Recent Topics
Motorkote ??
by Moondawg
07/29/16 08:53 AM
Windows 10 For Free Last Day
by NHHEMI
07/29/16 08:24 AM
HD Truck Maintenance Costs - Wow!
by Miller88
07/29/16 08:10 AM
1,000,000 mile Tundra
by Hokiefyd
07/29/16 07:34 AM
Choosing oil with both CJ4 and SN specs
by devarshi84
07/29/16 07:11 AM
Stapled down carpets ???
by Oldtom
07/29/16 01:51 AM
MicroGard (Wix) 57047 ~7k miles
by MrQuackers
07/29/16 01:24 AM
Ford 4.6 with Supercharger, 2,000 mi. / yr.
by milkboy
07/29/16 12:50 AM
Only secure content is displayed?
by Eddie
07/28/16 11:35 PM
2008 Honda Element oil question
by fujirio
07/28/16 09:50 PM
TIRE QUESTION
by renegade_987
07/28/16 09:46 PM
What's your favorite outboard and why ??
by BrocLuno
07/28/16 09:30 PM
Newest Members
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
Who's Online
75 registered (2015_PSD, 09_GXP, 2009Edge, 87sammy, 2010Civic, 2002 Maxima SE, 6 invisible), 1789 Guests and 11 Spiders online.
Key: Admin, Global Mod, Mod
Forum Stats
58632 Members
66 Forums
252390 Topics
Max Online: 2862 @ 07/07/14 03:10 PM
Donate to BITOG
Topic Options
#3255896 - 01/22/14 06:29 AM cleaner better for duration oil
rhondas Offline
Loc: USA
my daughter has a Lincoln and it requires a 5 W 20 oil weight nothing else .
my Nissan pathfinder require 5 W 30 -10 W 40 oil . weight
when I do an oil change on my daughters Lincoln you can see the timing chain inside the oil fill hole and its pristine clean - now on my pathfinder the parts inside the oil fill hole look darkened used like a 57 Chevy would look like ,so if I used the 5 W 20 oil in my pathfinder would it be a cleaner engine . both use the same name oil and filters-Castrol oil
thanks for an answer
_________________________
Rhondas
#3255900 - 01/22/14 06:33 AM Re: cleaner better for duration oil [Re: rhondas]
Wilhelm_D Offline
Loc: Tacoma, WA
Whatever is going on, it has nothing at all to do with the viscosity of the oil.
#3255933 - 01/22/14 07:23 AM Re: cleaner better for duration oil [Re: rhondas]
901Memphis Offline
Loc: Northern Kentucky
Castrol - Thats your problem, try Pennzoil. Castrol has notoriously weak additive packages compared to most others..
http://www.pqiamerica.com/CastrolGTX.htm
http://www.pqiamerica.com/Pennzoil.htm
http://pqiamerica.com/March2013PCMO/Marchsyntheticsallfinal.html
2002 Buick Century 125k - Built 4T65e(Maxlife) - Syn Frankenbrew + XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3255935 - 01/22/14 07:25 AM Re: cleaner better for duration oil [Re: rhondas]
bigjl Offline
Loc: London, England
Are you using full synth, semi, blend or mineral?
Is it possible you are using mineral and your daughters car uses full synth?
I have used mainly full synth oils for the last few years.
Used synth blend once, Maxlife.
And have used semi synth as a minimum since 03/04.
Maybe i am wasting money.
But i have never had any oil related or sludge.
What kind of oci have been doing in the Pathfinder?
I do 5k in mine, usually between 6-8 months on average.
But mine is diesel so not like for like.
But is heading steadily to 120k miles with no issues so far.
14 Kia Picanto 1.0 City 10k miles. Kia 5w30
07 Citroen Berlingo Multispace 1.4i 39k 10w40 Maxlife
#3255965 - 01/22/14 08:00 AM Re: cleaner better for duration oil [Re: 901Memphis]
volk06 Offline
Loc: Iowa
I disagree. The problem with this statement is you are using a VOA which does not tell the whole story. Especially since the formula you linked for GTX is no longer the formula for the current version. Also edge had one of the highest starting TBNs. Not to mention the formula for GTX you linked was virtually identical to VWB.
