 OCI, but I got my answer. I will also second the fact that no Mobil 1 TDI to be found anywhere. One auto parts store had it, and they were going to quit stocking it also. I currently use Amsoil, but was lookig for a good oil that I could just go buy at the store instead of having to order every time....oh well.
Byron
1997 F-350, 7.3 PSD, Heavily Modded, Rotella T 15w-40
2015 Kia Soul Plus
2012 34' Sundance by Heartland TT
