Brakes for 2012 Subaru Legacy
by Picky1
4 minutes 31 seconds ago
Microgreen Oil Filter 50% Off Discount Code
by kohnen
10 minutes 4 seconds ago
Don't believe the hype of "never change the oil"
by Fsharp
30 minutes 16 seconds ago
tzlk to me about aeroflot
by Jetronic
Today at 12:21 PM
My extended drain OCI did not go as intended...
by firemachine69
Today at 11:10 AM
Honesty
by stockrex
Today at 11:04 AM
Valvoline's New "Cobalt" Grease availability
by EdandSherry
Today at 10:47 AM
Mobil Delvac 1 5w40: where to buy?
by car51
Today at 10:38 AM
Honda EM7000is stored too long with fuel
by henni
Today at 10:04 AM
1967 Ford F250- cooling system flush w/ Cascade??
by ryanschillinger
Today at 10:02 AM
Oil for FTO MIVEC used on track
by Spetz
Today at 09:13 AM
[Cut Open] Motorcraft FL500S - 5316mi
by DuckRyder
Today at 09:04 AM
Jennyp, dcdodge, igolfat8, makomike, Alexas
58338 Registered Users
89 registered (another Todd, 13Tacoma, 1foxracing, aquariuscsm, 09_GXP, 13 invisible), 2025 Guests and 11 Spiders online.
58338 Members
66 Forums
251102 Topics
Page 1 of 2 1 2 >
#1008280 - 10/11/07 05:37 AM using a car oil filter for a motorcycle
hondaintegratypes Offline
Loc: CA
i noticed that my car oil filter is the same size as my bike oil filter. can i use the car filter on my bike?
i'm specifically talking about the mobil 1 m1-110.
#1008281 - 10/11/07 09:03 AM Re: using a car oil filter for a motorcycle [Re: hondaintegratypes]
g56 Offline
Loc: USA
A car oil filter can be fine, but you need to select it with more than just that it looks about the same size. One way to do it is to find a cross reference, go to Fram's website and use their info to find the filter number you need for your bike, then you can cross reference that to any brand of filter you like.
AMA Charter Life
AMA Longrider Emeritus 300,000
#1008282 - 10/11/07 10:26 AM Re: using a car oil filter for a motorcycle [Re: g56]
dwendt44 Offline
Loc: Central Wisconsin
Cycle oil filters are often priced much higher than the similar auto oil filters.
Many Honda cycles can use the Honda auto filter (Accord/Civic).
That's the one I'm most familiar with.
The bypass pressure should be close on any auto filter you try to use.
What cycle are we talking about?
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
#1008283 - 10/11/07 02:51 PM Re: using a car oil filter for a motorcycle [Re: dwendt44]
02zx9r Offline
Loc: Ball, LA
Cant find the link where I got this but a guy did a study and like others have said, you can use car filters on bikes. I use purolator pure one PL14610 on my 2002 kawasaki ninja zx9r, which is about 1 1/4" longer than oem.
About 3.25 inches long.
Purolator Pure One PL14610, about $6.
Mobil 1 M1-110, about $10.
Made by Champion.
Bosch 3323, about $6.
Made By Champion.
WalMart SuperTech ST7317,
about $2. Made by Champion.
2012 Honda Insight EX
#1008284 - 10/11/07 02:53 PM Re: using a car oil filter for a motorcycle [Re: 02zx9r]
02zx9r Offline
Loc: Ball, LA
maybe almost an inch longer, i forget the actual length how much longer it is but it is a tad longer.
#1008285 - 10/11/07 04:12 PM Re: using a car oil filter for a motorcycle [Re: 02zx9r]
BillWilson Offline
Loc: Denver, NC
I plan to use the ST7317 for the next oil change on my Honda VLX 600. During the last oil change I tried the ST7317 on the bike & it fit, but used the last Honda filter I had. Using the longer ST7317 the filter removal tool that fits on the end of the filter and uses a 3/8" ratchet does not have enough room/clearance with the ST7317. The ST7317 is about 2.57" in diameter so I will try the channel lock style oil filter pliers sold at WalMart that will go down to 62MM (2.44") diameter for removal.