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
#3255991 - 01/22/14 08:40 AM Re: cleaner better for duration oil [Re: rhondas]
aquariuscsm Offline
Loc: South Texas,USA
Give us some more info:
Year,miles,and oci length on both cars.
Type of Castrol you and your daughter are using.
Type of driving both cars are subjected to.
Do not use a 20 weight oil in your Nissan. Stick with a 30-40 weight. My Nissan requires a 10W30-20W50 at 3k,3 month oci`s via fsm. What does Nissan say about yours?
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Syntec 10W40/Fram Ultra
Amsoil MTG(tranny)
Amsoil 80W90 GL5(rear diff)
Mobil 1 ATF
Redline Water Wetter
#3256031 - 01/22/14 09:16 AM Re: cleaner better for duration oil [Re: rhondas]
Michael_P Offline
Loc: By the Lake
You will decrease the life of the timing chain with a XW20 oil on a Nissan VQ engine. That is straight from Nissan.
#3256114 - 01/22/14 10:58 AM Re: cleaner better for duration oil [Re: rhondas]
Zaedock Offline
Loc: Massachusetts
Two different engines and applications!
Stick with the recommended weights.
2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2004 Malibu Maxx LT
1975 Ford Bronco/1959 Willys CJ5/20XX Custom rock crawler
#3256143 - 01/22/14 11:27 AM Re: cleaner better for duration oil [Re: rhondas]
Doog Offline
Loc: North Coast
Switch both to Pennzoil Platinum and keep the factory recommended weights. You will notice the engines get cleaner over time.
The difference between a beer and your opinion is that I asked for a beer... well except for just now..:-)
#3256157 - 01/22/14 11:43 AM Re: cleaner better for duration oil [Re: volk06]
ARCOgraphite Online   content
Loc: N.H, U.S.A.
Agree, You cant look at a VOA and tell which oil is better for scavenging and detergency action unless its been misformulated - this is NOT 1980 oil chemistry. In fact certain and MORE metallic ( spectroscopically reportable/ visible AW compounds can lead to MORE piston deposits reportable in situ engine deposit ranking tests. E.G.: MolyDithiocarbamate
Memphis might just be flaming a bit as bitog'ers can get riled so easily smile
Edited by ARCOgraphite (01/22/14 11:45 AM)
2014 Nissan Rogue S CVT, OC#4 19671mi-Castrol EDGE EP 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#6 41243mi-M1EP 0W20+Subaru Filter
#3256489 - 01/22/14 04:08 PM Re: cleaner better for duration oil [Re: rhondas]
901Memphis Offline
No in not flaming, seriously think Castrol GTX is the bottom of the barrel for conventional name brands. I like edge just not GTX. Not a huge fan of VWB either.
#3256746 - 01/22/14 08:22 PM Re: cleaner better for duration oil [Re: 901Memphis]
volk06 Offline
Loc: Iowa
Then you'd be interested to know that GTX now has a new additive package that does not use sodium and has over 2000ppm CA on par with others. It meets SN and most basic manufacturer specs... its not "that bad".
I've never been a GTX or VWB fan due to the low CA and high NA content but they produce some of the best looking UOA out there. Curious to see how this new GTX does.
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
#3256999 - 01/23/14 02:57 AM Re: cleaner better for duration oil [Re: volk06]
Clevy Offline
Loc: Saskatoon canada
I've noticed the same thing volk. Yeah castrol may not look great on paper however a voa doesn't tell the whole story.
And the castrol syn's used oil analysis that have been posted recently looked absolutely stellar on iirc 12000 mile or 14000 mile interval or something like that.
Castrol makes some stellar products no matter what they look like on paper.
I don't use gtx so I cannot comment on it but I have used castrol's 5w-20 syn and ran it for 10000 without complain nor any obvious change in running condition.
I got it on rollback of course. I'd use it again
2006 Charger RT
Miles x 2 per oil filter
