Recent Topics
Avoiding short trips like the plague
by FordCapriDriver
06/25/16 03:11 AM
API CK-4
by JustPlainFolks
06/25/16 02:37 AM
Rotella T
by momo
06/25/16 01:51 AM
3,000 mile OCI/severe service/newspaper delivery?
by Aurora09
06/24/16 11:46 PM
move over esters...time for alkylated napthenes
by Shannow
06/24/16 10:46 PM
ear wax and ear plugs
by motor_oil_madman
06/24/16 09:26 PM
Discount Tire Direct 4th of July Sale
by sopususer
06/24/16 08:37 PM
What kind of oil drain plug gasket is this?
by Chris B.
06/24/16 07:36 PM
by Chris B.
06/24/16 07:34 PM
First time changing oil what to use ?
by sshazam
06/24/16 07:13 PM
toshiba 720p 28" TV hdmi to thinkpad vga cable?
by bmwjohn
06/24/16 06:48 PM
1988 Brougham
by momo
06/24/16 06:38 PM
Newest Members
accobra66, Diehl, Hotrodls1, Koloa, codeman021
58257 Registered Users
Who's Online
36 registered (claluja, b1amgm47, Char Baby, bbhero, chrisri, 6 invisible), 635 Guests and 10 Spiders online.
Key: Admin, Global Mod, Mod
Forum Stats
58257 Members
66 Forums
250769 Topics
Max Online: 2862 @ 07/07/14 03:10 PM
Donate to BITOG
Page 2 of 2 < 1 2
Topic Options
#3236831 - 01/04/14 08:09 AM Re: 1MZFE 187,500 Miles [Re: Big Smoke]
kschachn Offline
Loc: Upper Midwest
Well, you hit all the high spots in maintaining that engine. Those Aisin kits are awesome. Completely OEM parts for a Toyota and a good price too. Aisin isn't the OEM water pump supplier for my Accord, but I bought one of the kits anyway based on my past experience. It was of very high quality, everything made in Japan.
And yes those spark plug wires are ready to install which makes it easy.
Originally Posted By: Big Smoke
I did a laundry list of things that totaled up to about $1,200. TB kit, plugs, wires, all cooling hoses, t-stat, rad cap, valve cover gaskets, pcv, pcv grommet, cam seals, crank seal, A/C & P/S belts, fuel filter, and quick struts. Most all my parts were OEM. Amazon has a great price on an OEM Aisin TB kit (TKT-024) which includes the hydraulic tensioner and idler bearings. All the other OEM stuff came from a dealer in VA and it didn't add that much to the cost vs. aftermarket items. The nicest thing was the plug wires that came already loomed.
Now hopefully all I need to do in the next 112,000 miles is change oil and filters.
I have an OEM set of heater hoses (engine to heater coil) if anyone is interested. PM me.
_________________________
1994 BMW 530i, 206K
1996 Honda Accord, 217K
1999 Toyota Sienna, 348K
2000 Toyota ECHO, 254K
#3238563 - 01/05/14 05:08 PM Re: 1MZFE 187,500 Miles [Re: Big Smoke]
mr_diy Offline
Loc: Michigan
Originally Posted By: renegade_987
Looks excellent for an almost 200K motor
Thank you. 3-4k OCI's, regular PCV changes, air filter changes, and TB kit every 90K (+/-). Ready to run to 300k before the next heavy maintenance. Also did the KYB quick struts all the way around. Very happy that I went with KYB, what a nice firm ride.
Has your TB looked worn at 90k? I have been going by the original owners manual supplement that only calls for a TB replacement, at 90k, for "heavy commercial use". Otherwise no apparent replacement recommended. I plan to only replace when the water pump needs replacement.
98 Toyota Sienna 155k, 18-26mpg, 21avg
13 Honda Civic 12k, 28-45mpg, 34avg
#3238568 - 01/05/14 05:16 PM Re: 1MZFE 187,500 Miles [Re: renegade_987]
javacontour Offline
Loc: Illinois
The supposed sludge monster V6.
Yes it would sludge. But I suspect only if you pushed OCI to the limits or beyond.
Nice job!
network down, IP packets delivered via UPS -BOFH
#3238716 - 01/05/14 08:00 PM Re: 1MZFE 187,500 Miles [Re: mr_diy]
Big Smoke Offline
Loc: Knoxville, TN
It has looked great both times. First one was done right at 90k and the second one at 187K. I plan on going 112k on this one. The valve covers and cam seals needed done badly. That was the main reason for this TB job.
1999 Camry XLE - 253,000 Miles.
#3238756 - 01/05/14 08:35 PM Re: 1MZFE 187,500 Miles [Re: mr_diy]
kschachn Offline
Loc: Upper Midwest
You're going to wait for a water pump failure? That's one component I'd rather not wait till it fails.
The belt itself usually looks pristine at changeout. However, the idler and tensioner pulleys will fail before the belt.
1994 BMW 530i, 206K
#3249919 - 01/16/14 06:04 AM Re: 1MZFE 187,500 Miles [Re: kschachn]
mr_diy Offline
Loc: Michigan
Thanks for the info. What time or mileage is your experience on idler/pulley replacement?
#3256491 - 01/22/14 04:10 PM Re: 1MZFE 187,500 Miles [Re: mr_diy]
Big Smoke Offline
Loc: Knoxville, TN
A complete OEM kit (Aisin) can be had for $140. Why not just buy the kit and replace at every TB change? It's cheap insurance.
#3256627 - 01/22/14 06:57 PM Re: 1MZFE 187,500 Miles [Re: mr_diy]
kschachn Offline
Loc: Upper Midwest
Well, the one time I didn't change the idler and pulley with the belt (the first change) it failed about 20,000 miles later. The engine started making a knocking noise at a certain RPM, almost like rod knock (the pulleys are bolted directly to the head and/or block). The dealer in town diagnosed it for free for me when I had it in for something else. The tech pulled back the timing cover and as the engine was revved, you could see the idler "hop" or wobble when it made the noise. He said it was common if you didn't replace the pulleys at the same time as the belt smile
And I agree with the comment about buying the Aisin kit and putting it all in. You can't go wrong with that kit.
1994 BMW 530i, 206K
Page 2 of 2 < 1 2
