Well, I have finished trying several different types of lubes for the Glock handgun and I have concluded that the best lube for the Glock is the copper-based lubricate you can get at Glockmeister. It stays put and the gun performs very well with it.
I have also been using G-Lube gun oil that you can get at the Glockmeister website but as long as you use the copper-based lube it may not make all that much difference what gun oil you use. But the G-Lube works very well for an oil.
I use a toothpick to apply small amounts of the copper-based lube to certain parts of the Glock. Then I use the G-Lube in the places where oil is supposed to be applied.
I have tried various kinds of cleaner and I like Hoppes and RemOil bore cleaner when I can clean my gun outside and I like the Milcomm M25 gun cleaner when I have to clean inside because of cold weather, wind and dust, etc.
I think the really big difference in lubing a Glock is to use the copper-based lube. Various gun oils like RemOil, Hoppes, and the G-Lube are probably acceptable for the oil required but the copper-based lube makes the big difference.
