Recent Topics
Purolator L14476 with OPE
by SwampDweller
02/12/16 06:09 AM
WRX or GTI?
by GumbyJarvis
02/12/16 02:50 AM
Single cylinder versus twin
by mjoekingz28
02/12/16 01:12 AM
Mobil Super Syn vs ...others
by Yup
02/12/16 12:45 AM
2016 WRX
by Silver02ex
02/11/16 11:58 PM
Class Action Lawsuit Against Oil Filter Company?
by crazyoildude
02/11/16 11:42 PM
PL10241 Cut Open
by Vegoose
02/11/16 11:15 PM
Seems like common sense to me......
by Doog
02/11/16 11:14 PM
Thinking of buying an old diesel Benz
by Diego3336
02/11/16 10:46 PM
Mobil 1 5W30 5279 Miles 06 Toyota Tacoma V6 401k
by qnyla
02/11/16 09:43 PM
2007 corolla oil pan steel or aluminum?
by Rolla07
02/11/16 09:07 PM
Taiwan DMV "Mechanical Knowledgee" Test Question
by Ducked
02/11/16 08:56 PM
Newest Members
engus, Rob_Pol, Nick24w, SkipKaye, MikeHancho
56899 Registered Users
Who's Online
53 registered (BillyTheKid, Al, 04SE, Astro_Guy, bullwinkle, bama7x57, 6 invisible), 693 Guests and 200 Spiders online.
Key: Admin, Global Mod, Mod
Forum Stats
56899 Members
66 Forums
244582 Topics
Max Online: 2862 @ 07/07/14 03:10 PM
Donate to BITOG
Topic Options
#3430284 - 07/20/14 02:38 PM GM Passkey III didn't require programing?
Falcon_LS Offline
Loc: Kuwait
So I lost the master key for my Envoy, so I got a new fob and coded key from the dealer. They asked me to come back tomorrow for programming, so I figured I'd do it myself.
I put the new uncoded key in the ignition and turned it on - five seconds later the security light went off. I cranked the engine and it fired right up! I tried the 2nd memory key and it fired right up. Am I missing something here?
_________________________
99 Explorer EB: M1 0W40/FL1A
00 Pajero: M1 0W40/26300-35503
01 Marquis: M1 ESP 5W30/FL820S
03 Expedition: M1 0W40/FL820S
05 Envoy: M1 ESP 5W30/M1-206
#3430325 - 07/20/14 03:25 PM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
Trav Offline
Loc: MA, Mittelfranken.de
Try leaving the Master in the house and try it.
ASE L1, Master. Deutsch Meisterbrief.
#3430331 - 07/20/14 03:39 PM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
eljefino Offline
Loc: ME
Maybe someone put in a remote starter and it has a bypass module you don't know about. Did you get it new?
#3430345 - 07/20/14 03:56 PM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
Falcon_LS Offline
Loc: Kuwait
Trav - same thing. shrug
I bought it off the original owner who never changed/added anything.
Based on what I've read, it appears I have a Pass-Lock system, which to my understanding is different than Pass-Key. To my understanding, there is no chip in the key - which explains why it cost $10 for a Genuine GM key vs. $30 for my Ford PATS key - the key is just used to make contact between the tip and the base of the ignition cylinder. The resistor is apparently located in the ignition cylinder itself. Maybe that explains why.
#3430360 - 07/20/14 04:15 PM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
dishdude Offline
Loc: Phoenix
Passlock just checks to make sure there is a key in the cylinder, passkey III has a transponder chip in the head of the key and requires programming. Is there any marking on the blade of the key such as PK3 or a circle with a + in the center?
2015 Grand Cherokee 1k mi
2001 GMC Sonoma 207k mi
#3430370 - 07/20/14 04:26 PM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
Falcon_LS Offline
Loc: Kuwait
No markings on the key.
#3430422 - 07/20/14 05:36 PM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
dishdude Offline
Loc: Phoenix
No marking on the key means it is a Passlock system, no programming necessary.
#3430606 - 07/20/14 08:34 PM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
itguy08 Offline
Loc: Central PA
So what exactly is this system supposed to prevent? Hot wiring can still be done - just put any old key in there....
#3430672 - 07/20/14 09:13 PM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
George7941 Offline
Loc: Toronto, Canada
Hot wiring will not work on Passkey systems since there are Hall effect sensors in the ignition lock cylinder and the BCM must see the pattern generated when the ignition key is turned normally, else the BCM does not enable fuel.
2006 GMC Sierra 4.3l, NV3500,G80 locker rear, Formula Shell Synthetic 5W30, Wix 51036, Dexcool.
1987 BMW R80
Staying out of the right lane a lot.
#3430838 - 07/21/14 06:15 AM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
eljefino Offline
Loc: ME
^ yup that.
Deliberately confusing terminology on GMs part. But, they still get credit for putting passlock on the cheaper cars-- it still deters theft.
#3430862 - 07/21/14 07:04 AM Re: GM Passkey III didn't require programing? [Re: George7941]
itguy08 Offline
Loc: Central PA
That makes better sense. Thanks.
