Recent Topics
Fram Ultra XG10060 Cutaway...
by AnthemBassMan
20 minutes 8 seconds ago
The Vole (MS) now deceiving users to install W10
by simple_gifts
27 minutes 29 seconds ago
5w20 + seafoam + hot weather + towing = ?
by meborder
Today at 03:15 PM
Chewbacca Mom & James Corden
by CharlieBauer
Today at 02:45 PM
This Radiator Looks Good to Me!
by Miller88
Today at 02:38 PM
Bill Cosby's sex assault case going to trial
by Mr Nice
Today at 02:25 PM
This is one reason I prefer to do my own oil
by SirTanon
Today at 01:37 PM
Recent discovery of SatbiliTrack failure Mode
by MolaKule
Today at 01:11 PM
Costco Insurance discountn going away?
by stockrex
Today at 12:56 PM
4 Wix Oil filters and 1 Mazda OEM AF (skyactiv)
by badtlc
Today at 12:48 PM
FYI, At&t Implements data caps today
by badtlc
Today at 12:12 PM
Top Tier Gasoline = only 5 miles more per tank?
by Hyde244
Today at 11:45 AM
Newest Members
WeekendWarrior, emily, lex73, showstopr30, any_user
57966 Registered Users
Who's Online
74 registered (440Magnum, 2oldtommy, Al, 94astro, AnthemBassMan, 4 invisible), 1848 Guests and 103 Spiders online.
Key: Admin, Global Mod, Mod
Forum Stats
57966 Members
66 Forums
249352 Topics
Max Online: 2862 @ 07/07/14 03:10 PM
Donate to BITOG
Page 7 of 7 < 1 2 3 4 5 6 7
Topic Options
#3259084 - 01/24/14 09:40 PM Re: Should you ever change your air filter? [Re: nickolas84]
901Memphis Offline
Loc: Northern Kentucky
Originally Posted By: nickolas84
What about weighting your air filter as a poor man's restriction gauge?
Assuming that the airfilters capacity is 300gr if one finds 100gr increase in weight, then he can keep the filter 50% longer, or install a new one and keep it 50% longer, and still be on the safe side.
Not a good idea due to the gasket being disturbed even one time can lead to leaks after its been compressed for a long time then uncompressed and re-compressed.
Also i believe you will allow contamination into the system too often. My air filter is very hard to get out, i wouldn't want to open it unless i was changing it and i don't even like doing that.
_________________________
2002 Buick Century 125k - Built 4T65e(Maxlife) - M1 0w40 /Fram Ultra XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3259214 - 01/25/14 02:08 AM Re: Should you ever change your air filter? [Re: 901Memphis]
nickolas84 Offline
Loc: Greece
No no no! The filter would be removed only once for weighting and either establish it's replacement miles or replace it straight away and use the info to make an educated choice on the replacement of your next filter.
Then., based on the weight gain of every filter you replace you decide the replacement interval for the next filter!
It is far from perfect but it could help people who now change their air filter too early by a factor of 10X.
#3259416 - 01/25/14 09:21 AM Re: Should you ever change your air filter? [Re: dnewton3]
afoulk Offline
Loc: Brickerville, PA
Originally Posted By: dnewton3
If you're speaking of my situation, it's because of the incredibly difficult ingress/egress issues ...
If you've never worked on a GL1800 Goldwing, it's a total nightmare and I don't exaggerate when I say it's easily an hour job just to get in, and then about the same back out. I kid you not.
I remember servicing my dads Suzuki burgman 600, that was not much fun either:)
2012 Toyota RAV4 2.5L AWD
#3259619 - 01/25/14 12:40 PM Re: Should you ever change your air filter? [Re: Jim Allen]
mr_diy Offline
Loc: Michigan
Originally Posted By: Jim Allen
Originally Posted By: mr_diy
I previously had neglected to change an original air filter (~80k) and after running a OA and getting a rather high silicon reading, I changed it out and the next OA had one third the silicon level. That original filter did not look bad, so maybe it was channeling.
Possibly. Other possibilities are a poor fit in the housing (maybe from being removed a few times). It might have been cleaned at some point and damaged. It's also possible the filter you replaced it with is more efficient.
Most likely iIMO is just the variables of comparing only two UOAs. Unless the differences were significant (say over 25%) it could be simple testing variables. Comparing two tests does not result in very accurate comparisons. To "see" small differences, you need trending. Lots of UOAs in each condition.
I don't believe I ever removed filter prior to the change, and it still looked fairly clean when replaced. The SI dropped from 21 to 7 and the replacement filter was a Purolator classic. Civic OA
My advice if you are not doing regular OA's, is just change based on recommended schedule. Then is the filter or gasket is failing you get it replaced sooner than later. A restriction gauge would only seem to make sense for very dusty areas where filters fill up faster than normal. Would not warn of a small bypass or failing media.
98 Toyota Sienna 155k, 18-26mpg, 21avg
13 Honda Civic 12k, 28-45mpg, 34avg
#3264347 - 01/29/14 09:34 PM Re: Should you ever change your air filter? [Re: dnewton3]
rrounds Offline
Loc: SACRAMENTO, CA
Take a look at these, you should be able to find one that will work on your bike.
http://filterminder.com/products.asp
ROD
'06 S2000
'00 SSEi sold at 252k miles
'08 Ford F53 V10
'13 Jeep Sahara 2 door
