The transmission in the Trans Sport starting giving troubles about 20,000 km ago - did a drain and fill which appeared to solve it, but now it's kaput.
Forward gear engages, although with all the snow here I haven't road tested it to see if all the gears are present. Reverse does not engage - there is no "thump" like the rest of the gears and I can hear a scraping noise for as long as I stay in that gear. What are some possible causes? Reverse piston seal? Clutch?
If you think a rebuild can save this transmission, what are some good kits? There's the stock AC Delco kit, but I've heard that the OEM materials allow for slippage. There are supposedly aftermarket rebuild kits that eliminate this slippage and you have to unplug the PWM solenoid; anyone know who makes these and if they would be a better choice?
