Originally Posted By: oliver88
So why all the fuss about flat tapett engine problems with the newer oils? Wouldn't this be fine to use? Seems pretty stout to me....The Porsche guys are spending hours upon hours dissecting oils to find the Holy Grail....
Yes, it would work fine. In fact, Mobil formulated it specifically for high-performance, flat-tappet engines.
Problem is it only costs about $4 a quart, and too many people equate mo money with mo betta. If Mobil had tacked a $12 per qt price tag on it the stores wouldn't be able to keep it on the shelves...
From Mobil's website:
"Mobil 1 15W-50 is formulated with SuperSyn, an extra-high viscosity synthetic fluid, plus extra anti-wear additive to provide extra protection for severe service applications such as towing, hauling and racing. Mobil 1 15W-50 is recommended for high performance vehicles including turbocharged and supercharged engines where a thicker oil film is desired.
Mobil 1 15W-50 is also recommended for older valve train designs that may benefit from a higher level of anti-wear normally not required for newer generation vehicles. Mobil 1 15W-50 will also provide better anti-wear protection for higher valve spring tensions in certain racing engines."
