Castrol Edge 5w30 no longer A5/B5
by slacktide_bitog
9 minutes 25 seconds ago
Best Oil Analysis?
by countryboy9799
Today at 07:28 PM
Left my lights on and battery died.
by joegreen
Today at 07:25 PM
Honda CRX '91 transmission fluid
by jhmed80
Today at 07:18 PM
It's winter, let's take out the... Motorcycle???
by OVERKILL
Today at 06:54 PM
Home Testing for Gas in Oil?
by landtoy80
Today at 06:54 PM
Cost to replace windshield.
by Oldmoparguy1
Today at 06:44 PM
Oil Life Monitor vs. Mileage vs. Time
by HOG
Today at 06:24 PM
Carrier A/C moving ALL production to Mexico.
by GiveMeAVowel
Today at 06:23 PM
ZDDP MAXX vs ZDDPlus
by 007
Today at 06:02 PM
Got a new jump starter, for the big boys
by 901Memphis
Today at 05:20 PM
S2000 valvetrain at 184K miles
by robertcope
Today at 04:58 PM
RTS, jhmed80, engus, Rob_Pol, Nick24w
56901 Registered Users
118 registered (2cool, 2002 Maxima SE, 1989outlaw, bdcardinal, 901Memphis, ammolab, 12 invisible), 1416 Guests and 194 Spiders online.
56901 Members
66 Forums
244620 Topics
#1059031 - 01/06/08 05:35 PM Recommendations closest to Castrol SAF-XO 75w-90?
Jim 5 Offline
Loc: Calgary Canada
My car and the motorcycle that's on the way both require Castrol SAF-XO 75w-90. Attached is a spec sheet that describes the Castrol Synthetic gear lube:
http://www.ge39.com/files/SAF_XO_SAF_XJ_B1174_96.pdf
I don't want to pay BMW prices. Can anyone recommend anything that's as good? The regular Castrol Syntec 75w-90 (sold in North America) is 1/4 the price but I don't know if it's any good.
Jim A
07.5 GMC Sierra 2500HD LMM Rotella 15w-40
09 Odyssey EX-L CT 5w-20
66 Bronco QS 10w-30
08 BMW K1200S Rt 15w-40
08 Pitster Pro X4 Rt 15w-40
#1059034 - 01/06/08 05:39 PM Re: Recommendations closest to Castrol SAF-XO 75w-90? [Re: Jim 5]
JHZR2 Offline
Loc: New Jersey
bmw superceeded XO with XJ for all LSDs, and IIRC, most dealers use XJ as their sole fluid.
I'd run amsoil severe gear... the 110 wt is probably a good bet, given that BMW diffs tend to get whiney.
JMH
#1059075 - 01/06/08 06:33 PM Re: Recommendations closest to Castrol SAF-XO 75w-90? [Re: JHZR2]
double vanos Offline
Loc: Bisbee, Arizona
I have been using Castrol Syntec 75-90 synthetic gear oil in my '02 330ci since it had 20,000 miles on it. It currently has 101,000 miles so I guess I can endorse it. Rear end is quiet and smooth. Change the oil every 15k-20k miles.
Svetlana Kapanina is harder core than Sabine Schmitz.
www.kapanina.com
#1059085 - 01/06/08 06:37 PM Re: Recommendations closest to Castrol SAF-XO 75w-90? [Re: double vanos]
Here's a link to the Syntec 75w-90 gear oil http://safetydatasheets.bp.com/USSDS/AME...33000220003.pdf . Cheers
www.kapanina.com
#1059136 - 01/06/08 07:28 PM Re: Recommendations closest to Castrol SAF-XO 75w-90? [Re: JHZR2]
Jim 5 Offline
Loc: Calgary Canada
JMH
The diff (car) and final drive call for 75w-90(xo) and neither have LSD's. I myself don't know of any BMW cars with LSD's though many BMW enthusiasts lament the fact that their cars don't have LSD's...especially these days as power is getting significantly higher across the product line. Maybe the X3/5's come with LSD's?
Many on BMW motorcycle sites say any GL5 75w-90 at reasonable intervals will do - SAF-XO is not necessary with this maintenance philosphy. The thought is that for those who believe in lifetime final drive fluids should use the more expensive SAF-XO.
That's not me, I've done the car once at 30k miles with Redline 75w-90. Will likely stay with every 25-30k miles. The bike calls for a change at 600 miles then never again. I'll do it at 600 then every 2 years thereafter (likely every 8k miles - the bike only needs 0.21L)
Jim A
66 Bronco QS 10w-30
#2051770 - 10/19/10 05:17 PM Re: Recommendations closest to Castrol SAF-XO 75w-90? [Re: Jim 5]
4x4taco Offline
Loc: FL
Going thru this right now on my 335i. BMW forum member pulled it out of the TIS dealer systema nd it is XO (75/90) for open diffs and 75/140 XJ for LSD diffs which are in M3's mainly.
I have an '07 335i open diff, so I'm going to run the 75-90 XO. Spec sheet compare to M1's 75-90 looks better. Much higher flash point and lower pour point, higher VI and is actually BMW approved for my warranty.
Edited by 4x4taco (10/19/10 05:18 PM)
#2057896 - 10/26/10 01:04 AM Re: Recommendations closest to Castrol SAF-XO 75w-90? [Re: Jim 5]
HondaMan Offline
Loc: Texas
I've been meaning to post an interesting bit of information on this for quite some time but I forgot.
Land Rover is your source!! I have several bottles of Land Rover 75w-90 in the garge and am running it in my 96 318i which calls for saf-xo.
Google 'Land Rover saf-xo'.... or 'LNR 7591' there was a pdf posted from Land Rover and listed out the OE fluids and their present OE supplier.
Do not let them sell you anything else. The bottle is black with the most generic sticker you ever seen!!!
For all the SAF-XO seekers here on Bob... a nice bit of info I've just shared.
Funny that the parts guy was insistant that Castrol 75w-90, which he had also, was the same, but at the same time noted that LR specified the 7591 in some diffs 'for some reason'.
#2430169 - 11/09/11 05:11 PM Re: Recommendations closest to Castrol SAF-XO 75w-90? [Re: HondaMan]
lkchris Offline
Loc: ABQ
Just to update ...
SAF XO is now called Syntrax (yes spelled correctly) Long Life
http://www.castrol.com/castrol/genericarticle.do?categoryId=9014115&contentId=7068181
Here's the Land Rover stuff
http://www.roverparts.com/Parts/LRN7591G.cfm
Edited by lkchris (11/09/11 05:12 PM)
Kent Christensen
Albuquerque
'03 New Beetle TDI, '06 E320CDI, '07 GL320CDI
