How much can you figure out from the wear metal results from a UOA?
Below are results of UOA's from BMW M54 engines taken between about 7500 and 13,500 miles, all done by Blackstone. Oils are about the same SAE grade, and API SL or SM.
Oil A Al 4 Fe 37 Cu 3 Pb 1
Oil B Al 4 Fe 18 Cu 7 Pb 9
Oil C Al 5 Fe 10 Cu 11 Pb 3
Oil D Al 3 Fe 18 Cu 5 Pb 1
Oil E Al 4 Fe 37 Cu 3 Pb 1
Oil F Al 8 Fe 15 Cu 14 Pb 2
Oil G Al 4 Fe 13 Cu 5 Pb 2
Oil H Al 7 Fe 11 Cu 13 Pb 2
Oil J Al 2 Fe 8 Cu 5 Pb 1
Oil K Al 3 Fe 13 Cu 5 Pb 1
So here's the quiz questions:
1.Which oil is a 10W-XX?
2.Can you group the oils by mileage? Under 10k? 10k to 12k? Above 12k?
3.Can you tell which four of these samples are from the same car?
4.Can you tell which three of these samples are from the same oil?
5.Can you tell which three of these samples are from the another oil?
6.Which manufacturer's oil is not represented - Amsoil, Castrol, Mobil, Redline, Royal Purple, or Shell?
Have fun playing and no fair cheating by searching in the UOA section!
