Deep tranny pan worth it?
by rsylvstr
14 minutes 17 seconds ago
Which oil for my old BMW and why?
by fdcg27
Today at 06:20 PM
Synthetic blend for a Elantra
by car51
Today at 05:48 PM
Camshaft Adjuster Bolts - Replacement ?
by Ndx
Today at 05:45 PM
STP Synthetic
by travlnman
Today at 04:37 PM
Myliftstand alternative jack stand
by momo
Today at 03:33 PM
Kmart sale on Smitty's oil and ATF
by slacktide_bitog
Today at 02:53 PM
Napa master pack oil filter price
by Electromotive
Today at 02:39 PM
Local Big Lots still has Valvoline next gen 10w30
by Electromotive
Today at 01:25 PM
Best Value Differential Oil 75W-90
by KevinP
Today at 01:02 PM
kohler 17hp . changed oil , now will not run
by chad8
Today at 12:32 PM
Oil change recomendations for '11 Ranger 2.3 Liter
by ryan2022
Today at 11:49 AM
Ruturaj, derfderfgoose, ssnead, mtrev, redtacoma
58277 Registered Users
102 registered (abycat, bchannell, bbhero, 55hambone, 2015_PSD, bdcardinal, 11 invisible), 1742 Guests and 10 Spiders online.
58277 Members
66 Forums
250845 Topics
Page 1 of 2 1 2 >
#1088617 - 02/18/08 04:53 PM 5W20 VS. 5W30 VS. 10W30
byez Offline
Loc: Canada,North America,Western H...
Considering what to run in my 03 V6 Toyota Highlander which is a non-sludge year engine.
With my limited oil knowledge, correct me if i am wrong but the 5w20 will have the best fuel economy and cold starts and the 10w30 will have the best thermal stability. So would a 5w30 be the best of both worlds? The engine in question has been ok'd by Toyota for 5w20 use.
#1088627 - 02/18/08 05:00 PM Re: 5W20 VS. 5W30 VS. 10W30 [Re: byez]
MGregoir Offline
Loc: Bonnyville, AB
5W-20 offers an increase in fuel economy and to this point have shown to be pretty good oils, plus they offer better low temperature performance.
5W-30 offers good cold weather performance and good high temperature protection to an extent but have not shown to be notably better than 5W-20 oils in applications where 5W-20 is reccomended.
10W-30 offers the best high temperature performance, but at a significant cold weather performance penalty and to an extent startup wear penalty from what I have heard.
If it is spec'd for 5W-20 just use 5W-20, if for 5W-30 use 5W-30. I wouldn't use 10W-30 except in the summers in most of Canada.
#1088633 - 02/18/08 05:13 PM Re: 5W20 VS. 5W30 VS. 10W30 [Re: MGregoir]
ekpolk Offline
The Regenerator
Loc: Pensacola FL
I'd go with MG's comments on this, with the following thoughts. Over the years here, I've become convinced that each of us have enough unique facts in our usage patterns that general advice is good only as a starting point. To take it to the n-th degree, you'll have to do several UOAs to see how your oil choices perform in your environment, under your usage conditions. You might try a few different oils, and see how they do for you, with the OEM recommendations as a starting point. Be patient, and let us know how it works out if you decide to try this path.
09 Camry Hybrid, Black (M1 5w-20, std flavor).
07 Avalon XLS, Cassis Pearl (GC 0w-30).
04 Prius, Black (GC -- 0w-30).
#1088639 - 02/18/08 05:21 PM Re: 5W20 VS. 5W30 VS. 10W30 [Re: ekpolk]
02zx9r Offline
Loc: Ball, LA
2012 Honda Insight EX
#1088644 - 02/18/08 05:28 PM Re: 5W20 VS. 5W30 VS. 10W30 [Re: 02zx9r]
byez Offline
So according to this chart. Would 5w30 and 10w30 be identical when it comes to summer performance and the only clear advantage would be 5w30 in the winter?
As the chart does not contain 5w20, would the maximum temp range be in the 25c to 30c range?
#1088653 - 02/18/08 05:34 PM Re: 5W20 VS. 5W30 VS. 10W30 [Re: byez]
Titan Offline
Loc: Mooresville, NC
My take is that 5w30 always has the advantage over 10w30, unless your engine shears oil alot, or has very few cold starts...by, cold, I mean anything significantly less than operating temperature....
The terms "dino,synthetic,blend,conventional" are marketing derived; not scientific.
