Oil Pressure with M1HM 10w30
by lukejo
06/27/16 05:56 AM
Clay Based HTB Grease
by SR5
06/27/16 04:33 AM
Which M1 oils are true synthetics
by FordCapriDriver
06/27/16 04:06 AM
That's unfortunate...or maybe bypass filtration?
by linksep
06/27/16 02:24 AM
Over Oiling
by mjoekingz28
06/27/16 12:59 AM
Sweden Trials Electric Higway for Trucks
by Y_K
06/27/16 12:07 AM
17 yo deutsch filter?
by robo339
06/26/16 11:07 PM
Ford Focus wrecked
by tig1
06/26/16 10:13 PM
Valvoline Maxlife vs Supertech Synthetic vs QSED
by mazdamonky
06/26/16 09:56 PM
Lexus seats in a Camry
by Nick1994
06/26/16 09:52 PM
shop rechecking work after front end parts replace
by motor_oil_madman
06/26/16 09:50 PM
M1-EP vs vanilla M1
by Atomic
06/26/16 09:29 PM
Josh_Westwood, Brogan, Superlatives, Ruturaj, derfderfgoose
58280 Registered Users
46 registered (Best F100, billt460, Char Baby, BigRalphie, bandz7, bigdreama, 5 invisible), 1046 Guests and 10 Spiders online.
58280 Members
66 Forums
250859 Topics
Page 1 of 2 1 2 >
#1008002 - 10/10/07 09:03 PM Audi S4 4.2 V8 and Approved Audi/VW Oil
mercury26 Offline
Loc: United States
So I recently purchased a 2007 Audi S4 with 4.2 V8, timing chaing and NO direct injection. Since my goal is hold on to the car for an extended period, I definitely want to treat the engine well. Recently, I purchased the following oil for a 2500 mile oil change:
Motul Specific 505.01/502.00/505.0 5w40 (listed at Vollsynthese on the back, 100% Full Synthetic)
I wonder how it compares to the following:
Elf Excellium DID 5w40
Lubro-Moly (Liqui-Moly) Voll-Synthese 5w40
Has anyone done a comparison on these oils?
Thanks in advance,
Chuck
#1008003 - 10/10/07 09:13 PM Re: Audi S4 4.2 V8 and Approved Audi/VW Oil [Re: mercury26]
Lonnie Offline
Loc: Los Angles, CA
You have seen the Super-Secret thread?
#1008004 - 10/10/07 09:19 PM Re: Audi S4 4.2 V8 and Approved Audi/VW Oil [Re: Lonnie]
buster Offline
Loc: NJ
#1008005 - 10/10/07 09:32 PM Re: Audi S4 4.2 V8 and Approved Audi/VW Oil [Re: buster]
mercury26 Offline
Loc: United States
The S4 doe NOT have Direct Injection fuel injection system. So no, it will not suffer from the same fuel dilution problem as the RS4. Different cars and different engines.
Cheers,
Chuck
#1008006 - 10/10/07 10:18 PM Re: Audi S4 4.2 V8 and Approved Audi/VW Oil [Re: mercury26]
Saab9-3 Offline
Loc: Ontario , Canada
I dont think you can go wrong with Elf or Motul. As for the lubromoly, havent used it, or heard much about it yet.
#1008007 - 10/11/07 12:06 AM Re: Audi S4 4.2 V8 and Approved Audi/VW Oil [Re: mercury26]
RI_RS4 Offline
Loc: Rhode Island
Cheers,
Chuck
Mercury, The S4 V8 still suffers from fuel dilution, although at a lower level. Substantial portions of the engine design are similar. The biggest problem with that V8 and the FSI V8 are the three chains used for cam and pump drive. S4 V8's are starting to show problems in later life with cam chain tensioners and cam chain problems. Since there is still some dilution going on, you will see accelerated wear of these components. BTW, I had a B6/S4 before I bought the RS4.
If you want to stay with 502 oil, I would recommend Lubro-Moly Vollsynthese 5w40. It has performed the best out of all the 502 oils in our RS4 testing.
If you are willing to go with a pseudo-502 oil, I can recommend Amsoil European Formula 5W-40, which is an excellent oil, and outperforms any of the "502 approved" oils.
For either of the above two oils, use a 5K oci, until you do a UOA and get direction from someone like Terry Dyson.
