Accord door lock issue....
by gregk24
3 minutes 7 seconds ago
2000 Corolla vvt-i rattle on startup?
by 55Test
Yesterday at 11:24 PM
Brought home a beater today
by exranger06
Yesterday at 11:03 PM
Can someone explain to me the nomenclature of ammo
by Vern_in_IL
Yesterday at 10:52 PM
Common for bad shift solenoids to shift good warm?
by DemoFly
Yesterday at 09:50 PM
Riding mower with non bearing front wheels
by JHZR2
Yesterday at 09:17 PM
Mail popup
by Eddie
Yesterday at 09:05 PM
Tundra headlight restoration..
by kenwin30
Yesterday at 09:00 PM
High mileage and severe service...
by OneEyeJack
Yesterday at 08:44 PM
Who uses Quicksilver Multi-purpose oil
by BrocLuno
Yesterday at 08:07 PM
Gumout Q&A with Ryan Tuerck - Answers
by wwillson
Yesterday at 07:37 PM
Friend Picked Up New 2017 Hyundai Santa Fe Today
by crazyoildude
Yesterday at 07:07 PM
danthemann, rodder98, kenb777, Indyfan3, RM53119
58651 Registered Users
40 registered (addyguy, Analyzer, aquariuscsm, Anduril, alan003, 5 invisible), 1217 Guests and 3 Spiders online.
58651 Members
66 Forums
252470 Topics
Page 1 of 2 1 2 >
#1072857 - 01/26/08 12:35 PM 5W30 vs 5W40
ARB1977 Offline
Loc: North Texas
This is the first run with 5W40 Syntec in my wifes 97 Jetta 2.0L. Today i did a little routine maintenance and noticed some white build up under the oil cap. There's no head gasket issues because the car isn't losing any coolant. Her commute is 15 miles one way to work, mainly freeway. Im thinking its mainly condensation that's not burning off. Anyway would running 5W30 get the oil temp up faster than 5W40? The car has a wide range of oil grades to use.
2015 Tacoma 4.0L 30K (as of 5-24-16)
Mobil One EP 5W30 / Toyota filter
2008 CRV 2.4L 144K (as of 04-13-16)
Maxlife 5W20 / Fram TG filter
#1072867 - 01/26/08 12:54 PM Re: 5W30 vs 5W40 [Re: ARB1977]
Drew99GT Offline
Loc: Colorado Springs
I doubt it would. I'd continue using the 5w-40 personally as people say the VW 2.0 likes a thicker oil. I have the milkshake under my oil cap as well from short trip and extreme cold weather. Adding cardboard in front of my rad has helped a lot - much faster warmup and it runs warmer overall per my infrared temp gun.
Edited by Drew99GT (01/26/08 12:55 PM)
#1072881 - 01/26/08 01:23 PM Re: 5W30 vs 5W40 [Re: Drew99GT]
bmwtechguy Offline
Loc: South Carolina
You're in Texas. I would stay with the 5W-40.
#1072885 - 01/26/08 01:29 PM Re: 5W30 vs 5W40 [Re: bmwtechguy]
JHZR2 Offline
Loc: New Jersey
white has to do with cooler temperatures condensing a bit. Common in my BMW, which gets short drives like that.
The differences in oil heat up time are tiny at best. Bettr would be to take it on a long nice drive once in a while.
JMH
#1072911 - 01/26/08 02:06 PM Re: 5W30 vs 5W40 [Re: ARB1977]
Triple_Se7en Offline
Loc: 1/2 hr. north of Detroit
I would bet those 15 miles freeway are in congestive traffic. That engine needs to see some longer spells at maximum highway speeds more often.
Edited by Triple_Se7en (01/26/08 02:08 PM)
#1072931 - 01/26/08 02:23 PM Re: 5W30 vs 5W40 [Re: Drew99GT]
JAG Offline
Loc: Fredericksburg, VA
 Originally Posted By: Drew99GT
Adding cardboard in front of my rad has helped a lot...
Ditto. It's a free, effective solution.
#1073077 - 01/26/08 08:01 PM Re: 5W30 vs 5W40 [Re: Drew99GT]
ARB1977 Offline
Loc: North Texas
Yea im sticking with this grade or may try some GC...when i changed out the PCV it looked like a clogged artery with this white crud.
#1073079 - 01/26/08 08:05 PM Re: 5W30 vs 5W40 [Re: Triple_Se7en]
ARB1977 Offline
Loc: North Texas
No...she drives in no traffic going to work but alittle comming home. This summer im giving auto rx a try in both cars, do you think this may help get rid of some of that white crud?
#1073082 - 01/26/08 08:11 PM Re: 5W30 vs 5W40 [Re: bmwtechguy]
ARB1977 Offline
Loc: North Texas
Im debating if i should stick with this oil or go with GC.
#1073094 - 01/26/08 08:51 PM Re: 5W30 vs 5W40 [Re: ARB1977]
JAG Offline
No, I don't think it will get rid of that crud if it's an oil/water emulsion. More heat is what's needed.
#1073103 - 01/26/08 09:01 PM Re: 5W30 vs 5W40 [Re: JAG]
ARB1977 Offline
Loc: North Texas
Thanks Jag.
#1073198 - 01/27/08 01:12 AM Re: 5W30 vs 5W40 [Re: ARB1977]
JR Offline
Loc: Michigan born but my heart bel...
I would stay with the 5W-40. I use delvac 1 5W-40. Were problem is short run times. If you take it out on the highway once a week or every two weeks. That should stop the build up and an oil change or two whats in it now should be gone. My 95 geo metro had that issue to. I am running mobil 1 europe blend 0W-40, and i started taking out for an hour drive a week. That was 3,500 miles ago and the cap and valve cover are clean.
#1073247 - 01/27/08 07:12 AM Re: 5W30 vs 5W40 [Re: ARB1977]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
15 miles seems like plenty of time to warm the car up. Are you sure you don't have a slightly sticky thermostat? I have seen this where yes the temp gauge will register some warming, but a new 'stat allows a tighter close for longer (not prematurely opening) and quicker hotter warm up.
The only time I would say go with a XW-30 would be a HDEO 30 for just a temporary clean/flush to get all the water emulsified oil out. You may want to consider this for 500-1000 miles.
#1073267 - 01/27/08 08:01 AM Re: 5W30 vs 5W40 [Re: Pablo]
Gary Allan Offline
Loc: Pottstown, PA
I agree with Pablo. More than enough time/mileage. Check the thermostat ..check the PCV system.
If you've got one of these
...then the oil temp should be pushing around 100C within 9 miles/9 minutes.
http://lube-direct.com/gallan/
#1073290 - 01/27/08 08:49 AM Re: 5W30 vs 5W40 [Re: Pablo]
ARB1977 Offline
Loc: North Texas
Thanks Pablo,
The tsat is original and the water temp seems to climb faily quickly. We drove it all day yesterday and the white stuff went away.
Page 1 of 2 1 2 >
