1991 Sierra rear brake squeel
by sr17
33 minutes 37 seconds ago
2015 Silverado Diff Fluid Change
by Realtech214
Today at 12:25 AM
Undercarriage Rust Management
by OpenClose
Yesterday at 11:31 PM
New used tires
by gfh77665
Yesterday at 11:29 PM
Hybrid and ROI (Return Of Invesment)
by HTSS_TR
Yesterday at 11:14 PM
Best Walmart stocked wiper blades?
by aquariuscsm
Yesterday at 10:54 PM
What Ohm antenna wire to use?
by daves66nova
Yesterday at 10:46 PM
Turtle Wax Passed The Test
by RevRider
Total FLUIDMATIC G6 SYN ATF, 13.7k mi OCI, 34k mi
by Emperors6
Yesterday at 10:17 PM
Honda NC700X Red Line 10W30, ~5,000 miles
by bulwnkl
Yesterday at 10:13 PM
If you liked the Fram AirHog Filters
by rrounds
Yesterday at 10:07 PM
Most advanced oil on the shelf?
by Jetstreamz06
Yesterday at 09:41 PM
Timmytimmy, Peakboy91, TimingBeltKing, watergate528, iamtheanimal
57996 Registered Users
27 registered (csx7006, bbhero, bdcardinal, Farmer, Gasbuggy, alcyon, 2 invisible), 634 Guests and 321 Spiders online.
57996 Members
66 Forums
249469 Topics
#1042498 - 12/08/07 09:04 AM Oil Weight for a Chevy 383 Stroker
SR77 Offline
Loc: Central, NJ
Hello, I just bought a car with a Chevy 383 Stroker motor in it and was wondering which oil weight you would recommend for it. I live in NJ and will probably store it in the garage over the winter, so it will probably only be driven early spring to late fall in the north east. Also would you use a different oil for storage then used for the rest of the year or should I just keep the same oil in it regardless so different oils aren't mixing? I was thinking either a 10w30 or 5w-40. I tried to do a search first but the search function doesn't seem to work so well for me. thanks for the help
Oh and any winter storage tips that you got are welcome also. I was going to just change the oil and check the coolant mixture, but leave the gear and trans fluid alone till the spring.
#1042503 - 12/08/07 09:13 AM Re: Oil Weight for a Chevy 383 Stroker [Re: SR77]
eljefino Offline
Loc: ME
Sounds like fun. Any trick parts, like a crazy cam or stiff valve springs etc?
I would look for lots of zinc and let the weight fall in from there. 5w40 rotella would work pretty good.
#1042538 - 12/08/07 10:06 AM Re: Oil Weight for a Chevy 383 Stroker [Re: eljefino]
mechtech2 Offline
Loc: Chicago Area
383 is a common 350 modification. But that means someone rebuilt that engine.
If they liked loose clearances, you would be best with a thicker oil. Being high performance, it probably will run hot in the summer. I'd go with the 5-40 in that great but older technology engine.
#1042543 - 12/08/07 10:11 AM Re: Oil Weight for a Chevy 383 Stroker [Re: mechtech2]
Rickey Offline
Loc: North Carolina
Rotella T Synthetic 5W40. Purolator Pure One oil filter.
Built right it should be faaast.....
Be careful Sir.
Rickey.
#1042559 - 12/08/07 10:37 AM Re: Oil Weight for a Chevy 383 Stroker [Re: Rickey]
wavinwayne Offline
Loc: North Alabama
Other than being a modification to a 350, what exactly is a 383 'Stroker Motor'?
Silence is golden, but duct tape is silver.
#1042646 - 12/08/07 02:14 PM Re: Oil Weight for a Chevy 383 Stroker [Re: wavinwayne]
Drew99GT Offline
Loc: Colorado Springs
http://www.chevymania.com/tech/383.htm
It's a 350 with a 400 crank.
#1042706 - 12/08/07 04:59 PM Re: Oil Weight for a Chevy 383 Stroker [Re: SR77]
Merkava_4 Offline
Loc: Clovis, CA
I have a friend in Missouri that's a professional engine builder. He has a Camaro that he races at the local drag strip. The car has a 500HP 383ci stroker motor and he runs nothing but Valvoline 20W-50 in it; and that's regular Valvoline; not the racing formula.
#1042770 - 12/08/07 07:07 PM Re: Oil Weight for a Chevy 383 Stroker [Re: Merkava_4]
SR77 Offline
Loc: Central, NJ
Thanks for the replies.
If I go with 5w-40 Rotella, would you use the same oil in the winter during storage even though it will be dumped in the spring before I fire it up or would you just put some cheap oil in for storage. If the cheap oil what weight?
Yes this engine is also in a Camaro (69) with no power steering so i am definitely gonna have to take it easy till I get used to the power. I just got the car and don't have many specs on the engine yet, but the previous owner said he is gonna find all the paper work on it and send it to me. Supposedly when the builder put it on the dyno it made around 425hp. The cam sound nice at idle but doesn't sound too radical. It also already a bigger all aluminum radiator, so i am hoping that will take care of the temp in the summer(cross my fingers). I don't plan on racing this car, this is gonna be more of a street cruiser.
thanks again for you guys help.
#1042805 - 12/08/07 08:43 PM Re: Oil Weight for a Chevy 383 Stroker [Re: SR77]
DragRace Offline
Loc: 1/4 Mile Track
Just change the oil before puttin the car into storage,thats the main thing.
Yup,I said the same thing,but there will be times you'll give in to a lil street race
#1043123 - 12/09/07 01:57 PM Re: Oil Weight for a Chevy 383 Stroker [Re: DragRace]
Ryan02SS Offline
Loc: Formerly Ryan00TJ member 143
I'm also throwing together a 385ci SB for my boat over the winter. Being a marine engine it's set up a little looser than a car engine and will be fed Mobil Delvac 1300S 15W-40. I would use a Synthetic but the oil is changed every 20-25 hours which is two weeks most of the time. Carbed marine engines are hard on the oil. Fuel dilution and extended WOT runs. How many car engines see 5500 rpms WOT for 2-5 mins at a time?
For your application I would want to know the bearing clearances? If you cannot find them out use the Rotella 5W-40 Syn or Mobil 1 5W-40 Syn. I've always had good luck with Diesel 15W-40's also. The motors I have torn down using 15W-40 oil have all looked wonderful and they are hard run marine engines.
I would stick with the same oil for storage. Just change it before storing and its ready to fire up in the spring.
08 GMC Sierra Z71 LY5 5.3L M1 0W-30 AFE PureOne
84 Hammond Challenger 6.3L 385ci SBC 80.5GPS Delvac 15W40
03 VW Passat 1.8T M1 0W-40 PureOne
