This is posted for Speedy 1
Also virgin oil report
Message from Speedy1: First mobil 1 0/40 is good oil and i started using it when i purchased my 1995 BMW M3 when it was 2 years old with 46,000 miles on it. I used mobil 1 5/30 & 15/50 depending on the season. I switched to 0/40 when it became availble. The blackstone report includes my last 4 reports red line 10/40 castrol 0/30 [german-gold] mobil 1 0/40-15/50 a 50 50 mix and mobil 1 0/40 this oil sample was the only sample not used when i tracked the car at mid-ohio sports car course. The motor has 184,230 it is modified to 275-280 horsepower, everything but cams. Before we changed over to red line oil we opened the motor for the very first time to change the valve cover gasket. Mobil 1 cleans and cleans and cleans. No sludge no varnish and my technician spent 20 min. with a flash light as was very impressed with the cleanliness and he could not see any visible wear on cams or any where else. Now many people complain about high wear metals in there first oil analysis reports when switching over to Red Line oil. That couldnt more wrong, just look at my report. If you start with a clean motor as i did after using Mobil 1 for the last 125,000 miles your first Red line report wont disapoint. Mobil 1 is good but in this motor Red line is excellent. To all BMW owners one side benefit of using Red line 10/40 almost all the chain noise from my VANOS unit is gone and it didnt stop with Mobil 1 0/40 or 15/50. I had enen replaced the lower chain tensioner with no improvement.So i would suggest anyone with high wear metals in there first Red line oil reports might consider the inside of their motors might not be as clean inside as they would have liked. and the Red line oil may truly be cleaning out all the gunk in side your motor.Just look at my report it speaks for itself. I dont think you can go wrong with either oil but the Red line oil i believe is even better. at least in my 1995 BMW M3. Speedy1
