I have been tooling with the idea of using Pennzoil MV ATF. So, in these questions I have, I decided to call Shell. I called a number I found for the tech department. I actually spoke to an oil blender. I asked a few critical questions in my opinion. One of which was in regards to settling of the additive package in the oils they sell....ie. Pennzoil Platinum.
Well, the point of the thread is this. I was told by the blender that Pennzoil Multi-vehicle ATF is NO LONGER a synthetic blend ATF. I was also told in short that the reasoning behind this is that testing showed that they were able to meet the needs of the suggested specs with a conventional base fluid. What I really heard was that they were able to cut cost and still charge the same amount of money for an inferior ATF to what they were putting out.
He also stated indirectly that the newer formulation was inferior to the syn blend, which I already had assumed. He never directly stated this, but did state that they wanted to meet manufacturer specs, and not necessarily exceed them.
Sounds like I will not be using this ATF anymore!!!!