However, if you want the best oil for your engine, definitely go with the RLI BioSyn 5W-40 HD oil designed for the RS4. It is perfect for your engine, will allow at least a 7.5K OCI and possibly a 10K OCI, and will reduce cam chain wear.
BTW, you really don't want the cam chain or tensioners to need to be replaced outside of warranty. It's at least a 2-day job and requires the engine to be pulled.
#1008008 - 10/11/07 12:11 AM Re: Audi S4 4.2 V8 and Approved Audi/VW Oil [Re: RI_RS4]
Camu Mahubah Offline
Loc: the Sandhills of Nebraska
I do say...rather excellent recommendations from RI_RS4!
#1008009 - 10/11/07 01:55 AM Re: Audi S4 4.2 V8 and Approved Audi/VW Oil [Re: Camu Mahubah]
mercury26 Offline
Loc: United States
Thanks for your input (RI_RS4) and you are right timing chains/tensioners going bad outside of warranty can be very expensive. I had a Passat W8 before my S4 that I purchased used, well at 45,000 miles I was getting excessive noise from the tensioner. Luckily, the car was under warranty or it would have been expensive to fix. My goal is to do a 2500 mile oil change, coming up in the next couple weeks. I will then be switching to Motul and then Lubro-Moly with a 5K OCI. Yes, it will be expensive but worth it to protect the engine. Since I have already purchased the Motul, then I will use it but work on moving on. I did get the Blackstone kit, wonder if the dealership will take a sample for me. I am taking it in for the 5k service trip to get something fixed and an oil change (but bringing my own oil).
Too bad, RLI has not been approved on the VW/Audi oil list, would be a good thing for them. I checked out their website and sounds like they have some nice products.
Cheers,
Chuck
#1008010 - 10/11/07 02:31 AM Re: Audi S4 4.2 V8 and Approved Audi/VW Oil [Re: mercury26]
RI_RS4 Offline
Loc: Rhode Island
Cheers,
Chuck
Chuck, yes it's too bad. But Audi/VW approval costs about $1/4 Million.
#1008011 - 10/11/07 03:16 AM Re: Audi S4 4.2 V8 and Approved Audi/VW Oil [Re: RI_RS4]
mercury26 Offline
Loc: United States
Yeah, I understand how that goes for a smaller company. Castrol has some deep pockets, too bad a lot their products are not up to snuff.
I will probably use the Lubro-Moly until I am out of the warranty period, and then switch to RLI product.
Thanks again for your help.
Cheers,
Chuck
#1008012 - 10/11/07 03:48 AM Re: Audi S4 4.2 V8 and Approved Audi/VW Oil [Re: mercury26]
buster Offline
Loc: NJ
I'd listen to RS4.:) Amsoil 5w-40 if you can't use the RLI 5w-40. I would also like to see someone try Redline 5w-40. HT/HS of 4.6. It's not an API approved oil though.
#1008013 - 10/12/07 10:42 AM Re: Audi S4 4.2 V8 and Approved Audi/VW Oil [Re: buster]
Lonnie Offline
Loc: Los Angles, CA
If you use LubroMoly would you get some uoa's and post them. No one knows much about the oil.
#1008014 - 10/12/07 08:19 PM Re: Audi S4 4.2 V8 and Approved Audi/VW Oil [Re: Lonnie]
ssj4 Offline
Loc: MD
Edited by ssj4 (10/12/07 08:20 PM)
[image]http://img365.imageshack.us/img365/2539/untitled17rm.jpg[/image]
#1008015 - 10/12/07 10:02 PM Re: Audi S4 4.2 V8 and Approved Audi/VW Oil [Re: ssj4]
StoicDude Offline
Loc: Reno, NV
After reading this, I am kind of glad I have a timing belt instead of the timing chain. hahah
I was kind of getting a bit upset about the timing belt and was seriously thinking about a car with a timing chain as my next car. I knew the tensioners on the chains were susceptible (from my motorcycle experience) so I guess the belts are not that bad.
Replacing the belt is certainly a pain, but I am sure not as much a pain as replacing a chain.
LubroMoly is a great oil and I would certainly think about trying it, but I am sticking with Mobil 1 till my stash is out.
RLI seems to be kicking some butt though.
#1008016 - 10/16/07 07:11 AM Re: Audi S4 4.2 V8 and Approved Audi/VW Oil [Re: StoicDude]
itb76 Offline
Loc: Whitehall, MI
It's not the chain that's so difficult, it's everything that goes wrong when pistons hit valves...
Page 1 of 2 1 2 >