#1088655 - 02/18/08 05:35 PM Re: 5W20 VS. 5W30 VS. 10W30 [Re: 02zx9r]
bamorris2 Offline
Loc: California
 Originally Posted By: 02zx9r
Sorry, but I think that graph is meaningless. My truck is spec'd for 5w20 in all weather. But according to that graph, I should be running straight 40 weight..??.. (yes, my temps are petty much +50*F all year).
#1088656 - 02/18/08 05:36 PM Re: 5W20 VS. 5W30 VS. 10W30 [Re: byez]
MGregoir Offline
Loc: Bonnyville, AB
Your engine has a thermostat to try to keep it close to the same temperature all the time when it is operating, roughly 195 degrees Fahrenheit, and it will only exceed that when the radiator's cooling capacity is exceeded. Typically 30 weight oil is at about 13 cSt at that temperature, and 20 weight oil is about 10.5 for viscosity.
The thinner oil is made up for by increased oil flow as well, and in most conditions 5W-20 is acceptable.
If you tow, or your engine regularly runs higher temperatures, you may require the additional protection of a 30 weight, and if the engine is specified for a 5W-30 oil (which it most likely is) it is the safest bet for all season performance.
#1088675 - 02/18/08 06:15 PM Re: 5W20 VS. 5W30 VS. 10W30 [Re: MGregoir]
02zx9r Offline
Loc: Ball, LA
the chart is somewhat old but is the only one I have at this time. If anyone has an updated one i would like to see it
#1088679 - 02/18/08 06:17 PM Re: 5W20 VS. 5W30 VS. 10W30 [Re: 02zx9r]
02zx9r Offline
Loc: Ball, LA
I forget who it is either patman or gman that is running straight 30 weight in his 300M, no problems. Wont shear as much as the multi-weights
#1088752 - 02/18/08 07:40 PM Re: 5W20 VS. 5W30 VS. 10W30 [Re: 02zx9r]
byez Offline
So what would be the most robust oil in long drain intervals? A 5w30 will shear to a 5w20, so what will a 10w30 or even a 5w20 shear to under long oci's?
#1088756 - 02/18/08 07:52 PM Re: 5W20 VS. 5W30 VS. 10W30 [Re: byez]
slipperysam Offline
Loc: rochester,ny
I agree that these generic oil temp charts are basically junk.
If you look at the chart suppplied by your auto manufacturer,
you will see what oils to use for given temp ranges. These can be found in your owners manual and are spec'd for conventional oil. They typically recc one grade but allow others under certain circumstances. Buy the cheapest brand name you can find that correlates with your expected temp range and change it according to the manual. Very simple really .
SS
Edited by slipperysam (02/18/08 07:58 PM)
#1088761 - 02/18/08 08:03 PM Re: 5W20 VS. 5W30 VS. 10W30 [Re: slipperysam]
02zx9r Offline
Loc: Ball, LA
just posted the chart so you can get a general idea of what temps the oil grades are good at
#1088766 - 02/18/08 08:06 PM Re: 5W20 VS. 5W30 VS. 10W30 [Re: slipperysam]
Panzerman Offline
Loc: Port Orange, Florida
I would take the 10w30 as the most robust oil, the closer you keep the numbers, 10 to 30, 5 to 30, 5 to 20, the less modifiers and better protection aginst shearing. 10w30 is all of a sudden, in the last couple of years labeled a gear oil by most. I would guess 70% of the cars on the road are running on 10w30, no matter what they are spec'd on. All the quick lubes run this as well as alot of home mechanics. So far all the super high milelage cars( a million miles) have been on thicker oils such as 10w30 or 20w50. Neither a 5w20 or a 10w30 is going to cause overnight failure in any engine. That said in my opinion, 10w30 is still the best choice for any and all cars.
2007 Ford F-150 FX-2 73,000
2007 Ford F-150 FX-4 198,000 (Sold to the Son).
2006 Dodge Ram 2500 Sport 4x4 69,000
2002 Lincoln Continental 153,000
#1088774 - 02/18/08 08:16 PM Re: 5W20 VS. 5W30 VS. 10W30 [Re: Panzerman]
slipperysam Offline
Loc: rochester,ny
Generally speaking Pman is right. Unless your manual states otherwise you can probably use 10w-30 in any engine and be ok.
I consider it to be the default oil when unsure of what to use.
My Honda manual says I can use 10w-30 down to 20F, however it says 5w-30 can be use year round for all temps. So I use the 5w-30 because the winters here can see temps down to 0F. I realize that 10w oils are good down to 0F, however I want the faster lube provided by 5W in the lower temps. I would have no issues running 10w-30 in the summer however.
SS
Page 1 of 2 1 2 >
