Recent Topics
Superbowl and Willie Woods
by Donald
02/07/16 08:32 AM
Rural King Synthetic
by MarkM66
02/07/16 08:32 AM
Lesson learned from rebuilding updraft carb
by Donald
02/07/16 08:12 AM
UOA on QSUD 0W20 coming soon!!!
by thorromig
02/07/16 08:05 AM
Which 0w-20 would you pick? (Based on specs)
by tam92
02/07/16 07:48 AM
Kohler Courage SV735-0013
by Mavigraph
02/07/16 07:46 AM
nearly 20k miles of research gone ....
by meborder
02/07/16 06:46 AM
New - smoke detectors for house.
by bmwjohn
02/07/16 03:45 AM
ProGauge PGO-4612 Oil Filter??
by andrewp1998
02/07/16 01:11 AM
Filter efficiency and diminishing returns
by ToadU
02/07/16 12:19 AM
Change PP after 1000 mi 6 month Short Winter Trips
by WillsYoda
02/07/16 12:00 AM
Tread Life & Curvy Roads
by Nick1994
02/06/16 11:46 PM
Newest Members
Nazmorgul, bhans, truthtracer, Recreator, 18LateModelFan
56842 Registered Users
Who's Online
85 registered (1989outlaw, 77GrandPrix, 90crvtec, 901Memphis, A1O, 6 invisible), 1298 Guests and 204 Spiders online.
Key: Admin, Global Mod, Mod
Forum Stats
56842 Members
66 Forums
244355 Topics
Max Online: 2862 @ 07/07/14 03:10 PM
Donate to BITOG
Page 2 of 2 < 1 2
Topic Options
#3285610 - 02/17/14 08:11 PM Re: Next-generation Tundra to get cummins diesel [Re: mikered30]
sevenznuf Offline
Loc: mount airy nc
these full-size Toyota trucks are the ugliest trucks on the road!!! I like the tacomas but these suck. don't matter what they put in it I will never buy one of them
#3285784 - 02/17/14 11:17 PM Re: Next-generation Tundra to get cummins diesel [Re: hattaresguy]
whip Offline
Loc: ohio
Originally Posted By: hattaresguy
Cummins is really pimping around their new light duty diesel.
Maybe one day I'll be able to buy a diesel in a base half ton instead of a $50k look at me tonka truck.
I still think the 4 cylinder Cummins that Nissan had in their show truck would be amazing in a base 2014 Silverado for around $22k sicker, hint GM, hint GM.
About 6-7 years ago, GM had a light duty V8 diesel, but they scraped it before they ever produced it. They might be bringing it back.
http://www.leftlanenews.com/chevy-silverado-1500-gmc-sierra-1500-to-get-diesel-option.html
_________________________
On the internet, people can be anything they want. Why do so many choose to be stupid?
#3295520 - 02/26/14 08:00 PM Re: Next-generation Tundra to get cummins diesel [Re: mikered30]
FL-400S Offline
Loc: Southeast
Is the diesel for better mpg, or higher towing, or both?
I wouldnt mind a big pickup that could push 25-30 mpg, if that is even possible. Diesel electric hybrid?
#3295599 - 02/26/14 09:27 PM Re: Next-generation Tundra to get cummins diesel [Re: FL-400S]
dave1251 Offline
Loc: Maricopa, AZ
RAM 1500 already has a pickup with a estimated fuel economy of 25MPG highway in its 3.6 V6 and 8 speed auto.
make the inside of your engine oil cap white.
don't use.
#3295760 - 02/27/14 01:28 AM Re: Next-generation Tundra to get cummins diesel [Re: mikered30]
MNgopher Offline
Loc: Lakeville, MN
And that's the rub. The fuel economy numbers we are hearing for these diesels is not extraordinarily higher than that of some of the gas powered trucks. Given the generally substantially higher initial purchase price of the diesel, plus the significant extra cost of diesel fuel (gas is currently around 3.52 a gallon, diesel is around 3.86 a gallon - about 10% a gallon higher on average), payback is going to be an issue unless placed in the right duty cycle.
I was once on this bandwagon - give me a mid-range hp diesel motor with decent torque (call it a mid range power option) with substantially higher fuel mileage and I'd bite. Then gas and diesel prices flip flopped so diesel is higher priced (and has been for years here), and gas rigs have steadily been doing better at fuel mileage, while diesel options have struggled now that they are saddled with all the emissions gear... and well, now I'm not sold.
#3295897 - 02/27/14 07:44 AM Re: Next-generation Tundra to get cummins diesel [Re: mikered30]
supton Offline
Loc: NH
I coulda sworn I had seen a site that did an mpg test while towing. And it was impressive--like 20 while pulling several thousand pounds. Diesels tend to drop less mpg under load--less of a need to drop down a gear, less frictional losses, probably other factors too. Until Ecoboost came along one either went diesel to get lots of umph at low rpm--or just got the biggest motor they could.
My wife's Camry has more hp but less tq than my Jetta. I've always preferred how my engine lays down power off idle though, while the Camry needs rev's to do anything. Pure personal opinion. I like how diesel drives, but for my mild usage the TCO simply isn't there.
2011 Toyota Camry, base, 6spd manual, 107k, hers
2010 Toyota Tundra double cab, 4.6L, auto, 114k, his
#3296213 - 02/27/14 12:22 PM Re: Next-generation Tundra to get cummins diesel [Re: mikered30]
hattaresguy Offline
Loc: CT
Diesels lost a lot of their advantage over gas motors in the past 10-20 years, modern good fuel injection really closed the gap between the two.
Back in the 80's the advantages were large, even in the 90's. But these days the gas motors are cheaper to run and last just as long.
Part of the reason is the silly modern emissions regulations that really hurt diesels in this country.
#3296334 - 02/27/14 02:03 PM Re: Next-generation Tundra to get cummins diesel [Re: mikered30]
rslifkin Offline
Loc: Rochester, NY
Set up properly (good gearing, properly sized motor for the load, etc.) a diesel will get better mpg unloaded and towing lighter loads, as well as in applications with significant idle time. However, if you're towing heavily loaded in the mountains, the mpg difference shrinks a lot as both engines are under enough load to be close to peak efficiency. The key is that gas engine efficiency drops off faster as you stray from that peak while a diesel has a better load / fuel consumption curve.
1998 Jeep Grand Cherokee 5.9 Limited with lots of mods (201k miles, bought with 100k in 1/2010)
Rotella T6 @ 6k OCI
#3299303 - 03/02/14 02:30 PM Re: Next-generation Tundra to get cummins diesel [Re: mikered30]
Spazdog Offline
Loc: Arlington
Copying the Titan? I thought the Titan was supposed to go away and be replaced by a rebadged Ram.
2013 Chevrolet Cruze Eco - dealer Dexos
2014 Chrysler 200S - Whatever the dealer put in it.
1987 Honda CN250 Helix - Penn Platinum Euro5W40
Page 2 of 2 < 1 2
