Undercarriage Rust Management
by OpenClose
05/26/16 11:31 PM
New used tires
by gfh77665
05/26/16 11:29 PM
Hybrid and ROI (Return Of Invesment)
by HTSS_TR
05/26/16 11:14 PM
Best Walmart stocked wiper blades?
by aquariuscsm
05/26/16 10:54 PM
What Ohm antenna wire to use?
by daves66nova
05/26/16 10:46 PM
Turtle Wax Passed The Test
by RevRider
05/26/16 10:46 PM
Total FLUIDMATIC G6 SYN ATF, 13.7k mi OCI, 34k mi
by Emperors6
05/26/16 10:17 PM
Honda NC700X Red Line 10W30, ~5,000 miles
by bulwnkl
05/26/16 10:13 PM
If you liked the Fram AirHog Filters
by rrounds
05/26/16 10:07 PM
Most advanced oil on the shelf?
by Jetstreamz06
05/26/16 09:41 PM
99 Dodge Dakota Brad Penn Superior Fuel Efficient
by Hullthumper
05/26/16 09:39 PM
2014 Cruz LT loaner..
by dblshock
05/26/16 09:21 PM
watergate528, iamtheanimal, 1991300sl, Rdyno, Darsahn
57993 Registered Users
66 registered (97prizm, 66chevelle, 87sammy, 901Memphis, 2015_PSD, 5 invisible), 1081 Guests and 334 Spiders online.
57993 Members
66 Forums
249465 Topics
#1088378 - 02/18/08 09:48 AM Brake fluid to lubricate Rubber bushings?
kartracer55 Offline
Loc: NJ
If brake fluid does not damage rubber seals throughout the brake system, could I use it to lubricate dried out bushings on a car? A lot of guys spray them with PBblaster but I can imagine this will deteriorate the rubber, no?
Thanks
Jim
RUPAUL 08!
#1088401 - 02/18/08 10:29 AM Re: Brake fluid to lubricate Rubber bushings? [Re: kartracer55]
Quest Offline
Loc: beaver land EH?
that is never a good idea to begin with:
1) brake fluid if hydroscopic meaning that it will attract moisture.
2)lack of lubricity
3)not thick enough to resist washout.
use synthetic brake caliper sliding pin lube designed for brake caliper sliding pins and bushings only. They are meant to be used that way. PBBlaster and the likes will swell any rubber bushings causing them to break/crumble and moisture and dirt will get in.
I personally have been using sylglide for decades with full confidence and excellent results.Vehicles been serviced by yours-truely using sylglide on various brake related rubber bushings, caliper sliding pins, etc. have gone past million miles mark (I have over 200+ vehicles maintenance service records that I performed on) and none of them experienced any brake caliper seizure or damaged rubber caliper boots.
Lastly: if your rubber bushings/boots looked swollen and out of shape, replace them with a rebuild pack (Carlson or Beck Arney) for it may have come into contact with other petroleum products already and will fail fairly soon.
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#1089461 - 02/19/08 08:13 PM Re: Brake fluid to lubricate Rubber bushings? [Re: Quest]
alreadygone Offline
Loc: North Arkansas
Don't know much about engineering, but getting brake fluid on any of the oil safe rubbers on your engine will turn them to jello, same as getting oil on any of the rubbers in your brake system will turn them to goo! The door seals and other automotive rubbers not designed for contact with oils or brake fluid with either get gooey, or rock hard with exposure to either one.
Bob
To which version of reality would you like to convert me?
Bob
#1089476 - 02/19/08 08:40 PM Re: Brake fluid to lubricate Rubber bushings? [Re: alreadygone]
Kestas Offline
Loc: The Motor City
The elastomer used in contact with brake fluid is specifically formulated for the application. I wouldn't willy-nilly throw brake fluid on suspension bushings. You don't know how bushing elastomer will react to brake fluid. Silicone-based lubricants are the only thing that can be safely used in this situation.
#1090115 - 02/20/08 07:38 PM Re: Brake fluid to lubricate Rubber bushings? [Re: Kestas]
kartracer55 Offline
Loc: NJ
Alright, thanks. I currently use CRC silicone spray and shake my head when I see guys spraying PBblaster to try and quiet noises
RUPAUL 08!
#1090149 - 02/20/08 08:37 PM Re: Brake fluid to lubricate Rubber bushings? [Re: kartracer55]
Drew2000 Offline
Loc: Long Island, NY
Gotta watch silicone sprays...the cheaper ones are petroleum/solvent based.. For rubber you want a WATER based silicone like LPS Heavy Duty silicone spray.
http://www.lpslabs.com/products/Lubricants/HvyDutySilicone.asp
Drew
11 Mustang GT
06 Tribute
05 Honda ST1300
03 Yamaha FZ1
93 Regal
91 Explorer
87 F250 6.9l Diesel
85 Yamaha FJ1100
83 Honda Nighthawk 650
