I found the printout of the TSB at home, if anyone cares to read this much:
Oil Filter - Ballons & Eventually Leaks
Article No. 94-11-7
06/01/94
ENGINE-4.6L-OIL FILTER "BALLOONS" AND EVENTUALLY LEAKS OIL - VEHICLES WITH AOD/AODE TRANSMISSION
OIL FILTER-"BALLOONS" AND EVENTUALLY LEAKS-VEHICLES WITH 4.6L ENGINE AND AOD/AODE TRANSMISSIONS
OIL PUMP-INCORRECT ENGINE OIL USAGE RESULTS IN OIL FILTER "BALLOONING" AND SUBSEQUENT OIL LEAKS-VEHICLES WITH 4.6L AND AOD/AODE TRANSMISSION
FORD:
1992-92 CROWN VICTORIA
1994 THUNDERBIRD
LINCOLN-MERCURY
1991-94 TOWN CAR
1992-94 GRAND MARQUIS
1994 COUGAR
This TSB article is being republished in its entirety to include 1994 Thunderbird/Cougar vehicles and to reflect a change in the oil pump service kit part number.
ISSUE:
The use of engine oil with higher than specified viscosity (5W30/10W30) may cause oil filter "ballooning" and subsequent loss of engine oil. Higher vicosity oils may cause oil pump relief valve bore wear. This causes the relief valve to stick, resulting in excessive system oil pressure and a blown oil filter.
ACTION:
Install an oil pump service kit with a revised oil pump and associated gaskets. This desensitizes the oil pump to higher viscosity oils to preclude potential oil filter "ballooning". Refer to Instruction Sheet # 6490B, included in the kit, for the installation procedure. Refer to the appropriate Car Service Manual, Section 03-01, for any additional 4.6L engine information.
The oil pump service kit (F5AZ-6660-A) includes on of each of the following components:
Oil Pump
Oil Pan Gasket
Front Cover RH Gasket
Front Cover Center Gasket
Front Cover LH Gasket
Cam Cover LH Gasket
Cam Cover RH Gasket
Instruction Sheet #6490B
CAUTION: CUSTOMER SHOULD REFER TO THE OWNER GUIDE FOR OIL USAGE SPECIFICATION. UNDER NO CIRCUMSTANCES SHOULD OIL OF A HIGHER VISCOSITY BE USED.
PART NUMBER PART NAME CLASS
F5AZ-6660-A Oil Pump Service Kit A
OTHER APPLICABLE ARTICLES: NONE
SUPERSEDES: 93-25-4
WARRANTY STATUS:
Eligible Under The Provisions Of The Bumper To Bumper Warranty Coverage
OPERATION DESCRIPTION TIME
941107A Replace Oil Pump And 8.1 Hrs.
Install New Oil Filter-
Crown Victoria/Grand
Marquis/Town Car
941107B Replace Oil Pump And 7.7 Hrs.
Thunderbird/Cougar
DEALER CODING
BASIC PART NO. CONDITION CODE
6600 63
OASIS CODES:40100
Sorry if I made any typos. Hope this is of help to someone.
