Recent Topics
Speed Painting
by Merkava_4
08/26/16 08:32 AM
Shell Rotella T6 & T5 - $5 rebate per gallon
by Bighorn2500
08/26/16 08:10 AM
ACDelco X66P
by OldEuroCarLover
08/26/16 12:07 AM
FL910S C&P, 4,000 miles
by cb4017
08/26/16 12:02 AM
Mobil 1 Full Synthetic $3.99 AR Menards
by John_K
08/25/16 10:32 PM
Causes of steering wheel shudder
by buck91
08/25/16 10:14 PM
Brand new Focus ST...
by Striker
08/25/16 09:55 PM
Chevy Volt bad idea for BITOG members!
by kohnen
08/25/16 09:22 PM
Looking for oil suggestion Chevy Express 3500 6.0L
by Goofball1205
08/25/16 08:38 PM
What ATF? 2004 Toyota Sequoia 4WD
by ShadowSix
08/25/16 08:35 PM
Tundra steering wheel
by RN89
08/25/16 08:11 PM
98-02 Corolla and Oil Consumption
by mmorri16
08/25/16 08:10 PM
Newest Members
rgmbedzi3, wildkid2008, dccode, dromonk, sledhead1
58930 Registered Users
Who's Online
84 registered (adamrc, 87sammy, 09_GXP, alarmguy, 2015_PSD, 901Memphis, 4 invisible), 1344 Guests and 38 Spiders online.
Key: Admin, Global Mod, Mod
Forum Stats
58930 Members
66 Forums
253570 Topics
Max Online: 2862 @ 07/07/14 03:10 PM
Donate to BITOG
Topic Options
#3256439 - 01/22/14 03:15 PM Does sodium, if not additives, always = coolant?
Ayrton Offline
Loc: Washington State, U.S.
I noticed this on one of my cars. 35PPM sodium. I also noticed it on some other people's UOAs of same engine, but not early in the life, once the car had 40,000+. When the cars are newer, they had like 8ppm Sodium.
Is it a very small amount of coolant getting into the oil? The engines never had oil with sodium additive.
Is there any other explanation? Can sodium be normal for any reason if not an additive?
I do notice the car has a small amount of coolant disappear over say 5,000 miles, enough to go from hot to cold in reservoir lines, about 6 ounces, but I have had other cars that had coolant slowly go away too that didn't show it in oil analysis.
So yeah, just trying to find out if there is ever any normal reason to see sodium?
Techron is often used, but any idea if it causes sodium to appear?
Edited by Ayrton (01/22/14 03:16 PM)
#3256452 - 01/22/14 03:39 PM Re: Does sodium, if not additives, always = coolant? [Re: Ayrton]
Rand Offline
Loc: NE,Ohio
you shouldnt be losing 6oz in 5000miles. maybe 2-3oz a year if its not a pressurized reservoir
_________________________
2015 Forester I-Premium 6MT
#3256460 - 01/22/14 03:46 PM Re: Does sodium, if not additives, always = coolant? [Re: Ayrton]
Clevy Offline
Loc: Saskatoon canada
Losing coolant is always bad.
I suggest pressure testing your coolant system. If a problem exists fix it immediately because its not going to get better.
And no there shouldn't be any sodium in the oil unless the brands additive package contains sodium,valvoline comes to mind.
If you've got to add to the cooling system you've got a problem.
2006 Charger RT
Miles x 2 per oil filter
#3256461 - 01/22/14 03:47 PM Re: Does sodium, if not additives, always = coolant? [Re: Ayrton]
Clevy Offline
2006 Charger RT
#3256485 - 01/22/14 04:02 PM Re: Does sodium, if not additives, always = coolant? [Re: Ayrton]
Ayrton Offline
Thanks. It's funny because even a brand new 2005 Nissan Altima I had for a while, I always had to add coolant, every 6 months or so right from the start.
I thought it was normal as nearly every car I have had needed coolant top offs except Mercedes.
Good to know this is wrong. I'm still perplexed in the current car why this would be happening. I do see quite a few UOAs where people have this 30ppm range of sodium though.
Oh well, I will keep investigating.
Edited by Ayrton (01/22/14 04:04 PM)
#3256524 - 01/22/14 05:05 PM Re: Does sodium, if not additives, always = coolant? [Re: Ayrton]
earlyre Offline
Loc: Lima, Ohio, USA
some companies, Valvoline for one, do use sodium as a additive in their mix...
here's a link to a VOA of mine on a "frankenbrew" of sorts, leftover ~.5 qts from several oilchanges all mixed together, and you'll notice, this never been run oil has 144ppm Sodium
In their Notes Blackstone points out "Sodium, Calcium, and Magnesium are Detergent/Dispersant additives":
http://www.bobistheoilguy.com/forums/ubb...mp;#Post3167824
Mine:
09 Mercury Sable : 6qts QSAD 5w20,WIX 51516
Mine to Maintain:
03 Pontiac Vibe : 4.5qts QSAD 5w30,WIX 51394
#3256655 - 01/22/14 07:18 PM Re: Does sodium, if not additives, always = coolant? [Re: Ayrton]
fdcg27 Offline
Loc: OH
If you look at VOAs, there are often trace amounts of sodium and potassium, in the few ppm range.
An engine that's had oil with a sodium add pack will often show higher than expected levels of sodium in later UOAs.
If you're using a coolant that contains potassium and if sodium levels are maybe 8-10 ppm with lower potassium levels, then I don't think you'd have much to worry about.
You actually saw 40K ppm of sodium in a UOA?
That would be a serious red flag and I'd ask the lab to re-run the sample, since that level strains credibility.
The main value of UOAs is in watching the trend.
If the trend is consistent, then I'd say no worries.
If sodium and potassium increase steadily, then you probably have coolant getting into the oil and you'd then have to decide whether to fix or just run on.
While coolant in the oil is never a good thing, a little bit isn't instant death either.
Maybe death in another 50-100K, by which time the whole machine will likely be ready for the yard.
You'd also need to consider the value of the machine versus the cost of repairs.
You or I would spend more on any Ferrari than we'd spend on any Chrysler/Chevy/Ford/Honda/Toyota/Lexus/and so on.
You get the point.
12 Accord LX 53K HGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 159K Delvac 15W-40
#3256796 - 01/22/14 08:51 PM Re: Does sodium, if not additives, always = coolant? [Re: Ayrton]
Ayrton Offline
Thanks! I'm sending in another oil sample to see if it stayed the same, went up, or trended down.
I'm 90+ percent sure this car never had an oil with sodium though (I am familiar with the use as an additive). It pretty much always had Mobil 1 0w-40 or 5w-30 it looks like.
It had 2ppm Potassium on the first analysis, BUT I'm not sure if Dexcool uses Sodium, Potassium or both? I think it depends on what brand of dexcool is in the car, and I don't know.
I will simply have to look at this next UOA and see how it goes.
If it was a leak, but it truly stayed around 31 PPM, I don't think that is a particularly bad leak, but who knows what will happen.
Edited by Ayrton (01/22/14 08:51 PM)