Bill
#1008286 - 10/11/07 04:13 PM Re: using a car oil filter for a motorcycle [Re: 02zx9r]
Titan Offline
Loc: Mooresville, NC
I use my Subaru-spec'd Wix filter on my Motorcycle. I've also used a Purolator. Lot's of people I know use Supertech car filters on their bikes. As long as the spec's are ok, it's fine.
The terms "dino,synthetic,blend,conventional" are marketing derived; not scientific.
#1008287 - 10/11/07 07:13 PM Re: using a car oil filter for a motorcycle [Re: Titan]
VictoryRed Offline
Loc: Wisconsin
where'd you find the specs on what filtration level your bike needs?
where'd you find the specs on how many lbs of pressure before the bypass opens?
#1008288 - 10/11/07 07:24 PM Re: using a car oil filter for a motorcycle [Re: VictoryRed]
BGK Offline
Loc: Northern California
Wouldn't the car filters come up on a cross reference chart IF they were truly acceptable alternate filters for motorcycles?
#1008289 - 10/11/07 08:29 PM Re: using a car oil filter for a motorcycle [Re: BGK]
g56 Offline
Loc: USA
That's exactly why I pointed him to the Fram website, they often recommend filters that are commonly available, and from the Fram number you can cross reference it to the brand of your choice.
As an example, Fram recommends a PH6607 for the GL1800, a lot of the guys are running the Super Tech ST6607, you can get them at WalMart for about $2.
AMA Charter Life
#1008290 - 10/11/07 09:00 PM Re: using a car oil filter for a motorcycle [Re: dwendt44]
Loc: CA
I have a CBR600RR sportbike. My car is an Acura RSX Type S.
The RSX uses an M1-110 oil filter. From what I've read, the M1-110's bypass psi is about 11-17psi, whereas the stock Honda bike filter has an 8 psi bypass valve. Yes, they're fairly close.
Looks like I can use this filter for my bike.
#1008291 - 10/11/07 10:54 PM Re: using a car oil filter for a motorcycle [Re: BillWilson]
dwendt44 Offline
The Wix site has a good list of specifications for each filter. Cross reference from the Fram numbers.
#1008292 - 10/12/07 06:42 PM Re: using a car oil filter for a motorcycle [Re: VictoryRed]
Titan Offline
You just find OEM or OEM equivalent filter numbers, and compare them to the filter you are considering. IF they are in the same range, I say they're close enough. Been doing this for over 35 years on bikes, NEVER had an oil-related problem on any bike I've owned. Then again, only one of my bikes had as much as 85,000 miles on it when I sold it. So, it's good for at least 85,000 miles in my experience. YMMV!
#1008293 - 10/13/07 04:08 AM Re: using a car oil filter for a motorcycle [Re: Titan]
Silk Offline
Loc: New Zealand
I used car oil filters on my Honda XLV750 - they were the same as Mazda filters.A good filter catalogue will have filters listed by dimension - thread size,can size,sealing ring dimensions etc.
1994 Mercedes C220 - Penrite Advantage 10/40
1987 BMW R65 - Penrite 20/50
2005 Nissan Expert - MSL 5/30
1996 Volvo T5 - Magnatec diesel 5W-40
#1008294 - 10/13/07 09:56 PM Re: using a car oil filter for a motorcycle [Re: Silk]
mrvfr Offline
Loc: Minnesota
Here is the motorcycle/car filter cross ref. link and some recommendations on which filer brand - Pure One - seem best:
http://motorcycleinfo.calsci.com/FilterXRef.html
08 Highlander V-6 4WD
96 Honda VFR 750
Page 1 of 2 1 2 >
