So many detailing products........
by buster
05/04/16 10:00 AM
Why is Mobil Delvac 1 so expensive?
by pb379
05/04/16 10:00 AM
2017 F-150 3.5 twin turbo V6
by OneEyeJack
05/04/16 09:45 AM
Fort McMurray Fire 80,000 evacuated
by Smokescreen
05/04/16 09:40 AM
Apparent dilution ratio discrepancy????
by Sayjac
05/04/16 09:31 AM
Ceramic brake pads
by bigdom
05/04/16 09:24 AM
how to verify oil in a manual transmission
by yvon_la
05/04/16 09:21 AM
14 F-350 Rotella T-6
by Erreich
05/04/16 08:43 AM
Why Measure Trans. Fluid with Engine Running?
by doitmyself
05/04/16 07:39 AM
Is Pennzoil discontinuing High Mileage 10W40?
by aquariuscsm
05/04/16 06:55 AM
Lowering vehicle with alternative coil springs
by OlDirty
05/04/16 06:22 AM
Remington R1 1911 or Springfield 1911-A1 MIL-SPEC
by MuzzleFlash40
05/04/16 06:02 AM
Palmer, jessanmark16, danbee, PTT, greasy_knuckles5
57790 Registered Users
70 registered (badtlc, AUTOTECH89, Bgallagher, Al, Astro14, Bandito440, 6 invisible), 1736 Guests and 283 Spiders online.
57790 Members
66 Forums
248451 Topics
#1045790 - 12/13/07 06:48 PM When is it too cold to wax the car?
lexrx3 Offline
Loc: New Jersey
I have missed the warm fall weather in which to put the last coat of wax on. So my question is, what is the coldest temp that you can apply wax and are there any problems putting a coat of wax on when its in the 40's F outside? I normally use Black Magic.
#1045930 - 12/13/07 09:12 PM Re: When is it too cold to wax the car? [Re: lexrx3]
deepsquat Offline
Loc: Tacoma ,WA
Maguires recommends 50 to 90 degrees ..check there site ...I know I am within a few degrees
#1046202 - 12/14/07 10:10 AM Re: When is it too cold to wax the car? [Re: deepsquat]
XPR Offline
Loc: USA
I asked the same thing, and it seems the surface temperature matters far more than air temp. So if you can heat your paint up to about 80F you should be good.
A 3,000 mile OCI is a waste! Use a full synthetic oil!
#1051570 - 12/24/07 12:45 AM Re: When is it too cold to wax the car? [Re: XPR]
SevenBizzos Offline
Loc: The IL
I tried to wax when the temp was around 60 and it still wasn't quite dry after 2 hours (not in direct sunlight).
#1051657 - 12/24/07 08:46 AM Re: When is it too cold to wax the car? [Re: SevenBizzos]
Patman Offline
Loc: Oakville, Ontario
You must've put it on too thick then. I put a coat of Meguiar's #21 on my car yesterday, and it was 60 degrees in my garage, and it was dry in under 30 minutes. I've done my car in 40-50 degree weather before and it's never taken 2 hours to dry ever.
2005 Corvette (M1 5w30 & Fram Ultra)
2006 Civic EX Coupe (M1 0w20 & Fram Ultra)
2010 BMW 328i X-Drive (M1 0w40 & Mann filter)
#1052179 - 12/25/07 12:24 PM Re: When is it too cold to wax the car? [Re: Patman]
Edmond Offline
Loc: Texas
I've waxed my car in 30 degree weather before and it's been perfectly fine. But it was the Mothers spray on wax. Don't know if that makes a difference.
#1052264 - 12/25/07 03:30 PM Re: When is it too cold to wax the car? [Re: Patman]
SevenBizzos Offline
Loc: The IL
That's certainly possible. I hadn't had that problem before, and I expected there to be no problem that time either. Now, I save the waxing for the heated garage.
#1052822 - 12/26/07 06:21 PM Re: When is it too cold to wax the car? [Re: SevenBizzos]
GMBoy Offline
Loc: Texas
It's too cold when you can't feel your fingers.
#1053891 - 12/28/07 09:53 PM Re: When is it too cold to wax the car? [Re: GMBoy]
Steve S Offline
Loc: East of IGO
I haven't waxed any of my vehicles since 1992.
Why do people post I want the best for my car,,, When there isn't anything that is the best on the car to begin with.
#1053999 - 12/29/07 07:05 AM Re: When is it too cold to wax the car? [Re: Steve S]
Ryan Offline
Loc: Stallings, NC
You know you can't come in here and post something like that and expect to survive! Put some wax on them dog gone cars!
#1057145 - 01/03/08 08:51 PM Re: When is it too cold to wax the car? [Re: Ryan]
Ramjet Roger Offline
Loc: Silver Spring, MD
I routinely wax my cars and truck in the 30s. I especially like using RainX's Fastwax. If I wipe it on smooth and evenly enough, I don't even need a follow-up wipe/buff.
For regular waxes like NuFinish and Black Magic, I wipe it on moderately heavy and wait 15-30 minutes. Then, I do a light wipe with clean dry towels--not to buff, just to smooth out the wet wax and remove the heavier deposits. Often the wax is still a bit wet so the toweling really just thins down the coating a bit.
Then 15-30 minutes later I follow up with a damp microfiber towel and then lightly buff with a dry microfiber just to the point of drying the light coating of moisture on the paint surface. It really brings out the shine. By the next day or so, everything is completely dry and looks flawless--no swirl marks and with no real effort. But, it does take some time...
Roger...
#1062124 - 01/11/08 01:10 AM Re: When is it too cold to wax the car? [Re: Ramjet Roger]
Dominic Offline
Loc: Gilbertsville, PA
When I cant wax, I use turtle wax spray wax which works well down to about 33F :)
2014 Mazda 6 GT - M1 EP 0W-20
2008 Nissan Versa SL - Valvoline 5W-30 Synpower
#1062373 - 01/11/08 12:18 PM Re: When is it too cold to wax the car? [Re: Dominic]
wannafbody Offline
Loc: PA
I think this depends on the product. Waxes don't cure but rather haze(solvents flash off)so cold temps might not allow them to flash as fast. It also depends on the type of solvent used. Low solvent products like Zaino can be used in mid 30 degree weather as long as it is applied thin.
2000 TA WS6
