Recent Topics
Trans/Hydraulic Fluid for Old Tractor?
by 333jeffery
02/12/16 04:27 PM
Does air go stale?
by mjoekingz28
02/12/16 04:13 PM
RAILROAD GUYS: What is this sound and one other Q
by SumpChump
02/12/16 03:59 PM
Got a free 5gal bucket of Mobil SHC 627
by MinamiKotaro
02/12/16 02:59 PM
Hard starting LCT snow engine..
by JTK
02/12/16 02:34 PM
low-temperature oil gelling reversible?
by DrRoughneck
02/12/16 12:51 PM
I HAD to do it!
by Kuato
02/12/16 12:24 PM
Why Erin Esurance vanished from TV
by Benzadmiral
02/12/16 11:39 AM
Engine Light Advice
by coopns
02/12/16 11:14 AM
Caution UOA - PP 10W30 6881m on 2001 Jeep 4.0
by Donald
02/12/16 11:09 AM
What happened to the thin oil movement?
by camrydriver111
02/12/16 10:57 AM
Mastercraft Strategy tires (I'm cheap)
by Bgallagher
02/12/16 10:41 AM
Newest Members
RTS, jhmed80, engus, Rob_Pol, Nick24w
56901 Registered Users
Who's Online
100 registered (333jeffery, 2010Civic, 18LateModelFan, 97K15004WD, 901Memphis, 19kj57, 10 invisible), 1718 Guests and 193 Spiders online.
Key: Admin, Global Mod, Mod
Forum Stats
56901 Members
66 Forums
244606 Topics
Max Online: 2862 @ 07/07/14 03:10 PM
Donate to BITOG
Page 2 of 2 < 1 2
Topic Options
#3454371 - 08/13/14 10:39 AM Re: Want aftermarket radiator and water pump advice [Re: Clubber_Lang]
Clubber_Lang Offline
Loc: SC
After much reading i changed my water pump order to...a gates. Although it was priced low at $23, suprisingly it has a reputation for being a good choice.
As for the radiator, i was tempted by some 3 row all aluminum radiators for sale on ebay. They were very decently priced but obscure brands that made them seem like a gamble, but for $200 they were tempting.
I just replaced the T-stat 100 miles ago with a stant. While im in there who would change it out with OEM? Im tempted but like i said the stant is brand new, except for being exposed to prestone flush and radiator gunk for the past 5 days in my attempt to revive the old radiator.
Edited by Clubber_Lang (08/13/14 10:39 AM)
_________________________
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Sir W.C.
#3454732 - 08/13/14 06:22 PM Re: Want aftermarket radiator and water pump advice [Re: Clubber_Lang]
Kruse Offline
Loc: Kansas
Gates water pump pro: lifetime warranty
Gates water pump con: 100% made in China (but then, a lot of them now are)
#3454775 - 08/13/14 07:31 PM Re: Want aftermarket radiator and water pump advice [Re: Clubber_Lang]
01rangerxl Offline
Loc: Birmingham, AL
I would return the $23 water pump. If that is not an option, put it on a shelf as an emergency back up. No freaking way would I replace a functioning OEM water pump with some $23 China part just because it has 155K miles. The 155K mi OE pump may very well have more life left in it than the China pump.
2002 Ford Ranger XLT | 3.0 V6 / 5-Speed Automatic / 2WD | 180K miles
1994 Ford Ranger STX | 4.0 V6 / 5-Speed Manual / 4X4 | 176K miles
#3454800 - 08/13/14 08:11 PM Re: Want aftermarket radiator and water pump advice [Re: Clubber_Lang]
Riick Offline
Loc: Northern Delaware
Only problem with some plastic radiators is, if cheaply made, thin-walled necks get brittle with age & fail from over-tightening the hoses. My last Toyota went 185,000 miles without a problem, while e36 BMWs (323/325/328) fail like clockwork at around 85,000 miles.
Sure, *this* time it's different (ROTFL)
#3454804 - 08/13/14 08:18 PM Re: Want aftermarket radiator and water pump advice [Re: Clubber_Lang]
jk_636 Offline
Loc: Texas
I only use Gates belts, hoses and water pumps. Gates has been around for years and they really do make quality products.
2006 Dodge Ram 1500 4.7 [Mobil 1 0w30+ Purolator synthetic or P1]
2012 Ford Escape 3.0 [Royal Purple 5w20 + Purolator Synthetic or RP Extended Life]
#3454887 - 08/13/14 10:19 PM Re: Want aftermarket radiator and water pump advice [Re: Clubber_Lang]
stephen9666 Offline
Loc: USA
Gates hard parts are not my cup of tea. It seems they're often plain-Jane Chinese white box parts with a Gates sticker. For a water pump I'd choose a different brand.
Maybe some of them are good, but some of the gates parts I've purchased and seen were not impressive.
#3455409 - 08/14/14 02:49 PM Re: Want aftermarket radiator and water pump advice [Re: Clubber_Lang]
Chris142 Offline
Loc: apple valley, ca
Will an all aluminum radiator typically outlast a plastic one?
often they are worse. when it heats up it expands. the aluminum tanks wont let it expand so it crushes the tubes in the corners and they leak. generally not repairable.
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3455459 - 08/14/14 03:22 PM Re: Want aftermarket radiator and water pump advice [Re: Clubber_Lang]
DoubleWasp Offline
Loc: Fort Lauderdale, FL
Stay away from the GMB pumps. I've seen many of them fail within 150-5000 miles. Don't know what they are doing, and I'm not sure they do either. Bosch pumps I have installed have never come back. All I use on my vehicles.
2007 Lincoln Navigator M1 0w-40/FU
1968 Charger R/T / Supercharged 440 VR1/DBL7349
2007 Ram 3500 4x4 / Cummins 6.7 /DBL7349
2015 Porsche 911 C4S PDK
#3455594 - 08/14/14 05:07 PM Re: Want aftermarket radiator and water pump advice [Re: Clubber_Lang]
asand1 Offline
Loc: Oregon coast
My advice would be flush and back-flush your OEM radiator, and don't replace a good working OEM waterpump with a new Chinese one.
Unless it is timing belt driven, if it ain't broke, don't fix it.
Nissan/Infinity/Mazda Manuals
1996 Maxima 310K
2008 Uplander 80K
Page 2 of 2 < 1 2
